Check engine light w/ the little traction control light came on..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by twistax, Aug 20, 2011.
  1. Aug 20, 2011 at 6:18 AM
    twistax
    twistax [OP] Toyota Freak
    Carlsbad NM
    2017 Tacoma 4x4 Off-Road
    CaliRaised ditch mounts & Side Projecting pods
    Anyone had this before?
  2. Aug 20, 2011 at 6:29 PM
    iowa530
    iowa530 Well-Known Member
    Iowa
    08 Double Cab 4X4, TRD
    Haven't had this in my Tacoma, but I did have it in my 99 Camry. Most anything that throws the check engine light will cause the traction control function to shut off. I think this is because the traction control uses some engine braking/ decreasing rpms, etc... In the case of my Camry, the CEL was caused by a problem with an emission control (circuit malfuction in the charcoal canister). Solve the CEL issue and the trac control light should go off.
  3. Aug 21, 2011 at 4:56 AM
    reg boulette
    reg boulette Well-Known Member
    Got that combination on a rainy day after a lane change. After a couple of starts it went away. Still under warranty, so went to dealer who diagnosed brake light switch at the brake pedal as the problem and replaced it - diagnostics from freeze frame data in ECU.
    Actually think problem was aftermarket trailer wiring and adaptor gone tits up - noticed strange lighting happening with the trailer where previously worked fine. Bit the bullet and bought the official Toyota harness (at the official Toyota price) and no problems since. A lot of different functions run on similar wiring circuits to save manufacturing costs, so one little thing wrong can screw up a lot of others.
  4. Aug 21, 2011 at 5:19 AM
    Tacoma Mike
    Southern Maine
    Engine and abs/trac go hand in hand sharing inputs. So the trac light comes on because it will no longer accept a possible wrong input.
    Reg and iowa are correct and i always suggest like in Reg's case factory trailer harnesses. I take out way to many aftermarket because of those issues.
    Nice to see a site that passes on real world info with the correct conclusion.
  5. Aug 21, 2011 at 5:47 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Mine came on after I sea foamed the engine, I was wondering why the trac light came on with it, then I figured it was because of the previously stated. I knew why my light came on so I just diconected the battery to reset it. But if you have something real, just take it to an auto zone or parts retail store like it and have them check your code if you don't own a code reader. They'll do it for free, cuz they wanna sell you the parts. Let us know what it is.
    AbunaiTaco likes this.
  6. Aug 21, 2011 at 5:48 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Happened a few years ago to me and It was an o2 sensor
  7. Mar 17, 2013 at 7:21 AM
    HighLow
    HighLow Member
    WNY
    2010 Tacoma 4*4
    2" level lift, light bar, offroad lights.
    Check engine and traction control lights on. Its definitely not working. Almost wrecked truck yesterday as I lost control on a snow covered road. I will have to slow down until I get this fixed. Quessing I was carrying too much weight in bed that may have set it off?
  8. Mar 24, 2013 at 5:45 AM
    HighLow
    HighLow Member
    WNY
    2010 Tacoma 4*4
    Seems it was a loose gas cap on mine. Check that first. Light went off after 10 miles. Traction control working now.
  9. Mar 24, 2013 at 6:03 AM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Strange things happen in new vehicles, systems are so interrelated. Case In point but not On a Tacoma. Installing LED 1157 style bulbs in my wife's 09 Hyundai ET caused the ESC and cruise to mal function. Had a TSB for the brake light switch performed and the dealer ordered a new cruise control module. Problem reappeared, a light went on in the dark recesses on my feeble brain that the problem originally appeared after replacing a burned out stop light with the LEDs so I replaced them with incandescents and voila! ESC and cruise are functioning. Who'd a thunk it?
  10. May 7, 2013 at 5:50 AM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    This happened to me today, went back home disconnected the battery, backed up 4 feet and it turned on again. So trip to the dealer I guess
  11. May 7, 2013 at 5:53 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    go to a local parts store first and see if they'll read the codes. not sure if that'll work in canuckistan.
  12. May 7, 2013 at 6:15 AM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    Tire pressure also play major role on VSC and Check Engine Light , check those first make sure your tire pressure up to the specific requirement, if that did not work disconnect the negative battery and leave it about 15 minute or so..it's works for me
  13. May 7, 2013 at 6:42 AM
    4banger09
    Alex
    Nb, Canada
    Leveled
    No tpms in my wheels been like that for a year plus. Going to disconnect for 15, the truck drives fine
  14. May 7, 2013 at 6:59 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I had these lights come on
    It was a loose gas cap
    The code was an Fuel Evap System fault
  15. May 7, 2013 at 7:23 AM
    4banger09
    Alex
    Nb, Canada
    Leveled
    Just did 15 didn't work, I also cleaned the maf. It has to be a sensor or something stupid.
  16. May 7, 2013 at 7:39 AM
    biborado
    biborado Well-Known Member
    Stephen
    San Diego, CA
    2010 TRD Off-Road 4x4
    This happens to me every so often. Do you have a Bluetooth OBD scanner plugged in? I tracked my light down to having my Bluetooth OBD ELM tool plugged into the OBD port... Seems like there is a conflict when it's plugged in. Happens once every month or so. Goes away on its own after two or three trips.
  17. May 7, 2013 at 8:27 AM
    The_Hodge
    SC
  18. May 7, 2013 at 8:36 AM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    for the engine code,try to get the code pulled. I know checking the gas cap is always unlikely to be the source of the problem,but in these tacomas i think there is a problem with our caps. Especially if you are not experiencing too many symptoms,then it most likely is a loose gas cap releasing ?hydrocarbons?. Im not too sure about the traction control light,but you may have to get the YAW sensor recalibrated. That happened to my friends 03 4runner and that fixed his problem. Good luck
  19. May 7, 2013 at 9:07 AM
    4banger09
    Alex
    Nb, Canada
    Leveled
    Noted going to get them pulled now
  20. May 7, 2013 at 10:06 AM
    4banger09
    Alex
    Nb, Canada
    Leveled
    Gave me a oxygen code so it could be the sensor or wiring, the tech said it is usually the sensor
