Chevy Colorado Destroys Frame While Towing
Discussion in 'Towing' started by ripcalifornia, Jun 21, 2019.
  1. Jun 21, 2019 at 9:21 AM
    ripcalifornia
    ripcalifornia [OP] Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    And we thought the Tacoma frames were bad...
    Saw this on FB, thought I’d share
    79DB2B94-7E27-464B-819B-5DEBD1B18ED0.jpg 6B4C7D2A-5474-48F7-9BEF-68E6450E5940.jpg
  2. Jun 21, 2019 at 7:16 PM
    Indy
    Indy Master of all I survey.
    That reads like 1 sentence taken out of a 10 page report. Much like a facebook video that shows the last 10 seconds of a 10 minute encounter to make the bad person look good.
    Much as you can't actually see the trailer. While it may be #2100, there's no way to see that it's not loaded with an extra #10k.
    *************edit**************************
    Allow me to enter an edit here. From the picture you can see it's a 'ruger' trailer. The only small model of which weighs completely dry (drumroll here) 2900 pounds. And that's if the GVWR they advertise was actually correct, since so many times they show quite a bit lighter than they actually are. Couple that with the additional hardware you can see bolted onto the trailer itself, go cruising down some roads with some dips and whoops at an excessive speed and physics has its way with you.
    Sooooooo, I'm calling BS on the rest of the complaint as well. I'd assume the picture is cropped specifically so you can't see the load, and assume he was substantially overloaded and blaming Chevy for his own actions.
    That's 30 seconds work sitting in front of the tv, imagine what I could find if I was actually on site investigating.
    https://www.rugertrailers.com/specs
  3. Jun 22, 2019 at 8:02 PM
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
  4. Jun 22, 2019 at 9:11 PM
    Indy
    Yep, called it :laugh: 3500lb axle bent like a rainbow, that definitely says 1" taller tire caused the problem. Back when I was a cop people often asked why we treated everyone like they were lying to us. It's because everyone always lies to us. Fb makes it so everyone can always lie to everyone. Only everyone treats everything on Fb like its true.
    MrCball likes this.
  5. Jun 22, 2019 at 9:28 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Not disagreeing with any of the above but it does look like a weak spot in the frame though. It kinked right where the oval hole is. I'd keep an open mind and see if the problem is repeated.
  6. Jun 22, 2019 at 9:36 PM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    The actual report from GM reads:
    It is believed that the Colarado hit the trail bump in excess of approxiamtely 50 MPH which caused a large (casotraphic) negative moment about the last 1/3 of the frame, and because of the load fixed at the tongue, the 4x.1/3 framing failed.
    When asked why the customer reached these speeds, with a 2500lb trailer in tow on the trail, he responded,
    "Because Multimatic BRO!"
    Warranty claim denied.
    End report.
  7. Jun 23, 2019 at 7:03 AM
    Indy
    Theres about a million of them on the road, I think if 100lb overload was a problem we would have heard about it by now. If I hit a tree at 100mph and suffer damage, it's probably not due to a weak spot in the frame.
  8. Jun 23, 2019 at 7:12 AM
    FJRrider
    FJRrider Well-Known Member
    Pacific Northwest
    2012 DCSB
    Someday...
  9. Jun 23, 2019 at 10:26 AM
    mgmdclb
    mgmdclb Well-Known Member
    The Maritimes, Canada
    2018 MGM DCLB Sport
    Just seen another one on FB
  10. Jun 23, 2019 at 10:49 AM
    stealthmode
    Alberta
    Apparently that frame is seriously under designed by the looks if it. Based on the first pick anyways
    100 bux says some kind of stiffening plate magically finds it's way to the frame in that spot in 2020-21.
    Notice the bend is exactly at the point where the shocks are fixed.
  11. Jun 23, 2019 at 11:01 AM
    Indy
    Working as designed isn't under designed. That's pretty much the reason everything had a rating. Exceed it and your up a creek.
    TacoManOne likes this.
  12. Jun 23, 2019 at 1:13 PM
    stealthmode
    Alberta
    What I think your talking about is safety factors because we cant think of every for seable circumstance so provide ratings to save our butts. And IMO this frame was designed to the nuts. Cheap as possible material design and min gauge steel or lack or high strength steel in critical points.
    Of course user error could be to blame but "durability" has alot to do with over designing- vs "working as designed". Next time you go in an elevator with 11 people and the tag calls for 10 people you can rest assured it won't fail because of this :p
  13. Jun 23, 2019 at 1:21 PM
    BlackGT99
    BlackGT99 Well-Known Member
    Noel
    2019 VooDoo Blue Tacoma TRD Pro
    Designed and engineered for owners to stay within towing and payload capacities lol
  14. Jun 23, 2019 at 3:16 PM
    stealthmode
    Alberta
    Seriously right??
    "Professional drivers on enclosed course" better maybe? :D
    Nunya Bizness likes this.
  15. Jun 23, 2019 at 3:18 PM
    Nunya Bizness
    Dayum...
    Now i dont feel so bad about my clunky Ujoint... cuz thats my only issue... easy fix.
    This would make me throw some stuff...
  16. Jun 23, 2019 at 5:35 PM
    ripcalifornia
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    Exactly, the taco may be slow but at least my frame don’t bend
    Nunya Bizness[QUOTED] likes this.
  17. Jun 23, 2019 at 10:00 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    The number that go offroad is quite a bit smaller, offroad with a trailer, smaller still, stupid fast to boot even smaller. Speed was definitely a factor but the frame bent there not somewhere else so that was either the weak point or the focal point for the stress. It's not as if auto makers have a perfect track record. And if there's a weakness anywhere, the over enthusiast will find it. Not saying it's defective, people break stuff by exceeding limits, apparently this is how you break this Chevy.
    Tullie D likes this.
  18. Jun 24, 2019 at 9:08 AM
    jbezorg
    jbezorg Well-Known Member
    Greg
    Gaithersburg MD
    2018 Tacoma AC TRD Off Road
    MrCball likes this.
  19. Jun 24, 2019 at 8:40 PM
    Indy
    I had my brand new f250 out last weekend, packed it with explosives, drove it off the edge of the grand Canyon at 120mph. $80k and now it won't even start. And ford is denying my warranty claim because I didn't wax it like I was supposed to. What a POS, thanks for nothing ford.
    tgarza74 and TacoManOne like this.
  20. Jun 25, 2019 at 4:08 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Apparently it's a thing with Raptor frames as well, and not due to trailer towing, just stuff Ford shows in comercials.
