Check Engine Light on after replacing fuel hose
Discussion in '1st Gen. Tacomas (1995-2004)' started by DrShaglove, Aug 7, 2015.
  1. Aug 7, 2015 at 3:59 PM
    DrShaglove
    DrShaglove [OP] New Member
    Dave
    2004 Tacoma PreRunner Extra Cab
    I replaced the fuel hose that connects the fuel pump to the main fuel line, after which I am unable to get the truck started -- it keeps cutting out and will not idle properly, plus the check engine light is blinking. It was running fine before I replaced the hose, except it was leaking fuel. It is a 2004 Tacoma Prerunner v6 extra cab with nary a mod on it. Anybody got any tips about the possible cause/resolution?
  2. Aug 7, 2015 at 4:00 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    whats the check engine code number
  3. Aug 7, 2015 at 4:36 PM
    DrShaglove
    Dave
    Don't have one. Got no scanner.
  4. Aug 7, 2015 at 4:56 PM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    could be just air in the fuel line, keep trying, maybe rev it a bit to keep her running,
    you could try cycling the key several times before starting it
