Checking Oil Level on the Dipstick
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NewtoTacoma, Oct 25, 2012.
  1. Oct 25, 2012 at 8:23 PM
    NewtoTacoma
    NewtoTacoma [OP] Active Member
    None yet
    I don't want to sound like a dipstick, but how do you guys manage to read the oil level on your dipsticks? On my stick it is very difficule to get a good reading. The oil in th dipstick tube smears on the stick.
    Any help is appreciated.
  2. Oct 25, 2012 at 8:29 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Stop engine, remove dipstick, wait 5 minutes, insert and remove.
    One side or the other will give a decent reading.
    Pulling the stick out smears oil up the tube. Waiting a few minutes gives it a chance to drain down.
    Budbudbuilds and TRDSport10 like this.
  3. Oct 25, 2012 at 8:35 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    When you pull the stick it carries some oil up the tube... best to wait 15 minutes to let the oil drain back down before reinserting to get your reading. Also, etching the area between the high/low marks with sandpaper or a file helps.
    Budbudbuilds, TRDSport10 and gmc8 like this.
  4. Oct 25, 2012 at 8:39 PM
    badger
    badger Well-Known Member
    07 SR5
    I've found the only way to get an accurate measurement on mine is first thing in the morning before I start the engine. After the first pull you will have the same problem with smeared readings. Just make sure the stick is all the way down in the morning, pull and read. I tried sandblasting the end of the stick, and that helped a little, but the dipstick on these things is pretty fucked.
  5. Oct 25, 2012 at 8:47 PM
    Ray
    Ray Well-Known Member
    San Diego
    09 Pre-Runner
    Find the full mark and drill a small hole at the line. Oil level is easy to see in the hole.
    Ray
  6. Oct 26, 2012 at 4:09 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Another option is to file a small "v" notch at the correct point on the dipstick - might be easier than drilling.
  7. Oct 26, 2012 at 10:24 PM
    NewtoTacoma
    None yet
    Thanks for the comments!
  8. Oct 27, 2012 at 8:42 AM
    b2948kevin
    b2948kevin Well-Known Member
    Kevin
    Highland, UT
    2010 Double Cab Long Bed 4x4 TRD Sport Black
    None yet
    I have the same complaint on my 2010 Tacoma and 07 4Runner. You're not the only one.
    Like others have said, you have to wait for everything to settle. This makes checking levels at the gas station between fills impossible, unless you have half hour to kill.
  9. Oct 27, 2012 at 8:52 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    wait until the oil is dirtier?
    i am having no problems..i let the truck sit for awhile. it is difficult when the oil is super fresh and clean.
    kidthatsirish and Lester Lugnut like this.
  10. Oct 27, 2012 at 2:21 PM
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    I prefer to check it after it sits overnite every week or so - allows the dipstick tube to drip back into the pan. Also eyeball radiator overflow tank and windshield washer fluid tank while you're under the hood.
    kidthatsirish and Vansurfing like this.
  11. Oct 27, 2012 at 9:38 PM
    NewtoTacoma
    None yet
    Thanks guys! I am going to go to the let it sit and pull the stick once to get a reading procedure.
    I have always pulled the stick, wipped it, replaced the stick, and pulled it a second time for the reading. But with the Taco they just doesn't work.
  12. Oct 27, 2012 at 9:41 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Not sure what it is... I'd have to drop the pan to confirm my suspicions, but I have a feeling that the dipstick tube extends down into the sump to guide the dipstick to prevent it from being hit (and wrapping up in) the crank.
    That would explain why it seems that the stick seems to draw an excessive amount of oil up the tube when withdrawn.
    I'd bet that you could suck on the tube and draw oil out of the engine.
  13. Oct 27, 2012 at 9:43 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I find mine difficult to read as well. Gotta check it a few times.
  14. Oct 28, 2012 at 10:34 AM
    b2948kevin
    Kevin
    Highland, UT
    None yet
    Rich, this was exactly what I was thinking. Spot on, sir.
  15. Oct 29, 2012 at 6:34 AM
    BRUCEB
    BRUCEB Well-Known Member
    CENTRAL MISSOURI
    2012 CREW CAB TRD
    The way I do it;check and see what it show's when I first pull it out.Then I spray the dipstick with brake clean;check again.Seams that the brake clean "helps"the oil stick to the stick.This seams to work good for me.
    Taco15Bob likes this.
  16. Aug 20, 2017 at 12:44 PM
    BrookTrout
    BrookTrout Active Member
    Brook
    West Michigan
    If anyone sucks on that tube, I want video!!!
  17. Aug 20, 2017 at 4:49 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The way it is supposed to be done is to pull out the dipstick and wipe it clean with a shop rag. Insert and pull it out a 2nd time to get an accurate reading.
  18. Mar 25, 2019 at 3:12 PM
    Taco15Bob
    Taco15Bob Member
    Bob
    2015 S5 4 door Prerunner
    None
    I Googled "2015 Toyota Tacoma oil check" and got here. So it's not just me. Been checking oil for 60+ yrs and have never had as
    much trouble with checking the oil on my 2015 Tacoma, so glad it's not dementia setting in. Will try suggestions. Thanks.
    Baja Barry likes this.
  19. Mar 25, 2019 at 7:30 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I must be lucky. The oil level on my '15 Tacoma is easier to read than my '14 4R or my '06 Avalon.
  20. Mar 25, 2019 at 7:37 PM
    racerX969
    racerX969 Active Member
    Your spose to check it ? I just change mine every 6 to 7 thousand miles.
