Check Engine Code P0102
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Drew12, Oct 10, 2017.
  1. Oct 10, 2017 at 8:37 PM
    Drew12
    Drew12 [OP] Well-Known Member
    Andrew
    Sisters, Oregon
    2005 4x4 TRD OR Access Cab
    Bilstein 5100's/Toytec 620 coils, rear AAL, Camburg UCA's, Pro Comp 7069, AFE stage 2 CAI, Blacked Depo Headlights
    Hey guys,
    So I was installing a CAI today but it turned out I didnt have enough parts to do the job (bought it used). When I was installing the stock intake back onto the truck, I decided to clean the MAF sensor since I had a little cleaner left over. When I turned my truck on I got the check engine light. Got codes read and it read P0102 ( Mass of Volume Air Flow A Circuit Low Input). Also said something about Air Intake Temperature High. Turned my truck off, waited a while and then back on and the light was gone... Is this something I should get checked out, or did the engine clear the code because it was running correctly after the on/off/on cycle? Thanks to anyone that can help!
  2. Oct 13, 2017 at 3:25 PM
    Drew12
    Andrew
    Sisters, Oregon
    Anyone??
