Check your drum brakes!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lentsnh, Dec 30, 2009.
  1. Dec 30, 2009 at 10:14 PM
    Lentsnh
    Lentsnh [OP] Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    I noticed I had alot of play in the brake pedal yesterday. Today I took it to the Toyota dealership (they had a good deal going on). And I was told that I had about 20% on my drum brakes and that they were way out of their adjustment and I was using purely my front brakes to stop.. Thank goodness I was starting to downshift during that time.
    I just had my brakes done at 76,xxx miles and currently I'm at 84,xxx.
    I have hit my ABS a few times.. when I went mudding (06BLUEDBLSPORT remembers ;)) and the guy at Toyota said that could be a sign of why my brakes were out of whack. This was all done for free by the dealership... To good to be true. Well it was true! :)
    But Just a reminder, ALWAYS keep an eye out for your drum brakes. As they do wear more quickly than the front.
  2. Dec 30, 2009 at 10:23 PM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    im at 50k just did my fronts at 45k havent checked the back yet.
  3. Dec 30, 2009 at 10:26 PM
    Lentsnh
    if you notice alot of looseness in the pedal... might want to get them checked;)
  4. Dec 30, 2009 at 10:39 PM
    Lentsnh
    The pads are alot softer and are smaller than the fronts.. The fronts will go for about 100,000 miles.
  5. Dec 30, 2009 at 10:49 PM
    Lentsnh
    They do most of the ABS system. thats what made mine wear down so fast.. the adjusters were skewed.
  6. Dec 31, 2009 at 6:17 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I only use 1 set of rear shoes per 2 sets of front pads. Been like this on all my vehicles.
  7. Dec 31, 2009 at 6:19 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    No....fronts before rears.
    If the drums are wearing out faster, then there's something else wrong.
  8. Dec 31, 2009 at 6:20 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    x2 I have never had rears go out before fronts. Got new front pads at 70,000 rears were still gtg
  9. Dec 31, 2009 at 6:22 AM
    Janster
    Jandy
    Lancaster, PA
    After you went mudding, did you bother to take the drums off and clean in there?
    Mud is BAD on drum brakes and can get in there and prevent things from working properly, including the adjusters.
    Also, check your ebrake cable system. If you use the ebrake and the cable gets hungup (on mud?) and can't spring back - the shoes could possibly be dragging.
  10. Dec 31, 2009 at 6:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2
  11. Dec 31, 2009 at 6:29 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    not sure if its still true, but you readjust the rears by backing up. When u apply the brakes it will adjust the rear.
    Weight shifts to the front , thats where the stop power is on any vehic or bike, which is why they can do drums in the rear if the disc power isnt needed(normally)
    Dealers....well they may tell u anything that guides you to work($$ ) for them
  12. Dec 31, 2009 at 6:32 AM
    TIM GAINOUS
    TIM GAINOUS Well-Known Member
    tallahassee fl
    o7 base desert sand
    tints,venvisors,low pro toolbox, readylift sst ,afe pro dry,dynomax muffler,sec air filter removed. jvc aresenal, with rear jvc 6x9's front blaupunkts.
    Yup. Use your parking brakes!!!!!! (adjusts your rears)
  13. Dec 31, 2009 at 6:33 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2 sets of fronts to 1 set of rears is pretty normal. You definately have something else going wrong there.
  14. Dec 31, 2009 at 6:43 AM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    I would agree with this.
  15. Dec 31, 2009 at 6:44 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Everyone else said it- If your rears are going faster than you fronts...Something else is up.
  16. Dec 31, 2009 at 6:44 AM
    jonny
    jonny Betty White Edition Heep ZJ
    you sure about that?
  17. Dec 31, 2009 at 6:49 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
    why did they do it for free? is your truck still under waranty ?
  18. Dec 31, 2009 at 6:50 AM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I just had my Tacoma's state inspection renewed last week. They check the brakes as part of the inspection. My guy told me I had probably over 75% left on the front brakes and over 85% left on the rear. And I'm at 43K miles.
  19. Dec 31, 2009 at 6:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For those folks that want to check their own, make sure there is over 5mm of friction material left on the shoes.
  20. Dec 31, 2009 at 6:51 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    My shop checked my brakes when he did my winter rim swap & said the rears looked brand new (40k), but my fronts needed to get done in the Spring.
    He said the winter/salt plays havoc with the front discs setups. Is this true? whats true?
