Chirping noise from engine
Discussion in 'Technical Chat' started by ARNIE R, Feb 9, 2022.
  1. Feb 9, 2022 at 8:05 PM
    ARNIE R
    ARNIE R [OP] Well-Known Member
    Arnold
    Leesburg, VA
    2019 Tacoma White SR5 4D ShortBed
    Fender gravel guards; Side step bars; Bug shield; Vent shades; Body side door moldings; Door edge trim; Tonneau cover
    Yesterday, I started up my truck as I was loading the bed with my work tools. A few minutes later, I heard a slight "chirping" noise. First thought was it was a bunch of birds in the background as I was at a barn doing some work, then realized it was the truck. Opened the hood but could not exactly tell where the sound was coming from. Drove home about 20 miles away and it was still making the sound.
    Started off this morning and didn't hear the noise until I arrived at my destination and could hear it slightly again. This evening, again I was packing up my tools and allowing the engine to warm up and within about 5 minutes, it appeared again. By the time I arrived home, it was fairly steady, only not in gear while at a stoplight. As soon as I gently accelerated, it became steady again, loud enough to be heard with the window open at low to moderate speeds.
    Wondering it there may be a belt or pulley bearing making the noise or something else I should be concerned about. About to call the dealer to have them look at it, but hate doing so because of the hassle of dropping it off so they can have it all day and tell me "unable to duplicate owner's concern".
    Any ideas or suggestions?
  2. Feb 10, 2022 at 11:47 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Can't tell for sure without hearing the noise but I'd guess belt or pulleys (or both). If you don't hear it until the engine warms up, you could try running the truck until it gets warm, shut it off, quickly pully off the serpentine belt, and then check again. If the noise goes away that probably kinda sorta maybe tells you it's something belt/pulley related. Diagnosis this way is free if you know how to pull the belt and do your own wrenching.
    ARNIE R[OP] likes this.
  3. Feb 10, 2022 at 4:14 PM
    ARNIE R
    Arnold
    Leesburg, VA
    Thank you for the suggestion - worth a shot.
    wi_taco likes this.
  4. Feb 11, 2022 at 7:00 AM
    OldTacoDD
    OldTacoDD current brain has check engine light on
    PNW
    2002 3.4L V6 SR5
    @ARNIE R. Grab a spray bottle with a little soap in it (windex will do in a pinch) and spray the belts to see if it goes away, even temporary. If it does then you need to change the belts. If not you are probably looking at the pully and of course the belts while you're at it.
  5. Feb 11, 2022 at 7:05 AM
    tcjacado
    tcjacado Well-Known Member
    MNMLST and SR-71A like this.
  6. Feb 11, 2022 at 7:34 AM
    ARNIE R
    Arnold
    Leesburg, VA
    Yes, I recall many, many years ago, we used to take an old bar of soap and hold it against the edge of a squeaking belt to make it stop. Might try that today.
    OldTacoDD[QUOTED] likes this.
  7. Feb 11, 2022 at 7:37 AM
    ARNIE R
    Arnold
    Leesburg, VA
  8. Feb 11, 2022 at 7:42 AM
    OldTacoDD
    PNW
    2002 3.4L V6 SR5
    If you took it in for the recall I doubt you'd need to go that far right now. Start with the basics, sometimes the pully itself needs adjusting with no replacement.
    ARNIE R[QUOTED][OP] likes this.
  9. Feb 11, 2022 at 7:45 AM
    ARNIE R
    Arnold
    Leesburg, VA
    I noticed that the chirping seemed to increase slightly as the RPM’s increased so it appeared to be speed reflated.
  10. Feb 11, 2022 at 7:47 AM
    tcjacado
    Yes. The high pressure fuel pump is in the engine bay, separate from the fuel pump in the gas tank.
  11. Feb 11, 2022 at 8:04 AM
    OldTacoDD
    PNW
    2002 3.4L V6 SR5
    I dunno, still think you should look into the pully as a start. They can 'chirp' with RPM increase since it's wobbling a little: high pitch in high RMP, drops when RPM's drop.
    If you had the recall it might be worth checking to see if both fuel pumps were checked (assuming you took it in?).
  12. Feb 11, 2022 at 8:08 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I would honestly just let the dealer deal with it. It's safe to assume it's drivetrain related so it'll be covered under 5 year/60k mile warranty.
  13. Feb 11, 2022 at 3:56 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Are your tools heavy? Im thinking carrier bearing is going out. The additional weight putting the driveline at an odd angle may stress out a worn part even further
  14. Feb 11, 2022 at 4:00 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    Lol, pretty big leap bud. Also the carrier bearing does not move unless the truck is moving. Probably the HP pump but could be the belt or idler. Sure it’s something simple.
    will.i.was[QUOTED] likes this.
  15. Feb 11, 2022 at 4:01 PM
    ARNIE R
    Arnold
    Leesburg, VA
    Only 150-200 lbs max. Did some more testing today. At fully warmed up idle, it is mostly quiet. As soon as I push the revs up past 1K, it starts getting louder. When driving, you can hear it change pitch as it shifts thru the gears.
    Made an appointment with the dealer for Monday morning. I’ll let them deal with it since it is still under warranty……I’m getting too old for dealing with this kinda thing myself.
    OldTacoDD and will.i.was[QUOTED] like this.
  16. Feb 11, 2022 at 4:06 PM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    Yeah it is lol I've had a similar chirping due to cb but can't really guess too accurately without hearing it
    Gotcha hopefully it's resolved soon!
  17. Feb 11, 2022 at 8:14 PM
    OldTacoDD
    PNW
    2002 3.4L V6 SR5
    You paid for the warranty, good time to use it. Will be interesting to see what they say, hope you give an update when that happens.
  18. Feb 14, 2022 at 12:42 PM
    Lenny Dykstradamus
    Lenny Dykstradamus Well-Known Member
    Lenny
    New York City
    Tacoma Warthog
    It is called angry sparrows if when moving and in that case would be failing universal joints
  19. Feb 14, 2022 at 12:57 PM
    ARNIE R
    Arnold
    Leesburg, VA
    As I suspected, the dealership stated that they did not hear anything so they could not confirm my issue.
    Being only in the mid 30’s today, I figured that would be their response.
    I specifically advised them that the chirping starts after the engine is totally warmed up and the ambient temperature at which it starts is about 45-50 degrees plus, so they would have to make sure the truck was inside their nice warm work bay to be tested. Plus, the RPMs had to be about 1100 and above.
    Claimed they did so and still nothing.
    Told me to “bring it in to any Toyota dealership” as soon as it starts up again so someone can come out at that moment to hear it. Ha-ha - good luck on that happening at a convenient time and place.
    So, I have to wait til the next warm days……..ain’t life fun.
  20. Feb 14, 2022 at 1:11 PM
    jgr81
    jgr81 Well-Known Member
    Jen
    Summit County CO
    16 Tacoma TRD OR Access Cab, 03 4runner v8
    I had the same issue, it was the high pressure fuel pump... and like you just mentioned the engine needs to be good and warm for it to happen. I had to go to the dealer for a separate issue and mentioned the chirping, the guy knew right away what it was. It was replaced under warranty.
    I noticed ambient temp didn't matter as much, it was definitely noisier in the hot summer but an hour drive from my house in the mountains in CO to the dealer in Denver at the end of December (below freezing for sure) was enough to get it going. Mine was noisy at idle inside the service bay so it wasn't RPM dependent for me. Just go on a nice long drive until you hear it before you try to go in if you can
