Check vehicle stability control system
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pkimball3, Dec 19, 2022.
  1. Dec 19, 2022 at 3:28 PM
    pkimball3
    pkimball3 [OP] Member
    Paul
    2017 tan Tacoma trd
    Stock
    I have a 2017 Tacoma trd and my battery went dead, I put my charger on the battery and charged it, after starting the truck it said check vehicle stability control system and the traction control light is on, run my scanner on it and the only code is steering angle sensor internal circuit, anyone have a fix for this?
  2. Dec 19, 2022 at 3:37 PM
    Bishop84
    Bishop84 Well-Known Member
    For some reason the steering angle sensor's fail when batteries are dying, I've seen this a few times and nothing works except replacing the sensor.
    That said, start with a VSC Zero point if your scan tool can perform operations.
    If not, read up.
    https://www.tacomaworld.com/threads/zero-point-calibration-3rd-gen.597187/
  3. Dec 19, 2022 at 3:44 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    also give it some time. these trucks do weird things when they die
  4. Dec 19, 2022 at 4:03 PM
    pkimball3
    Paul
    2017 tan Tacoma trd
    Stock
    I e tried the paper clip trick and clearing the abs code with no luck
  5. Dec 19, 2022 at 4:03 PM
    pkimball3
    Paul
    2017 tan Tacoma trd
    Stock
    It’s been two weeks so far and nothing has changed
  6. Jul 5, 2023 at 5:17 PM
    protaz
    protaz Member
    David
    vancouver CANADA
    17 tacoma 3 inch toytec lift with 33smuders
    aftermarket head lights aftermarket tail lights billet grille 3 inch suspension lift MTX speakers
    Has anyone found a solution to this? Is replacing the sensor a viable fix to this error code?
  7. Jul 5, 2023 at 5:18 PM
    protaz
    protaz Member
    David
    vancouver CANADA
    Any luck with this?
  8. Jul 5, 2023 at 7:04 PM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga STRONG Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Having a tech like you here is second to none. First hand experience. And with that, I won’t be pushing my luck on the battery. :hattip:
    10/11/17 I reckon it’s time. I’ve read about you folks going with an agm. But with the amount of time this battery gave, I figure why fix what ain’t broke.
  9. Jul 5, 2023 at 7:06 PM
    Bishop84
    I usually change around 5 years as well, I'm currently on year 4 of my personal battery and its sweating battery acid, so I'm tempted to go AGM as well, but who knows what 2024 will have for me haha.
    Topanga Taco[QUOTED] likes this.
  10. Jul 5, 2023 at 7:18 PM
    Topanga Taco
    Rick
    There it is. No wonder there was buildup under the battery holder where the metal was bare. In two areas, both had either the paint stripped by the chemical reaction, or the holder was poorly painted. Looks like an AGM is in the works. Didn’t know about battery sweating. I better fully read up on the agm’s.
  11. Aug 26, 2023 at 11:32 AM
    protaz
    protaz Member
    David
    vancouver CANADA
    Update I replaced my SAS with the cheap eBay one light immediately went away . Now Having issues with VSC light flickering on curvy roads thinking the cheap eBay sensor is 70$ for a reason.
  12. Nov 10, 2023 at 4:11 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Any tips on replacing the sensor? I had drained my 2 yr old agm I guess with my frig and sitting over the weekend. Took it in to a local shop and requested them to try reset/calibrate or confirm a bad sensor and they did so I’ll be buying a sensor, doing the install and take it to the local shop to recalibrate.
  13. Nov 10, 2023 at 4:28 PM
    protaz
    protaz Member
    David
    vancouver CANADA
    Once they are fried they there’s nothing you can do, a zero point dosent do anything to steering angle only the yaw and accel sensor get zeroed out the steering angle is self calibrating every time the truck is turned on
    unfortunately oem sensors come with the clock spring so it’s a pricey sensor to buy doing the work requires airbag removal in the steering wheel .
  14. Nov 10, 2023 at 4:53 PM
    baldbeardedtaco
    FL
    I wanted confirmation before buying the sensor and I was suggested to unplug the clock spring and sensor connectors. It didn’t hurt to try and I was able to do it by just taking the lower steering column plastic off. Don’t have a scanner or equipment to do the calibration so took it to a local shop to test
    was asking him for any tips on replacement since he’s done a few and it’s what he does- there’s always tips and tricks of the trade.
    I did not know that the oem part was sensor and clock spring assembly, it makes more since at the 300-350$ “discounted”price
  15. Nov 10, 2023 at 6:18 PM
    protaz
    protaz Member
    David
    vancouver CANADA
    I am a mechanic , and recently went thru hell figuring out my SAS issue so I’m just trying to save you time and money ,
    the steering angle sensor is attached the clock spring it’s snaps on to it there’s no way to do it without removing the airbag and steering wheel , Toyota does not sell the sas separately, DO NOT BUY a aftermarket sensor on eBay they don’t work properly the main tip here is disconnect battery prior to doing this work wait 5min after disconnecting battery before you remove the orange and black tab on the steering wheel air bag .
  16. Nov 10, 2023 at 6:19 PM
    protaz
    protaz Member
    David
    vancouver CANADA
    I am a mechanic ,and I recently went thru hell figuring out a SAS issue so I’m just trying to save you time and money ,
    the steering angle sensor is attached to the clock spring it snaps on to it there’s no way to do it without removing the airbag and steering wheel , Toyota does not sell it separate DO NOT BUY a aftermarket sensor on eBay they don’t work properly
    Arrieta578 likes this.
  17. Nov 10, 2023 at 8:35 PM
    baldbeardedtaco
    FL
    I’m looking into the Toyota online parts store- it’s coming up as TOYOTA 8924B-0R020 but it also says steering sensor w LO. Hoping it’s a 1 part for all trims kind of thing and it’s the right one
  18. Nov 10, 2023 at 9:36 PM
    protaz
    protaz Member
    David
    vancouver CANADA
    Best to call dealer and confirm part number they can match with ur vin , I paid 1000$ for mine with clock spring but I’m in Canada things are bit different here with pricing and sometimes even parts aren’t available in Canadian markets
  19. Nov 10, 2023 at 10:01 PM
    baldbeardedtaco
    FL
    1k for just the part? ouch. Msrp is listed at 450ish
  20. Nov 11, 2023 at 1:22 PM
    baldbeardedtaco
    FL
    An update and to correct a wrong. Toyota does in fact sell just the steering angle sensor (standalone w/out clock-spring). Part number, vin verified, was 8924b-0r020 for me
    local dealer had 1 in stock and price matched online parts store- cheapest I could find was 315 plus tax (msrp 460).
    It had a diagram that mentioned using a locking pin, I guess you enter into the clockspring to hold in place. Any tips/tricks removing without?
    *edit* figured it out, the locking pin is basically for if you were to replace only the clockspring and then transfer the steering angle sensor over without changing it’s position. The locking pin is also the white piece already on the new sensor keeping its position (remove once attached to the clockspring).
