Clanking noise from under the truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tig3r_Bit, Jul 25, 2020.
  1. Jul 25, 2020 at 11:48 AM
    Tig3r_Bit
    Tig3r_Bit [OP] Well-Known Member
    2018 TRD OR 4x4
    Hey y’all. So today. I experience some kind of noise. Sounds like is coming under from my truck? Is sound like clicking noise. Or something like to metal bar hitting one another. It happens when I reverse and then it’ll happen again when I put it in D and drive away.
  2. Jul 25, 2020 at 12:48 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    How about looking under the truck?
    Tyler7544 and QuicksandTaco like this.
  3. Jul 25, 2020 at 12:54 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    It’s probably the brake pads shifting.
    Skydvrr likes this.
  4. Jul 25, 2020 at 2:13 PM
    Tig3r_Bit
    2018 TRD OR 4x4
    I never experience this before
  5. Jul 25, 2020 at 3:18 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    How loud? Could the chain on the spare be hanging down through the rim?
    Tig3r_Bit[OP] likes this.
  6. Jul 25, 2020 at 3:20 PM
    FLJB
    FLJB Well-Known Member
    J
    FL
    2020 4X4 Sport MT
    I second this. If you search my posts, I have one from years ago where this was a pretty common phenomenon with 2nd Gens at least...
    If it is brake pad slap, it is a pretty low cost easy fix. I think i even posted the parts and what to do...
    Skydvrr and Tig3r_Bit[OP] like this.
  7. Jul 25, 2020 at 3:22 PM
    Tig3r_Bit
    2018 TRD OR 4x4
    Gen 3. Possibility TSB?
  8. Jul 25, 2020 at 3:24 PM
    Tig3r_Bit
    2018 TRD OR 4x4
  9. Jul 25, 2020 at 3:26 PM
    Tig3r_Bit
    2018 TRD OR 4x4
  10. Jul 25, 2020 at 3:34 PM
    Pogue_Mahone
    Pogue_Mahone Well-Known Member
    2020 TRD Off Road 4X4 DCLB
    Yeah, check under the truck. Could be something as simple as something you picked up on the road or an angry co worker f-----g with you. No kidding, I've seen all kinds of cruel automotive jokes. Bolts placed behind hubcaps, a thick slice of limburger on the radiator etc. Tacos are easy to get under.
    Chako and Tig3r_Bit[OP] like this.
  11. Jul 25, 2020 at 4:26 PM
    jetfishn
    jetfishn Well-Known Member
    U-Joints?
  12. Jul 26, 2020 at 5:28 AM
    Tig3r_Bit
    2018 TRD OR 4x4
    I really appreciate the help y’all. And yes. That day, me and my son was out and about all day. I’ll totally check my truck today.
  13. Jul 26, 2020 at 5:41 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Sounds like axle wrap if it's only happening when you are stopped and changing gears/direction of travel. Sounds like a metallic clank when you have foot on the brake and move gear shift from Park to Drive, or Drive to Reverse. Maybe louder when engine RPMs are bit higher on cold engine. Sounds like it is coming from rear area of vehicle. If these are true, could be axle wrap.
    https://www.tacomaworld.com/search/12190023/?q=axle+wrap&t=post&o=date&c[node]=186
  14. Jul 26, 2020 at 6:06 AM
    Dee1seven
    Dee1seven Well-Known Member
    RVA
    '17 DCSB TRD OR - Quicksand
    '15 TRD Pro Bilstein Suspension HS 3 leaf AAL TRD PRO Wheels 285/75r16 BFG KO2’s Truxedo Soft Roll Up cover
    Go forward a few inches press the brake reverse a few inches press the brake... keep doing this until you can replicate the sound that you are hearing, you’ll find that it’s the pads “adjusting/slapping” as you move forward or reverse. It’s a known 2nd gen quirk that carried over
  15. Jul 26, 2020 at 6:13 AM
    andrewbrandon19
    andrewbrandon19 Well-Known Member
    Having used the spare time some time ago the chain mechanism wasn't put back perfectly in place and sometimes it slaps the the wheel of the spare tire. Took me forever to notice because I usually have the windows up and music blaring.
  16. Jul 26, 2020 at 6:13 AM
    boston23
    boston23 Well-Known Member
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    I had a weird clicking noise fron a loose skid plate that i thought was a busted cv
  17. Jul 26, 2020 at 6:19 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I took some bailing wire and secured a roadkill possum under a guys truck back in the day. He never could figure out where the smell was coming from. lol
    Pogue_Mahone[QUOTED] likes this.
  18. Jul 26, 2020 at 7:15 AM
    Tig3r_Bit
    2018 TRD OR 4x4
    @Wsidr1 yes. That’s what I’m experiencing. Going forward and then stop. Reverse stop and so on. That’s when I hear the clanking noise.
  19. Jul 26, 2020 at 7:16 AM
    Tig3r_Bit
    2018 TRD OR 4x4
    @Dee1seven yep. When I do. That’s when the noise happens.
  20. Jul 26, 2020 at 7:46 AM
    boston23
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    That’s vile lmao
    What did he do to u?
    shakerhood and andrewbrandon19 like this.
