Checking coolant with multimeter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jsnm23, Jul 28, 2016.
  1. Jul 28, 2016 at 1:08 PM
    jsnm23
    jsnm23 [OP] There are no solutions; only tradeoffs.
    2011 mgm TRD OR 4x4
    5100s @1.65 MB 352 wheels Debadged Cb radio Bhlm
    Ok, so I saw a YouTube video showing how to check your coolant with a multimeter. Person in video says if your coolant reads below .03 on the 20 volt DC setting your coolant is good. I decided to give it a try. Mine reads .25 . Anyone ever try this with the Toyota coolant? I'm wondering if there's an additive in it that would make it read so high.
    I've been draining the radiator and filling it up with new Toyota coolant every 20-30k. Not a complete flush but I figure adding new coolant every so often will keep it somewhat fresh. Is this a bad idea?
  2. Jul 28, 2016 at 1:46 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Never used a meter but I do drain the radiator and fill every 30k. I'm sure Toyota says it's lifetime but I'd like to stretch the lifetime.
  3. Jul 28, 2016 at 1:55 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    I believe it's actually 0.4 or less is good.
  4. Jul 28, 2016 at 2:00 PM
    Clearwater Bill
    Billy
    Largo Florida
    As @4Running Daily suggests, the correct target is .4
    Your .25 is just fine.
  5. Jul 28, 2016 at 3:46 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Can't resist, same number on blinker fluid?
    o0oSHADOWo0o likes this.
  6. Jul 28, 2016 at 3:57 PM
    Clearwater Bill
    Billy
    Largo Florida
    No, there is requirement for conductivity to support the blinker circuit. Doh! So the number needs to be much higher! :D
    ecgreen likes this.
  7. Jul 28, 2016 at 6:01 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    You are really overcomplicating this. If a five dollar parts store hygrometer says the coolant is okay it's okay. Leave it alone.
  8. Jul 28, 2016 at 6:33 PM
    jsnm23
    2011 mgm TRD OR 4x4
    In don't have a 5 dollar parts store hydrometer but I did have a multimeter on hand and went that route.
    I'm pretty sure the magic number should be .04 or under not .4
  9. Jul 28, 2016 at 6:36 PM
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
    If it ain't low leave it alone, forever.
    CusterFan likes this.
  10. Jul 28, 2016 at 6:47 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
  11. Jul 28, 2016 at 6:57 PM
    Bishop84
    Bishop84 Well-Known Member
    It's over analyzing a simple liquid. If it's been changed regularly then its ok. I've never seen anyone test coolant for voltage except in rare cases to confirm the coolant is causing failure. But its 20$ a jug, if you're worried, dump it. It's premixed and the days of overstrong coolant are past us.
    The acidity in the oil is more of a concern for me than the acidity in the coolant. It just happens that you can actually measure the coolant.
    TRDSport10 likes this.
  12. Jul 28, 2016 at 7:06 PM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    How do you use a multimeter set to DC voltage to test your coolant? Where do you stick the test leads, one to the pos terminal and stick the other one in the radiator? I can't think of how this test would be reliable.
  13. Jul 28, 2016 at 7:09 PM
    Bishop84
    If coolant is left in an engine system for too long, it can build up acidity similar to how a flooded battery works. It will build voltage and eat gaskets and metal. It's one of the reasons for changer intervals with coolant.
  14. Jul 28, 2016 at 7:14 PM
    3coma
    rob
    I can see the coolant gradually having more metal content therefore being more conductive. I just don't see how it can generate voltage on it's own.
  15. Jul 28, 2016 at 7:17 PM
    Clearwater Bill
    Billy
    Largo Florida
  16. Jul 28, 2016 at 7:18 PM
    Clearwater Bill
    Billy
    Largo Florida
  17. Jul 28, 2016 at 7:28 PM
    3coma
    rob
    Lester Lugnut likes this.
  18. Jul 28, 2016 at 7:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    I have a Fluke. :p
    The only cheap tools I buy are one time or very infrequent use items that I don't really care if they break, and if it doesn't work right won't get me killed. :D
  19. Jul 28, 2016 at 7:39 PM
    3coma
    rob
    So do I :cheers:. I've been a calibration tech/semiconductor equipment mechanic for a long time. Sticking a test lead into a liquid just does not scream accurate to me.
    Usethe2nd likes this.
  20. Jul 28, 2016 at 7:51 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    I've been turning wrenches and I am ASE certified. Never once have I heard of this.
