Checking codes without a scan tool
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NelsonTacoma, Sep 8, 2012.
  1. Sep 8, 2012 at 12:01 PM
    NelsonTacoma
    NelsonTacoma [OP] This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    So I did a search and came up with nothing. My check engine light came on today and I don't have my scan tool handy (it's at work for obvious reasons) and I was wondering if anyone knew how to check the codes without a scan tool. I know on the older models pre OBDI & II you could jumper 2 pins on the diagnostic port and the light would flash the codes (similar to ABS/Air bag stuff).
    I tried looking it up on Mitchell on demand on the internet but came up with nothing. I'm too impatient to wait till Monday and don't want to go to Vatozone or O'riellys either. Any help would be appreciated!!!
  2. Sep 8, 2012 at 1:23 PM
    NelsonTacoma
    Tucson, AZ
    Lots of views. But no one knows? Must not be possible. Come on TW show me what you got!!
  3. Sep 8, 2012 at 1:28 PM
    NelsonTacoma
    Tucson, AZ
    Yeah that's what I was thinking. I was hoping someone knew. :(. Just glad it's not flashing.
  4. Sep 8, 2012 at 1:35 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    OBD-1 you could do it because they were only 2-digit codes.
    OBD-2 went to 4-digit codes with an alpha thrown in to differentiate between the engine, body, ABS, and transmission controllers (and hand-held tools STILL don't properly read all of the body and trans codes).
    Just hop over to O'Rielly or Autozone and borrow their scantool.
  5. Sep 8, 2012 at 8:36 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Auto parts stores are open on Sunday here...
  6. Sep 8, 2012 at 8:45 PM
    NelsonTacoma
    Tucson, AZ
    I know how the codes work. But I also know you can read ABS & Air bag codes without a scan tool, by jumpering a wire in the DLC was hoping that you could read PCM codes that way too. But it seems you can't.
    I have a Snap-On Solus scan tool at work I can use. I was just hoping to get a jump start on what the problem is.
    I hate going to auto parts stores. Plus I'm not going to buy any parts from them so I don't feel right borrowing their stuff.
    If I have to put any parts on my truck I will order them from my work (we are also a Lexus dealer) so I get the parts at cost +10%.:D
  7. Nov 4, 2023 at 12:19 PM
    Budman0204
    Budman0204 Active Member
    Gary
    2004 Prerunner
    None
  8. Nov 4, 2023 at 9:31 PM
    Waasheem
    Waasheem
    2007 xrunner
    Sorry, I don’t know of a way.
    You could try a regional forum to see if someone will help.
    Envious, dang expensive piece.
  9. Nov 4, 2023 at 9:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    OP posted this 12 years ago.
    The guy above your post pulled it back up.
    I don’t know what 4 & 13 means?
