Circulating coolant heater
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ack_Thbbft, Dec 22, 2018.
  1. Dec 22, 2018 at 6:31 PM
    Ack_Thbbft
    Ack_Thbbft [OP] Member
    Bil
    2017 Tacoma TRD 4x4
    Has anyone installed an honest-to-goodness circulating coolant heater on a V6 2017? The 400 watt external tiddler is a bit under powered. When to 350 watt B/H in my 2010 VW diesel went, I replaced it with a 1500 watt Zero-Start. 45-90 minutes was all that was needed for an easy start, even at 20 below.
    I looked under the hood, but there's too much plumbing to sort out without a service manual, and mine's still under warranty.
  2. Dec 22, 2018 at 6:45 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
  3. Dec 22, 2018 at 6:46 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    What are you looking for exactly? Just a heater for cold start or a heater to actually get the heater working sooner?
    The Tacoma has a few things:
    1. 0W-20 Synthetic gives you to -40f starting ability.
    2. An electric heating coil built in to the heating unit to augment your standard heater.
    3. If you are going to be in really cold weather, a simple block heater plus the above should be all you need.
    doublethebass and TXpro4X4 like this.
  4. Dec 22, 2018 at 6:47 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Pretty sure these trucks have a circulating coolant heater
    OnHartung'sRoad likes this.
  5. Dec 22, 2018 at 6:52 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    A good block heater circulates the coolant, don’t the Canard’s versions have that option?
  6. Dec 22, 2018 at 6:52 PM
    Bushed
    Bushed Well-Known Member
    Kenora, ON
    08 DCSB TRD OR - Sold
    Cambridge Metals and Plastics Bed Bar
    More of a diesel thing, isn’t it? Had one on my 06 Jetta TDI. Was a beautiful thing. Never really had any cold start issues with a gasser. Block heater should suffice. A battery blanket is nice to have too.
    hiPSI likes this.
  7. Dec 22, 2018 at 7:07 PM
    WARPED5
    WARPED5 Well-Known Member
    Ted
    NW IN
    2017 Blue TRD OR
    BITD, I had a Corona .... was parked outside ... put a dipstick heater in there with a 100W bulb next to the battery. All was hooked to an appliance timer set to 1 HR before I left for work. Did an excellent job!
  8. Dec 22, 2018 at 7:34 PM
    LVLAaron
    LVLAaron Well-Known Member
    Aaron
    2018 TRD Off Road
    I think he's looking for the a plug-in device that goes in your coolant line.
    hiPSI and Bushed like this.
  9. Dec 23, 2018 at 10:43 AM
    Ack_Thbbft
    Bil
    2017 Tacoma TRD 4x4
    My sold-in-Canada Tacoma came without a block heater. I have the dealer option one to go in, but its only 400 W or so. So it needs to be plugged in for hours to be effective. And it only warms the block metal from the outside. Someone posted an IR pic of the motor in one of the block heater threads, so heating is localized.
    As far as starting, it not been a problem so far. I have noticed significantly poorer gas mileage in cold weather, on short cycle driving, which I expected. Like 20%, if you believe the truck.
    My diesel experience has been a 25% increase in fuel consumption, in cold weather(-10 C and down, Less than 25km trip). Preheating made a huge difference.
    So, prewarming the engine will likely pay a dividend. I have actual coolant heaters on hand, but they are convection type, so correct plumbing is critical, or they don't work/overheat.
  10. Dec 23, 2018 at 10:51 AM
    Ack_Thbbft
    Bil
    2017 Tacoma TRD 4x4
    Like, one of these
    https://phillipsandtemro.com/solutions/engine-heating-solutions/circulation-heaters/
    These WILL NOT work properly, unless the heater outlet runs upward into the block, dip-free, and draws from a lower point in the system. Water channels have to be open when the engine is cold (think closed thermostat). Not a big deal on older gas engines, cuz the ports were there and the plumbing comparatively simple.
    A frost plug heater is another option, but it involves engine surgery, something I can't do whilst under warranty. I may not have access to a suitable plug anyway.
