Check engine light after new gas cap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by InfernoTonka, Feb 8, 2018.
  1. Feb 8, 2018 at 7:15 PM
    InfernoTonka
    InfernoTonka [OP] Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    So I figured I need a locking gas cap so I bought one to replace the OEM cap.
    All went well until this morning when I started the truck up...I got the dreaded check engine light. No big deal, I just put the OEM cap back on and expected the check engine light to go away. It seems that it will not go away.
    My main question is: once the check engine light comes on, and you fix the problem, does it stay on? If so what is the best way to reset it?
  2. Feb 8, 2018 at 7:19 PM
    07regtacoman
    07regtacoman Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    Takes a few miles before it goes off unless you have a code reader that resets the light.
    Miraclejoe and InfernoTonka[OP] like this.
  3. Feb 8, 2018 at 7:20 PM
    Hurley_man
    Hurley_man Well-Known Member
    Las Vegas, NV
    16 DCSB OR 4x4
    Traded my 2012 sport for the 16
    Same thing happened to me. You have to use a regular cas cap. Something about the locking one set my check engine light off. Pretty sure our gas is safe. There’s a little dilhickey in there that prevents people from stealing your gas.
  4. Feb 8, 2018 at 7:21 PM
    Hurley_man
    Las Vegas, NV
    16 DCSB OR 4x4
    You can reset the check engine light if it doesn’t go off. YouTube it!
    InfernoTonka[OP] likes this.
  5. Feb 8, 2018 at 7:31 PM
    InfernoTonka
    I was just making sure this check engine light thing was normal. It makes me a little nervous that it doesn't go away quickly.
    I'm not worried about someone stealing gas as much as someone pouring something in the tank to screw things up. My neighborhood has become more sketchy over the past couple of years and I am usually the one calling the cops on suspicious activity. Long story short things have got really tense on the block.
    I'd rather be safe than sorry on this issue. Or at least safer. If nothing else it would slow the idiots down long enough for me to take action LOL.
    TacoPandaTRD and DAS Taco like this.
  6. Feb 8, 2018 at 7:35 PM
    LawTaco
    LawTaco Well-Known Member
    Lawrence
    Bay Park,San Diego,Ca
    TRD SPORT 24
    The locking cap probably didn't seal properly,
    Try disconnecting the battery for half an hour to try to reset it
    TacoPandaTRD likes this.
  7. Feb 8, 2018 at 7:35 PM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Emissions stuff often takes 3 successful drive cycles I believe.
  8. Feb 8, 2018 at 7:36 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Just disconnect the battery for a few minutes, CEL will reset. Otherwise it could take a hundred or so miles.
    Aftermarket gas caps and Tacomas have never gotten along, ever
  9. Feb 8, 2018 at 7:38 PM
    tcjacado
    tcjacado Well-Known Member
    The new gas cap set off mine as well. I disconnected the battery to clear the cel. But if it is a issue in your neighborhood then install the locking one when you get home and reinstall the oem one when getting ready to leave. I know it a pita, but it will work:thumbsup:
  10. Feb 8, 2018 at 7:48 PM
    not0ny
    not0ny Well-Known Member
    2017 MGM TRD SPORT DCSB 4X4
    Bilstein 6112/5160 JBA UCA
    are you using a stant locking oil cap?
    no issues with mine
  11. Feb 8, 2018 at 7:50 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    what was the code? Could be something else....
  12. Feb 8, 2018 at 7:56 PM
    InfernoTonka
    No. I did notice that it is the favoured brand. All of the Autozones and Advanced Auto's around me don't carry them for whatever reason. I might just order off Amazon.
    not0ny[QUOTED] and tcjacado like this.
  13. Feb 8, 2018 at 7:57 PM
    not0ny
    yeah i purchased from Amazon as well. never had an issues with a CEL
  14. Feb 8, 2018 at 7:59 PM
    InfernoTonka
    I hope not. It was fine before I made the cap switch. I might go to Autozone and borrow their reader.
    BTW I've always put aftermarket gas caps on all my past vehicles and never ever had issues.
    wilcam47[QUOTED] likes this.
  15. Feb 8, 2018 at 8:00 PM
    wilcam47
    Will
    Bourbon state
    Ive had issues with the locking cap. But never hurts to check the code.
  16. Feb 8, 2018 at 8:05 PM
    phsycle
    phsycle Well-Known Member
    CA
    A code reader is pretty cheap on Amazon as well. Easy to read the code and clear the CEL.
  17. Feb 8, 2018 at 11:11 PM
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    Do you need to spin it until it clicks at least once like the OEM? I’m assuming you did...my wife didn’t spin it until it clicked at least once and the light came up too. After we clicked it, dealer reset it but it would’ve reset itself anyways.
  18. Feb 8, 2018 at 11:34 PM
    1tacomaluvr
    1tacomaluvr Well-Known Member
    '17 Inferno OR DCSB
    my Stant #10504 locking gas cap came from WalMart and caused my CEL to come on too, took "resetting" the cap twice for the light to go out, hasn't come on again in a year, works good (hopefully) lasts along time!
  19. Feb 8, 2018 at 11:46 PM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    IMO, The best answer will be the OBD Scanner.. :thumbsup: and from there you can reset the code for that Gas cap issues you might have.
    .. Or you can go Autozone for a free OBD scan check.. ;)
  20. Feb 9, 2018 at 12:51 AM
    SK808
    SK808 Well-Known Member
    Ewa Beach, Hawaii
    2017 Tacoma TRD OR DCSB 4X4
    Magnuson Supercharger, Kings w/Resi front and rear, ICON UCA, Allpro STD leaf pack, C4 Fab Hybrid Front Bumper, RCI Rear Bumper, X20 winch, All Pro U-bolt Flip Kit w/ wheelers bump stop, Method 701, 17X8.5 w/0 offset, BFG KM3 285/70/17, All Pro Sliders, TRD CAI, Spec-U exhaust, Total Chaos bed stiffener, RCI Skid Plates (all skids), Wet Okole seat covers, Diamondback tonneau cover, Grillcraft MX Grille, Husky front floor mats, Weather Tech rear floor mats, bed mat, various Baja Design lights, mobtown tailgate reinforcement plate, and a bunch of other stuff.
    I got the stant #10504 locking cap and works great. Ordered it from rockauto.com. I had a stant on my Gen2 Tacoma as well with no issues.
    Requital likes this.
