Clean the MAF?
Discussion in 'Technical Chat' started by Sprig, Feb 7, 2019.
  1. Feb 7, 2019 at 10:20 AM
    Sprig
    Sprig [OP] Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I have a 2009 TRD 4x4 with the 4.0 engine. Bought it new and have had all the maintenance done per the manufacture maintenance schedule. It has 95000 miles. I’ve never cleaned the maf. It runs great, should I clean it? Or not mess with it “if it ain’t broke”?
    lynyrd3 likes this.
  2. Feb 7, 2019 at 11:50 AM
    peteyfresh
    peteyfresh Well-Known Member
    Pete
    13 Taco DCLB, 04 4Runner, 97 Jeep ZJ, 86 VW GLI
    I would, especially if you have a K&N or other high flow air filter. Just make sure you use MAF sensor cleaner, not brake clean or anything else that will leave a residue.
  3. Feb 7, 2019 at 9:20 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    I recall someone mentioned not to touch the sensor with the spray can’s straw as the sensor is fairly fragile.
    lynyrd3 and whatstcp like this.
  4. Feb 7, 2019 at 9:25 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Cleaning the MAF at every oil change or when you change the Air filter is recommended
    Cleaning the MAF restores lost power and increases mpg
  5. Feb 7, 2019 at 9:29 PM
    Bishop84
    Bishop84 Well-Known Member
    It is sensitive and fragile, I would discourage cleaning it more than once a year. I just clean them during the spark plugs which is plenty frequent.
    Wyoming09 and US Marine[QUOTED] like this.
  6. Feb 7, 2019 at 9:35 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I clean my MAF at every oil change. I have done so for 14 years.
    I have also run a K&N for those 14 years.
    290,000 miles on the truck (230k of those miles are mine with a K&N) zero problems.
    lynyrd3 and US Marine like this.
  7. Feb 8, 2019 at 12:48 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have never cleaned my MAF after the first failed attempt .
    Just install a new one when I remember
    lynyrd3 likes this.
  8. Feb 8, 2019 at 10:43 AM
    Sprig
    Ken
    Never done it but it looks pretty easy to do. Unplug it, remove 2 screws, pull the maf out, spray it with spray maf cleaner. Let it dry thoroughly and then reinstall. Right?
    El Taco Diablo likes this.
  9. Feb 8, 2019 at 10:47 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    No need to unplug the harness from the MAF
    Sprig[QUOTED][OP] likes this.
  10. Feb 8, 2019 at 12:30 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    It's a lot easier to clean if you remove the MAF from the vehicle. Lay it on a clean rag and spray the 2 different areas with the sensor wiring(my term) from different angles.
    Use the CRC MAF cleaner unless you know of another. Let it air dry for awhile once you are done.
    lynyrd3 likes this.
  11. Feb 8, 2019 at 12:33 PM
    mwnewel
    mwnewel Well-Known Member
    Michael
    Denver, Colorado
    2015 Tacoma DB TRD 4x4
    OME 887x, OME Shocks, Dakar Pack, RCI Skids
    I cleaned my MAF sensor and throttle body at 75,000 miles and was shocked how dirty both were. As others have said if you run a K&N I highly recommend it as it is not hard to do at all.
    lechicklet and US Marine like this.
  12. Feb 8, 2019 at 12:36 PM
    lynyrd3
    Bill
    East Central Upstate NY
    112,900 miles and never cleaned MAF or throttle body . Bought the spray for both ,maybe this spring . I’m not very mechanically inclined o_O :rofl:
  13. Feb 8, 2019 at 12:38 PM
    Sprig
    Ken
    I just brought my truck in today for some service including changing the serpentine belt. Since it was there I asked them to clean the maf. They did and said no charge for it. Love the garage I take my truck to.
  14. Feb 8, 2019 at 12:39 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    I can easily spray the MAF and clean it thoroughly with the harness plugged in . I've talked to a few auto techs and they do the same as some shops won't allow the techs to unplug the harness unless changing the MAF out
    I place a towel over the area of the air box or in my situation the CAI . The harness on my 2.7 is long enough to place it on the towel and clean it
    Sprig[OP] and lynyrd3 like this.
