Check Engine Light - BACK AGAIN x3!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NIU_Huskies, Sep 5, 2018.
  1. Sep 5, 2018 at 2:49 AM
    NIU_Huskies
    NIU_Huskies [OP] Well-Known Member
    2017 Toyota Tacoma TRD Sport DCLB
    I'm sitting on the shoulder waiting for Toyota Care roadside assistance. Driving to work this morning and my check engine light came on and then a minute later my trac off light turn on. What are the chances this is the CPS issue?
    I have a 2017 Toyota Tacoma TRD Sport with 6,014 miles.
  2. Sep 5, 2018 at 3:31 AM
    Gator352
    Gator352 I like Publix cake ...
    Leesburg, Florida
    2018 Super White Tacoma SR5 4x2
    Did your truck stall? Or did you pull over not wanting to risk further damage?
  3. Sep 5, 2018 at 3:35 AM
    NIU_Huskies
    Pulled over to not risk any damage. I figured I had free Toyota Care roadside assistance so I'd rather get a tow than turn around and drive 15 miles to the nearest Toyota dealer. Plus I was on the road at 5am so I knew the Toyota dealer wasn't going to be open that early.
  4. Sep 5, 2018 at 3:38 AM
    Spencer4x42006
    Spencer4x42006 Whoisthatguy
    Spencer
    Bend, OR
    2006 TRD OR
    5100s Wildpeaks Light bar Other shit
    My 2006 did that when an o2 sensor went out, not sure if it’d be the same on the newer trucks though
  5. Sep 5, 2018 at 3:50 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    It depends on what the code is, could also be a loose connector.
    Any recent service lately?
  6. Sep 5, 2018 at 3:55 AM
    NIU_Huskies
    No new service since 18 month Toyota care service in May. I filled up my gas tank 80 miles ago.
    EDIT: Just checked my trip odometer since last gas fill up it was 104 miles.
  7. Sep 5, 2018 at 4:43 AM
    NIU_Huskies
    Finally got it to the dealer. The service writer was annoying. I told her I read about a lot of issues with bad CPS and she said she never heard of that issue and never had a Tacoma in for that and she didn't like to diagnose issues based off what customers read. She asked if I recently got gas and it could be the gas cap. I told her I got gas 104 miles ago and it should have lit up way before then and the trac off light also turning on should have nothing to do with a gas cap.
    outlawtacoma likes this.
  8. Sep 5, 2018 at 5:28 AM
    srdatv
    srdatv Proud Tacoma Owner
    SCOTT
    massachusetts
    2017 trd sport double cab
    led interior lights,led plate lights,led low beams,side steps,rainguards,hood deflector,hood graphic,goodyear duratrac tires,sill plate decals,glove box decals.
    I work at a dealership and some of these service advisors should stuff there own f----ng heads in the toilet because they don't know shit about shit most times!!!!!
    gilligoon, Saeros, Garyji and 5 others like this.
  9. Sep 5, 2018 at 5:56 AM
    Jh8473
    Jh8473 Well-Known Member
    Bowling Green
    2025 Tundra SR5
    None
    So what's the verdict?
  10. Sep 5, 2018 at 5:57 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    What were the codes that triggered the MIL? You can't diagnose anything unless you know what the codes were. Some indicate a possible CPS, many dont.
    fdbyrne likes this.
  11. Sep 5, 2018 at 7:14 AM
    Gator352
    Leesburg, Florida
    My wife filled up her charger and went 200 miles before check engine light came on.
  12. Sep 5, 2018 at 7:23 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think when guys were having CPS failures the high transmission temperature screen also came on too.
    The hammer likes this.
  13. Sep 5, 2018 at 7:50 AM
    rickm
    rickm Well-Known Member
    Rick
    MA
    2018 BLK Tacoma TRD Pro
    If there was no tell tale signs such as a rough or sputtering engine or loss of power I would have checked to see how tight the gas cap was!
  14. Sep 5, 2018 at 7:51 AM
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    That's probably true. But, it's also not their job to diagnose issues unless it's something pretty obvious. Even if they both agreed that it could be the CPS issue, doesn't the tech have to confirm before any warranty work is approved?
  15. Sep 5, 2018 at 7:53 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Yep
    In other words, diagnose based on the codes thrown and go from there, dont just throw parts at what you think might be the problem.
    BillsSR5 and 98tacoma27 like this.
  16. Sep 5, 2018 at 11:35 AM
    NIU_Huskies
    They called for me to pick up my truck. I called back and the service writer didn't answer. So still don't know the cause. But it hasn't been a good day for my truck.
    Either the tow truck company or the dealer scratched up one of my Method wheels. Both are saying it wasn't their fault so there is a claim in with Toyota roadside assistance and customer care so Toyota and tow truck company can hash out who is at fault.
    Found my truck parked on curb at Toyota dealer like this before it went in to be checked and before I left the dealer in a shuttle.
  17. Sep 5, 2018 at 11:50 AM
    NIU_Huskies
    Service writer called me back and her explanation of what the issue was seemed confusing so I'll ask again when I go to pick it up. She said a "speed sensor" in the wheel was the cause. What speed sensors are in wheels and why does it cause a check engine light to go off? I have TPMS in my wheels but that is to report and monitor tire pressure.
  18. Sep 5, 2018 at 12:07 PM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    The speed sensor is for ABS and traction control. In the old days of ODBII the check engine light was mostly only for emissions related failures. Hence many people’s association of it as the oxygen sensor or gas cap light. But now pretty much any module can request the light.
    I recommend a cheap code reader like the AL319 or something better if you can afford it. Then you can at least see what it is. Especially after your free tows run out.
    1bad2k and sierra141 like this.
  19. Sep 5, 2018 at 12:12 PM
    SD Quicksand
    SD Quicksand Well-Known Member
    Alex
    San Diego, CA.
    2017 Tacoma TRD Off Road 4x4 Access Cab Quicksand
    Speed sensors are part of the ABS. They are not part of TPMS. Plenty of discussion on various TW forums involving the sensors.
    Also:
    https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
    Mr-Paul likes this.
  20. Sep 5, 2018 at 12:13 PM
    NIU_Huskies
    Thanks @tallpilot, I've also noticed that in this truck everything seems to set off the check engine light even if it's not actually an engine-related issue. Surprised it didn't set off an ABS light too then.
