Clean back-up camera install for 1st gen Tacomas
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Oct 4, 2020.
  1. Oct 4, 2020 at 5:02 PM
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
    I bought an Alpine ILX-w650 headunit from Best Buy and a $40 camera off Amazon. I also bought a Pop-N-Lock for my tail gate. I drilled a hole in the Pop-N-Lock to feed the camera wire through. Ran the wire inside the tailgate and under the truck, following the factory harness. Now, every time I put the car into reverse the camera comes on automatically. It works great, wish I did it when I first got the truck. It is great having apple car play and running the Waze app, it automatically tells you of any police sightings in your area/route.
    I wired the automatic camera turn-on wire from my headunit to the reverse gear trigger switch under my seat. It’s a red/black wire in the collection of factory wires.
    My headunit has an automatic lock out if the car‘s emergency brake isn’t on, meaning you’re supposed to wire the headunit to the e-brake wire or else the head unit won’t let you use most any of the features. For this reason they sell parking brake bypasses on amazon, I listed the one I used below. The bypass works great, you just wire it to the unit and the unit thinks the parking brake is on all the time
    The Pop-N-Lock is cool, but not worth the $50 price tag. It’s just a piece of plastic with a lock. I had no choice as I wanted to do the cleanest install possible. I wish someone could find dimensions for it so the shell could be printed on a 3D printer. Pop-N-Lock also sells a wireless, automatic lock for keyless entry to your tailgate as an added accessory. When my camper shell is locked, it prevents the tail gate from opening anyway.
    I also swapped the cigarette lighter for a USB pass-through ($10 on Amazon) so i can run apple car play on my headunit and not have a wire dangling anywhere.
    Next upgrades will be to change the dashlights to blue LED, OME suspension, new rims/tires, bumper light bar, and full JL audio sound system.
    Parts I used
    camera
    https://www.amazon.com/gp/aw/d/B07H852D49?psc=1&ref=ppx_pop_mob_b_asin_title
    Pop-N-Lock
    https://www.amazon.com/gp/aw/d/B000GVM7CM?psc=1&ref=ppx_pop_mob_b_asin_title
    USB pass-thru
    https://www.amazon.com/gp/aw/d/B01NAMU8KY?psc=1&ref=ppx_pop_mob_b_asin_title
    Alpine parking brake bypass
    https://www.amazon.com/gp/aw/d/B07T545H2M?psc=1&ref=ppx_pop_mob_b_asin_title
    6D4A0745-D797-4812-88C4-8957FBE53BD7.jpg 2A221570-7229-45FB-8C9D-7A91ECA9A42E.jpg
    Install and Pop-N-Lock modification info below
    The camera post I did not need to modify, it was short enough to fit perfectly. I did modify the plastic on the back of the pop lock, right where you drill a hole there is a diagonal piece of plastic your drill bit will go through. I clipped that whole diagonal piece off so I could thread the nut onto the camera post. I used a grinder to cut/flatten ONE of the sides of the flanges on the nut so it will fit flush on the pop lock. The nut will stay in place, so twist the camera itself to thread it on.
    Here is the back of the assembly
    here is a shot of the post. Short enough, no mods required. Notice how your pop lock has a diagonal piece of plastic for reinforcement in this area. Clip it.
    this is one of the most important parts. Cutting the flange nut with a grinder so it fits. Thread the camera itself, not the nut.
    I took a drill bit and widened one of the indentations for the wire to pass through without being pinched
    when you reinstall the assembly it might look from the outside like it’s not flush. It’s vital you get this lip piece on the backside of the factory handle over the sheet metal of the tail gate. Just push in on the handle itself and it will pop into place
    this is how I ran the wire. I’m going to add a loom over it. It goes under And passes through into the taillight from underneath the truck. I zip tied all the extra wires and tucked them behind the taillight.
  2. Oct 4, 2020 at 5:04 PM
    tony2018
    tony2018 Well-Known Member
    hows the view? any images?
  3. Oct 4, 2020 at 5:05 PM
    Cutter_
    Yes third picture. View is great I had the option to use the the lines from the camera or the headunit, I opted for the headunits lines.
  4. Oct 4, 2020 at 5:06 PM
    tony2018
    ah, that image didn't looad
  5. Oct 4, 2020 at 5:19 PM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    Nice install of the camera. Do you have the URL for the camera? Plan on doing the same thing.
  6. Oct 4, 2020 at 5:25 PM
    Cutter_
    This camera’s features are great. You can flip the image and shut off the built in back up assistance lines if you want
    jammer, Kleenax[QUOTED] and tony2018 like this.
  7. Oct 4, 2020 at 5:53 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Thanks for the post, @Cutter_. I have *exactly* the same project underway with the Pop 'N' Lock on my 2003 DC and the Pioneer AVIC-5201NEX head unit I put in a couple of years ago. My camera is different (only a little).
