checking oil when stone cold- after sitting for days/overnight VS the 5 minutes indicated in manual
Discussion in '3rd Gen. Tacomas (2016-2023)' started by silverflash, Jul 10, 2019.
  1. Jul 10, 2019 at 7:08 AM
    silverflash
    silverflash [OP] Well-Known Member
    Bill
    Harnett county NC
    2019 TRD 4x4 OFFROAD DCSB Auto Quicksand
    tyger armor side bars tyger tri-fold tonneau cover avs bug deflector II scangauge II
    So i have a question regarding checking the oil in the V6.
    i know, there are other threads but this is more specific.
    i know that you can't pull the stick, then re-insert then check that way as per the manual, due to capillary action skewing the reading. I have tried and it's frustratingly difficult to get a good reading. That is how i have always done my other cars and it's always worked. I have done hundred of oil changes in my life on many different brands- except toyota.
    i checked it the past couple times in the morning before i start it after it's sat a couple days and it seems to be a clean read. I am right below the high dimple on the stick and the stick above is perfectly clean of any oil. If i re-insert, then there are oil strands all over the stick.
    I recently did the 1st oil change, adding 6 quarts after draining all the old out and changing filter. I did not add oil to the filter before re-installing like i normally do on my other cars.
    SO how accurate is the check after it's sat all night and also if you check it after the first pull? I have seen some say to pull the stick after the 5 minutes, and set it someplace for an hour, then come back and check then. That seems really overly complicated. why not just check it 1st thing in the morning?
    thoughts?
  2. Jul 10, 2019 at 7:19 AM
    silverflash
    Bill
    Harnett county NC
  3. Jul 10, 2019 at 7:33 AM
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    My thought is you're way over-thinking this.;)
    Pull it, wipe it, stick it back in, pull it, and read it. Make sure you're between the dots and you're good! :thumbsup:
    The only reason you need to crank up the engine after a change is to make sure oil's flowed into the filter. You would otherwise have a slightly higher than actual read.
    Garyji and rnish like this.
  4. Jul 10, 2019 at 8:17 AM
    silverflash
    Bill
    Harnett county NC
    i will have to disagree. every time i pull it, wipe it, put back in, pull it back out and check, the oil is all over the place. on both sides. it may be that the true level is more filled in but it's hard to see. i have gotten into the habit now of just checking when stone cold by just pulling and checking it then. I checked this morning and perfect. Last time ic hecked, i did the same stone cold one pull check. I did re-insert and check again for giggles, and there was oil about 2x the length of the "safe" zone. that's from oil getting on the inside of the tube when you re-insert and hitching a ride back up on the next check i believe.
    in all my years, i have NEVER had this problem. I will chalk it up to a tacoma characteristic.
    LOL.
  5. Jul 10, 2019 at 8:24 AM
    Chiloquin_Car_Care
    Chiloquin_Car_Care homie dont play that
    Oregona
    2021 voodooblue DCSB 4x4 3.5l v6
    nada....maybe a license plate one day & BA bumpers
    you will think I am nuts (& I will likely get a bunch of off the wall responses to this), but here goes-
    I have never checked my dipstick once in 6.5 years/321k miles
    why?- I change my oil every month as I drive 5k miles per month (& perform oil changes every 5k miles, along with oil filter/lube 5 zerks)
    I put exactly 5.5qts in & 5-5.25qts comes out (I measure it)
    I never check the dipstick, just put the 5.5qts in & drive the snot out of my taco
    crazy, huh?
    lol
  6. Jul 10, 2019 at 8:27 AM
    silverflash
    Bill
    Harnett county NC
    wow, that's ALOT of miles. KUDOS!
  7. Jul 10, 2019 at 8:28 AM
    mac84
    mac84 Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
    Yes sir...me too!!
  8. Jul 10, 2019 at 8:31 AM
    Chiloquin_Car_Care
    Oregona
    Im attempting to go to 500k....179k to go
    LooneytuneSR5 and Sgt.Tee like this.
  9. Jul 10, 2019 at 8:33 AM
    Chiloquin_Car_Care
    Oregona
    tacoma's are the best
    built to last
    gotta love our trucks
    gen1, gen2, gen3....we love em all
    Sgt.Tee and silverflash[OP] like this.
  10. Jul 10, 2019 at 8:46 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have had this problem on other cars. If there is oil up the sides, I discount that and just consider the level where it is completely across the dipstick. In then end, we have a generous safe zone between the marks. About one quart. I personally like it near the top mark, but we are good to go if the stick is wet.
    Like you, I generally check oil levels cold. Just quicker and easier. If the motor is cold and it is at the bottom mark, definitely add some. :D
    Vbpiper, Sgt.Tee and shakerhood like this.
  11. Jul 10, 2019 at 8:47 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I usually let my truck sit overnight before checking too.
    Vbpiper, Sgt.Tee and tonered like this.
  12. Jul 10, 2019 at 9:20 AM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    WRONG!!!
    After you pulled the stick out and set it aside, did you take two steps to the right, one step back, spin around four times, one step to the left and jump up twice? If not, the oil reading will be wrong. I do this every time and oil level is perfect.
    start car for 2-3 min to warm up the oil and move it around.
    drain oil, replace filter.
    add oil per manual indications (6.3qt)
    stop car and check the oil level (between dots is a qt of oil. If in the middle of the dots add 1/2 qt of oil)
    clean around and look for drips.
    drive it.
