Clean Engine Mating Surfaces?
Discussion in '1st Gen. Tacomas (1995-2004)' started by austinmtb, Jul 17, 2019.
  1. Jul 17, 2019 at 10:43 AM
    austinmtb
    austinmtb [OP] Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    I recently purchased this rebuilt engine and noticed that the injector holes, intake manifold, exhaust manifold surface, oil filter surface, and oil cooler surface are all painted.
    Should I remove the paint from these surfaces before installing everything? If so, will getting paint in the engine be an issue or will it just burn up? The injector holes seem nearly impossible to clean without getting paint in the engine.
  2. Jul 17, 2019 at 2:56 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    yeah, pretty sure those shouldn't be painted.
    It doesn't look like they masked ANYTHING off.
    I would be highly suspect of the quality of that rebuild... who did that?
    wilcam47 and Running Board Man like this.
  3. Jul 17, 2019 at 3:26 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    If you do remove the paint, I'd use a shop vac
    to pick up debris.
    Try using a rag with solvent to clean paint.
    austinmtb[OP] likes this.
  4. Jul 17, 2019 at 7:37 PM
    austinmtb
    Austin
    Southern Oregon
    "Toyota Engines" in Oregon.
    They have great reviews and offer a 3 year unlimited milage warranty, the most generous warranty out of any rebuild company that I've seen. They were recommended to me by a few mechanics and friends that have had good experiences with them.
  5. Jul 17, 2019 at 8:19 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Call and ask them?
    jbrandt likes this.
  6. Jul 17, 2019 at 8:26 PM
    austinmtb
    Austin
    Southern Oregon
    I asked the builder about the exhaust manifold surface when he dropped the engine off and he said to just put the gasket on over it. I didn't notice the injector holes were painted at that time, so I wasn't able to ask about that. I don't really like the idea of putting all these components that need to seal on over paint, hence why I'm asking for a second opinion on here.
  7. Jul 17, 2019 at 8:27 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You should see some of the paint work on domestic v8 garage rebuilds.
    Abeyancer and Running Board Man like this.
  8. Jul 17, 2019 at 8:29 PM
    austinmtb
    Austin
    Southern Oregon
    Sounds like a good plan, I'll give it a try.
  9. Jul 18, 2019 at 9:13 AM
    jbrandt
    Justin
    I've seen plenty of businesses go down hill that I'd no longer send them my trash, let alone trust them with my vehicle.
    Regardless if you heard good things about them, it is odd to me that they would be okay with throwing a gasket over paint like that. IFAIK, you never paint a gasket mating surface. That's just seems fishy. Plus the fact that you can see they didn't really mask off very much when they painted the block and heads. Just seems like lazy work.
    I would honestly take it back and make THEM do it. You paid for that motor, you shouldn't have to do a bunch of extra work to it.
  10. Jul 18, 2019 at 9:30 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    I second this opinion, I've rebuilt 2 stroke power equipment where cheaper brands paint the cylinder jug and didn't mask off the bottom of the clamshell because "the permatex seals it" and after a couple run cycles are running like shit and weeping fuel mix out of the bottom of the jug .. granted they use cheap cheap paint that bubbles at the first hint of heat
    cruiserguy likes this.
