Chinese replacment grills
Discussion in '1st Gen. Tacomas (1995-2004)' started by agalloch07, Oct 9, 2021.
  1. Oct 9, 2021 at 1:08 PM
    agalloch07
    agalloch07 [OP] Well-Known Member
    The entire grill on my 2002 Tacoma needs replaced not just the center section. Do the Chinese replacements sold on ebay fit good enough? This truck is a beater so it dont need to be 100% perfect. But i have bought chinese parts in the past and they fit so poorly in some way i wish i hadn't went Chinese. This is the one i am looking at it's half the price of the toyota one. https://www.ebay.com/itm/174003936124?ssPageName=STRK:MEBIDX:IT
  2. Oct 9, 2021 at 3:10 PM
    agalloch07
    Anyone? OEM Toyota one is about $100 more than a Chinese. But this truck is a beater with 300k on it so I'm trying to keep it cheap.
  3. Oct 9, 2021 at 3:23 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    First off it's eBay:facepalm:
    Grill has 0 reviews, 0 ratings.
    Roll the dice to be the first :spending:
    The cheap counterfeit knock off are extremely flimsy and lightweight.
    If it arrives unbroken :fingerscrossed:
  4. Oct 9, 2021 at 3:30 PM
    agalloch07
    The factory grill was flimsy and light weight so idk if it could get any worse. It ended up getting broken while i was replacing the radiator. Those stupid clips that attach it are the cheapest shit i have ever seen in my life. I would just leave the grill off but i want it to look somewhat respectable.
  5. Oct 9, 2021 at 3:43 PM
    Black DOG Lila
    Virginia
    The factory grill is Extra Heavy Duty compared to EXTREMELY FLYMSY eBay counterfeit.
    Kwikvette and Nessal like this.
  6. Oct 9, 2021 at 4:30 PM
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    I use black zip-ties to hold my grille on...They last a good while! I broke a few while putting the grille back in after a trans cooler install.
  7. Oct 9, 2021 at 4:37 PM
    agalloch07
    I was trying to line all of the factory clips up while reinstalling. But the clips were sliding and the other end while i was fighting with the opposite end. So by the time i got down to the other clips were not where they should have been. I tried pulling it back and busted it and just ended up grabbing it and ripping the whole damn thing off. I am disappointed in the quality of how that thing is held on. I have installed a lot of radiators and this was by far the worst one i have ever done. I think i will just order the china one and attach it with zip ties. It will look better than not running a grill at all.
  8. Oct 9, 2021 at 4:40 PM
    agalloch07
  9. Oct 10, 2021 at 12:57 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I purchased a cheap eBay grill for my '96 Tacoma 4x4. The first had a broken mounting tab straight out of the box. Sent it back for another, tried to install it and mounting screw retainers would not line up correctly and grill was loose. That was enough aggravation so sent it back and ordered an OEM and it arrived perfect and fit perfect. Do yourself a favor and go with the OEM.
  10. Oct 10, 2021 at 1:21 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You take chances buying cheap stuff on ebay.
    With that said, I bought one on Ebay for mine some years back without issue.
    Clipped in just fine, all holes matching.
    I even bought a cheap knock-off for my 4Runner and it even came with new clips to attach to the radiator support.
    The old grill with new, knock-off side markers -
    The grill some thousands of miles already on the truck -
    I'd post better pics but I never bothered with any "frontal" shots.
    Here's the 4Runner factory grill and the knock-off -
    Factory emblem went right on -
    And again, the only close-up of the front some thousands of miles later. Still holding up fine and aligned like the factory grill was -
    Das it mang likes this.
  11. Oct 10, 2021 at 7:16 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    My replacement from RockAuto was like 40 bucks and was perfect