  11. Dec 23, 2018 at 11:13 AM
    Ack_Thbbft
    Bil
    2017 Tacoma TRD 4x4
    For people with deep pockets, a Webasto or Eberspacher would be nice. Not me, right now.
  12. Dec 23, 2018 at 11:25 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    If the 3rd gen block heater is similar to the block insert style on the 2nd gen it should work fine. I just checked mine that’s been plugged in for a couple hours and it’s warmed the coolant from -10°F to 52°F in that time. I have an oil pan heater as well which probably helps radiate some heat upwards through the block.
  13. Dec 23, 2018 at 8:07 PM
    Ack_Thbbft
    Bil
    2017 Tacoma TRD 4x4
    So it would seem. Hole in the left rear face of block. I'm awaiting heat transfer paste and decent weather for the install.
    And, I s'pose, some cold weather to test it out. Gonna be +5 C here next week.
    I take that back. We had a winter a few years back where it was warmer Yellowknife than southern Ontario for about 2 weeks.
    A plumbing diagram for a circ type heater from some one who has it working would be appreciated.
    So far, no takers...
  14. Dec 23, 2018 at 8:21 PM
    Ack_Thbbft
    Bil
    2017 Tacoma TRD 4x4
    I really want the fuel-wasting, emission-system heat-up sub-program to kick off sooner. On my VW TDI, I thnk it was based on engine coolant temp.
    Regardless, a block heater and weather front saved significant fuel.
    A big block heater allows me to turn it on and get ready(60 minutes, pillow to punchclock). The factory 400W means I need to plan things hours ahead of time (not always possible) to benefit.
    My indicated tank mileage is 10-15% poorer in cold weather.
  15. Dec 23, 2018 at 8:26 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I use an outdoor timer to turn mine on and off automatically. My work schedule changes daily and at random but it’s a simple one minute job to change the timer the night prior as needed.
  16. Dec 23, 2018 at 8:36 PM
    Ack_Thbbft
    Bil
    2017 Tacoma TRD 4x4
    On my Dodge Cummins, I used a remote switch thingie (think key fob to turn on/off the christmas lights).
    Never got curious enough to find out how big the heater was (it was a lease), but 45 minutes was the difference tween Happy diesel start-up and Angry Diesel. Colder the bigger difference. Never had a no-start.
    I guess I'll find out when I get the cartridge heater up and running.
    It's a discipline thing, really. Spend 15 cents on hydro to save 50-75 cents on fuel. Or not.
  17. Dec 23, 2018 at 8:40 PM
    Ack_Thbbft
    Bil
    2017 Tacoma TRD 4x4
    Anyone using Webasto heaters or similar on gas trucks up there? Very popular on up market cars in northern Europe, I'm told.
    BMW has them as an option on the 3.0 TDI or whatever Beemer calls them.
    A bit spendy for my climate.
  18. Dec 23, 2018 at 8:43 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    No one that I know of. Pretty much everyone just goes with a block heater, oil pan heater and battery heater. Some people add a transmission pan heater or substitute a trickle charger for the battery heater.
    hiPSI likes this.
  19. Dec 23, 2018 at 8:45 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    I service and repair them. In this climate, all of our equipment is preheated.
  20. Dec 23, 2018 at 9:08 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You keep comparing our truck to a diesel and that is apples and oranges. Our truck will start with no heater at minus 40f no problem.
    Your poorer has mileage has nothing to do preheat, with the exception of the first few minutes of engine warm up. After the first few miles, the ECU has leaned out the fuel mix and opened up the air.
    If you are used to running diesel vehicles maybe you are not aware of summer versus winter gas. That will drop your efficiency by about 10%. I just did a big long post on it recently.
    I have no clue how much you drive in the winter but on average, if you are running 10% less efficient it will cost you about $5 for a 20 gallon fill up. No idea how much those heaters cost but rough calculations tell me you can be 10% less efficient and it will cost you about $100 for every 6000 miles driven.
    If you just want it for quicker heat in the cab then fine, but for actual efficiency and cold weather operation on the Tacoma it is not needed unless you are in really cold climates.
    Good luck man.
    The hammer likes this.
