Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Jan 5, 2016 at 3:32 PM
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Just greased mine at 1,300 miles; they were bone dry.
    3 zerks in the rear took 6-7 pumps to purge
    2 zerks in the front took 2-3 pumps to purge
    I used plain old Valvoline multi-purpose; it's what I could find local that meets the Toyota and Spicer spec.
    EDIT: 1
    This applies to 4wd only.
    2wd are sealed and not greaseable.
    EDIT N0. 2:
    As of June/July 2016, all 4x4s shipped with non-greasable rear driveshafts. The front driveshaft is still greasable.
    EDIT NO. 3:
    Link to replacement u-joint thread
    https://www.tacomaworld.com/threads...e-2016-and-2017-tacomas.521461/#post-16543852
    EDIT NO. 4:
    Link to Dana/Spicer replacement u-joints;
    https://www.danaaftermarket.com/aut...=331&from=0&y=2016&mk=Toyota&md=Tacoma&sort=1
    FRONT TO REAR
    note-front driveshaft will rotate by hand for easier access
    Zerk #1-front driveshaft
    Zerk #2-front driveshaft(remove cover with 12 mm socket)
    -with cover
    -without cover
    -opposite view
    Zerk #3-rear driveshaft
    Zerk #4-rear driveshaft
    Zerk #5-rear driveshaft
    EDIT NO. 5
  2. Jan 5, 2016 at 3:42 PM
    jmatteau
    jmatteau Well-Known Member
    Is there a diagram somewhere where all the zerks are at, and does anybody know how many total there are?
    ToyoVL, Arrampico and trabo like this.
  3. Jan 5, 2016 at 3:45 PM
    splitbolt
    NW Arkansas
    Depends what truck you have.
    Mine's a no-brainer.
    vbibi likes this.
  4. Jan 5, 2016 at 4:03 PM
    usadaytrader
    usadaytrader Well-Known Member
    Would be great post with photos.
    Miller1103, TRDSport10 and Yankeetaco like this.
  5. Jan 5, 2016 at 4:51 PM
    splitbolt
    NW Arkansas
    :thumbsup:
    This applies to shortbed Offroad.
    FRONT TO REAR
    -with cover
    -without cover
    -opposite view
  6. Jan 5, 2016 at 4:55 PM
    rottenpixies
    rottenpixies Well-Known Member
    New York
    2015 DCLB 4X4
    Been meaning to do this... I've seen people here mentioning it.
  7. Jan 5, 2016 at 4:59 PM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    Thanks for posting.
    Do you think U-Joints are part of the 5000 mile inspection/servicing?
  8. Jan 5, 2016 at 5:03 PM
    splitbolt
    NW Arkansas
    It's required maintenance under special conditions.
    Toyotacare does not cover special conditions.
    Mine were bone-dry; the only grease I purged was what I put in.
    The zerks have black paint that has not been disturbed by having a grease nozzle put on them.
    Do not wait for 5,000 miles.
  9. Jan 5, 2016 at 5:04 PM
    vuTron
    SF Bay Area
    ok, thanks for posting
    Dannyblues likes this.
  10. Jan 5, 2016 at 5:08 PM
    tyler2009
    tyler2009 Well-Known Member
    Tyler
    NE Ohio
    2009 DCSB TRD Sport
    None
    Wow that's what a truck looks like without rust. You should see my 09' I just bought.
  11. Jan 5, 2016 at 5:22 PM
    Eric NJ
    Eric NJ Well-Known Member
    New Jersey
    So what you are saying is that the trucks are rolling off the line without being greased??
  12. Jan 5, 2016 at 5:22 PM
    Frank_Zuccarini
    Frank_Zuccarini Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    REALLY good to know, Splitbolt. Thanks so much for letting us know.....................
    Frank
    Arrampico and Dannyblues like this.
  13. Jan 5, 2016 at 6:00 PM
    splitbolt
    NW Arkansas
    Apparently, mine did.
    Dannyblues and AR15xAR10 like this.
  14. Jan 5, 2016 at 6:15 PM
    busticator
    busticator Well-Known Member
    FL
    2016 Tacoma SR5 DCSB
    CPS rev2
    Sad. Good thing you checked. Something else for me to do. <sigh>
    Dannyblues and 0uTkAsT like this.
  15. Jan 5, 2016 at 6:18 PM
    splitbolt
    NW Arkansas
    I meant to do it a lot sooner.
    Pisses me off...
    Dannyblues, 12TRDTacoma and 0uTkAsT like this.
  16. Jan 5, 2016 at 6:19 PM
    indyspz
    indyspz Member
    Craig
    Hampton Roads Virginia
    2016 Black Taco SR5
    4" lift, XD Series wheels
    How do you know when you've put in enough grease?
    Thanks
    Dannyblues and 16tacoblue like this.
  17. Jan 5, 2016 at 6:20 PM
    Sandtaco
    Sandtaco Well-Known Member
    Henderson NV
    2016 TRD Offroad Access cab
    Going to check mine tomorrow. Thanks
  18. Jan 5, 2016 at 6:30 PM
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    Side (sad?) story:
    I took my '99 4WD Tacoma in to get the wheels re-balanced and specifically asked the shop to grease the driveline zerks for me (I haven't done it in years). The shop mechanic's answer was:
    "We don't have a grease gun that can do that. New cars don't come with grease zerks anymore. Your truck is unusual. Sorry."
    What the actual fuck?
    //rant
  19. Jan 5, 2016 at 6:37 PM
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    I would say sorry I don't pay with normal money. Here's a few rocks to compensate your time.
  20. Jan 5, 2016 at 6:40 PM
    splitbolt
    NW Arkansas
    You should see grease come out all 4 seals.
    Since mine were dry, I could also here the air escaping as it neared capacity.
    If you can't get it to purge out all 4, you may need to lift up on the shaft, or bang on the ears with a brass hammer to unbind.
    If you still can't get it to purge, something is screwed; Spicer recommends disassembly/inspection/replacement.
    robssol, kairojya, Biscuits and 11 others like this.
