Check engine/ Trac off light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jrup2110, Oct 17, 2019.
  1. Oct 17, 2019 at 4:27 PM
    Jrup2110
    Jrup2110 [OP] Member
    Black 2014 Tacoma TRD
    Lund bull bar with LED light bar
    Does anyone have experience with the Chrck engine/ Trac off lights coming on. Mine has been coming on and going off sporadically for about a month until a few days ago, when it decided to stay on. Took it to autozone and had them hook the one scanner to it and the recommendation was to replace the instrument cluster. Which is weird because the codes it read were mostly transmission issues(sensors and what not). I’m just curious if anyone has had the same thing happen,and what the fix was. Obd codes were P0500/P0722/P0771
  2. Apr 12, 2022 at 4:55 PM
    2014BAJA
    2014BAJA New Member
    Eddie
    California
    2014 Tacoma TRD Baja Edition
    Did you ever figure out the problem?
  3. Apr 12, 2022 at 4:58 PM
    Clearwater Bill
    Billy
    Largo Florida
    Loose gas cap is the first check.
    If not loose possibly failed.
    I've had it 3 times on various Toyotas
    Always start simple.
  4. Apr 12, 2022 at 5:17 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What code(s) are you getting?
    Without knowing that anything is a pure guess.
    TnShooter likes this.
  5. Apr 12, 2022 at 5:23 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    All the codes OP posted deal with the transmission and the speed sensor. The speed sensor would be the first thing to check.
  6. Apr 12, 2022 at 6:39 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If I were to guess, I’d say it’s the output shaft speed sensor.
    About all you can do is check resistance unless you have a scope.
    Does your speedometer work?
  7. Apr 13, 2022 at 7:40 PM
    2014BAJA
    2014BAJA New Member
    Eddie
    California
    P0722 I went wheeling and ther were a a lot of sticks and old tree stumps. I think I tripped one of the wires going in to a sensor. Checking tomorrow. Same symptoms, A-teak light on and check engine and won’t shift into OD (5th) in auto
  8. Apr 13, 2022 at 8:05 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea that code is set when no speed signal is detected from the output speed sensor (SP2 on the rear of the transmission housing).
    Since it sounds like you may have pulled a wire off I'd inspect the wiring closely.
  9. Apr 13, 2022 at 8:12 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Old thread...the op was from 2019o_O
