Chirping sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TrdAaron, Nov 18, 2021.
  1. Nov 18, 2021 at 5:01 PM
    TrdAaron
    TrdAaron [OP] Well-Known Member
    Ventura, CA
    2012 Silver Tacoma TRD Off Road Access Cab 6MT
    Full OME BP-51 kit, TRD Pro 16in wheels, go fast camper, some other cool stuff.
    Hello all,
    I have a strange chirping sound coming somewhere from my 12' V6 Tacoma. I had an earlier thread on this, but since then I've gotten a better understanding of the sound. I had the TSB 0044-14 done because I thought it is a ping, but its not. Its more of a low chirp. It starts at about 1k rpm and goes up to 3.5k rpm before cutting off all together. It sounds like now its coming from behind the engine, but im not 100% sure. Maybe driveline area? I got a video of the sound, you have to turn up your volume to hear. Its most noticeable near the end of the video. For reference, the video is taken from the back of the cab with the rear window open (access cab). What could this be?
    https://youtu.be/Ve3KHBXOfzU
  2. Nov 18, 2021 at 6:15 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    When was the last time you greased your u-joints?
    wi_taco and Dm93 like this.
  3. Nov 18, 2021 at 6:58 PM
    TrdAaron
    Ventura, CA
    Never.. I only bought the truck about 10k miles ago. I'm getting new tires tomorrow, I could add that into the service and see if anything changes.
  4. Nov 18, 2021 at 7:39 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Grease them and if it stops you know where the noise is coming from. However, If it is chirping in a universal joint it is already too late to save them. Get all of them replaced as they are all probably on the last leg. Best to do it before a catastrophic failure happens.
  5. Nov 18, 2021 at 9:02 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    A lot of shops do it free if you ask.
    However, I’ve found the majority you have to ASK.
    And if they do, hope they hit the “tricky” zerk. See below for details?
    I just do mine myself, mostly because it gives me a reason to inspect the underside.
    It’s not too hard, the rear most joint on the front drive shaft can be tricky. But once you figure it out, it’s not too bad.
    I actually made a post about it years ago. - Here - To remind myself how I did it.
    Although, I have to admit. I can’t say I ever looked back on it.
    As usual, I jump in and have to figure it out all over again.
    Once you do it, you’ll understand.
    Jimmyh likes this.
  6. Nov 18, 2021 at 9:04 PM
    TrdAaron
    Ventura, CA
    Great thanks. I’ll look into that ASAP.
  7. Nov 18, 2021 at 9:08 PM
    TrdAaron
    Ventura, CA
    I’ll be sure to ask tomorrow at the tire shop! Or I can just get my own grease gun to re grease in the future. Thank you for the advice.
    TnShooter[QUOTED] likes this.
  8. Nov 18, 2021 at 9:11 PM
    TrdAaron
    Ventura, CA
    I guess I forgot to mention it ONLY happens when under load. I tried listening in the bay but sounds pretty good at idle/rev. How would one check the bearings?
  9. Nov 18, 2021 at 9:13 PM
    TnShooter
    Deogee
    STOCK
    Good thought.:thumbsup:
    Easy enough test would be to rev the engine in Park or Neutral.
    If the sound can still be heard it’s not the U-Joint(s).
    Then, remove the drive belt. Repeat above test.
    No noise heard, it’s likely a pulley or idler.
    Start spinning things by hand. You can usually tell by feel, sight or sound.
    TrdAaron[OP] likes this.
  10. Nov 18, 2021 at 10:14 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    There is no throttle cable to pull.
    Drive by wire for the throttle.
    TnShooter and TrdAaron[OP] like this.
  11. Nov 18, 2021 at 10:15 PM
    TrdAaron
    Ventura, CA
    Sounds easy enough. I’ll give that a shot too.
  12. Nov 18, 2021 at 10:18 PM
    TnShooter
    Deogee
    STOCK
    Obviously, you don’t want to run the engine too long with no belt.
    As the engine could over heat. But you should be fine from a cold start.
    Just watch the temp gauge if you have it running long.
    TrdAaron[QUOTED][OP] likes this.
  13. Nov 18, 2021 at 10:57 PM
    TrdAaron
    Ventura, CA
    For sure. I will try this out tomorrow.
  14. Nov 19, 2021 at 9:46 AM
    TrdAaron
    Ventura, CA
    Did a little bit of investigating this morning before the new tires go on. I may have found the culprit. The carrier bearing has a good amount of vertical play and the driveshaft isn't sitting centered in it.
    https://youtu.be/QNIlt6dIQlY
    wi_taco likes this.
  15. Dec 27, 2021 at 9:04 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Was the center bearing the culprit?
  16. Dec 28, 2021 at 3:27 PM
    TrdAaron
    Ventura, CA
    Unfortunately no. Forgot to update this thread. The noise came back after a day of driving. I replaced the carrier bearing and the center U joint. Still need to replace the other two (couldn’t get the other two joints in time). I must have driven close to 5000 miles with this noise, nothing bad has come from it and one dealer said everything was fine. So it’s not my priority right now. Once I have time to replace those other U joints I’ll make sure to update.
  17. Dec 28, 2021 at 5:12 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Tension and idler pulleys
  18. Dec 29, 2021 at 6:33 AM
    Kevins60
    Kevin
    Odessa FL
    Sounds like creaky suspension. Try jumping up and down on the rear bumper?
  19. Dec 29, 2021 at 9:00 AM
    TrdAaron
    Ventura, CA
    It’s definitely drivetrain related. Only happens When I push the gas
  20. Dec 29, 2021 at 9:01 AM
    TrdAaron
    Ventura, CA
    This is soemthing I want to investigate soon too. I’m about to cross 150k and thinking about taking it in for a service rather than doing it myself… if I can summon the strength to let someone else touch my truck :(