    Did you have to work around anything related to the post length on the camera? As I've made dozens of measurements, it looks like the one I have will *just* clear the indentation in the tailgate and fit into the open space.
    Any shots of yours from the back before you buttoned it up?
    What did you do to route the camera cabling between tailgate and pickup bed? Anything special around strain relief or armoring?
    PS: I've put OME kits on two Gen 1 Tacomas now. I've had OME stuff on a number of vehicles, and ARB's Gen 1 Tacoma setup is one of their best. About 2-inches of lift (or a hair under) and ride quality better than stock. I run an ARB bullbar and either an aluminum tonneau or fiberglass shell over the bed, with BFG AT KO 235/85-16.
    ontarioyota and Cutter_[OP] like this.
  8. Oct 4, 2020 at 6:24 PM
    Cutter_
    The camera post I did not need to modify, it was short enough to fit perfectly. I did modify the plastic on the back of the pop lock, right where you drill a hole there is a diagonal piece of plastic your drill bit will go through. I clipped that whole diagonal piece off so I could thread the nut onto the camera post. I used a grinder to flatten ONE of the sides of the flanges so it will fit flush on the pop lock. The nut will stay in place, so twist the camera itself to thread it on.
    linkie, jammer and 4xdog[QUOTED] like this.
  9. Oct 4, 2020 at 10:21 PM
    ROlla-Xrs
    ROlla-Xrs Well-Known Member
    Roman
    Elk,WA
    1st gen Trd Tacoma
    Looks clean :thumbsup:
    Cutter_[QUOTED][OP] likes this.
  10. Oct 5, 2020 at 7:13 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Great write up and detailed information on the install. Thank you for the links as well.
    Taco critter and Cutter_[OP] like this.
  11. Nov 26, 2020 at 7:21 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Same thing on the stock tailgate handle.
  12. Nov 26, 2020 at 7:37 AM
    MCJohnston
    MCJohnston Well-Known Member
    Matthew
    CT
    02 Tacoma SR5 TRD 3.4L 4x4 X-tra Cab
    Nice work. I’d been thinking about getting the pop and lock system for the bed but now I’m pushed even more to try this out
  13. Nov 26, 2020 at 9:17 AM
    Kevins60
    Kevin
    Odessa FL
    Thanks, i went this route because I figured if I really screwed up i would be out $15 for a new tailgate handle and no one would be any the wiser. I used a 5/16 drill bit to drill out the tailgate handle from the back and open up the screw hole in the tailgate to get the camera nipple to fit. Also used a rubber grommet in the drain hole to prevent chafing and secured the connector on the camera cable to the bottom of the tailgate with a plastic cable clamp so I can disconnect it if I ever need to remove the tailgate and ran all the cabling in split wire loom. I’ll shoot you a picture of it when I get home next week. I haven’t done a lot of mods on my truck but this is my favorite.
    nchiker1 and MCJohnston[QUOTED] like this.
  14. Nov 26, 2020 at 2:39 PM
    nchiker1
    nchiker1 Well-Known Member
    Very nice! Saved for reference incase I get a camera. Getting a stereo similar to that one put in next week. Are the buttons' location on the bottom of the stereo annoying at all? There's another stereo I'm considering that has the buttons located on the bottom. My current one on order has the buttons on the left have side, vertically oriented.
  15. Nov 26, 2020 at 2:42 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Nice clean install :thumbsup:
  16. Nov 26, 2020 at 4:04 PM
    Cutter_
    Touch buttons are a bit annoying when driving, it’s hard to hit what you want. I still went with this one because I feel that it looks as close to factory as possible, the other stuff with buttons and crazy colors look goofy and cheap IMO. This one also has a button you can hit to mute the whole system. There’s a guy in the thread below that added steering wheel controls, I just haven’t done it yet. Next thing I’m gonna do is adding a bass knob, once you run a system like mine you NEED IT
    https://www.tacomaworld.com/threads...l-audio-controls-for-50.650541/#post-22609057
    ontarioyota likes this.
  17. Nov 27, 2020 at 10:43 PM
    twolexxx
    twolexxx New Member
    2003 Black Tacoma TRD
    Do you think you can post pictures of how you wire the camera to the tail light wires? I’m having trouble figuring out which one is the (+) reverse wire and the ground wire for the back up camera
  18. Nov 27, 2020 at 10:56 PM
    Cutter_
    Yeah I’ll clarify tomorrow
  19. Nov 28, 2020 at 8:44 PM
    Geeoh43
    Geeoh43 Well-Known Member
    Gio
    Fort Lauderdale, FL
    2004 Tacoma Prerunner SR5 DC
    Tints LED license plate lights Double Din
    Can you post picture of HU while in reverse to see the angle
  20. Nov 28, 2020 at 9:12 PM
    Cutter_
    it should be in OP
