check engine code P0101
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YumaTRD, Jan 31, 2010.
  1. Jan 31, 2010 at 3:11 PM
    YumaTRD
    YumaTRD [OP] The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
    I have a volant cold air intake installed and drove the truck for about three months with no codes. out of no where I get the check engine code P0101. My first thought was that the oiled air fillter probably got the MAF senor dirty so I removed and cleaned the MAF senor with special MAF senor safe cleaner.
    I had the code reseted.
    Within the following month the code apeared again and then it cleared itself after a hunderd miles.
    I decided to upgrade to a dry filter from URD.
    I reset the computer again and the code still apears.
    Do I need to replace the MAF senor or would installing the URD Calibrator fix the problem?
    Im thinking that the MAF is misreading the actual air flow and that the calibrator could fix that.
    Any other ideas?
    Thanks in advance
  2. Jan 31, 2010 at 3:36 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    I just looked up your code. It says it's either a vacuum leak in the intake system, a leak in the PCV system, or a bad MAF.
    My guess is it's the first one. I'd see if the manufacturer has any info on this problem, or get a hold of the URD guys and see if they have a fix for it.
  3. Jan 31, 2010 at 3:45 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    I'll check the hoses that conect to the intake and make sure theres no leaks or tears.
    hope its something simple like that
  4. Jan 31, 2010 at 6:40 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    all the hose connections were tight and sealed.
    I'll trade the MAF with a friend and ill see if the problem occurs again.
  5. Mar 17, 2010 at 1:32 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    I installed a different MAF sensor on my truck and got the same code again. that should rule out the sensor. all the vacuum hoses are nice and tight. I don't know what to do to fix the problem
  6. Jun 24, 2011 at 8:11 AM
    johnh7
    johnh7 life. It goes on.
    GA
    i know its been a while.. any fix on this?? i have gone throught 3 MAFS, replaced vacume hoses... but still get that stupid p0101 code...
  7. Apr 17, 2013 at 12:48 PM
    masterarcher
    masterarcher Member
    Jordan
    Austin Tx
    2019 Taco SR 4dr 4x4 3.5l V6
    I had the same code, i just recently just cleaned my sensor, reset my light and after 50 miles, it hasnt come on so far. I will update again if it comes on. The sensor just sits on top of the air intake, and is only held on by 2 screws. Just unhook the wire, unscrew it and pull out the sensor. The sensing bulb on mine was pretty obviously dirty, so i just wiped it off an put it back in. Hope this helps.
  8. Dec 4, 2014 at 5:39 PM
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    Check your EFI #2 fuse!
  9. Jan 2, 2019 at 7:28 PM
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
    I know I'm resurrecting the dead, but what have you guys done to resolve this code?
  10. Jan 2, 2019 at 7:40 PM
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    OP, cleaned your MAF lately?
  11. Jul 14, 2020 at 4:10 PM
    weidnca
    weidnca New Member
    Sorry to resurrect this thread....any updates on the P0101 code? My 2008 Tacoma has been throwing it off an on for a month or so....I have a K&N cold air intake, and cleaned/oiled the filter just before the code appeared. I've cleaned the MAF with contact cleaner twice, and reset the computer each time. The code just reappeared yesterday....any ideas? Thanks in advance!
  12. Jul 14, 2020 at 10:09 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I would replace the maf sensor and get rid of the oily K&N
    weidnca and Jimmyh like this.
  13. Aug 23, 2020 at 9:44 AM
    Hood24
    Hood24 Member
    Brandon
    Georgetown Ontario
    '15 TRD DC SB 6MT
    URD Intake, TRD EXHAUST, 265/70/17 Duratracs, 3" Supreme Suspensions Lift, Smoked Tails, Nokya 2500k Headlight & Foglight Bulbs, Black Factory TRD Sport Rims,
    Yup, just got the same code.
    Tried cleaning MAF sensor, even replaced it. Nothing.
    All hoses look fine as well.
    I'm running a URD intake on my 4.0L.
    Anyone end up fixing this issue?
    Gadget from URD just advised making sure filter wasn't installed too far into intake pipe (which it isn't), and all wiring connections are properly intact (which they are)
    If anyone has insight please advise
  14. Aug 23, 2020 at 9:48 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Try putting the stock intake setup back on and see of the code returns
    Clearwater Bill likes this.
  15. Aug 23, 2020 at 9:52 AM
    Hood24
    Hood24 Member
    Brandon
    Georgetown Ontario
    '15 TRD DC SB 6MT
    I wish I could. I sold it years ago. Ran the yrs intake for about 4-5 yrs now.
    Maybe I'll check online to see if there are any OEM intakes for less than factor price
  16. Aug 23, 2020 at 9:56 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Well if it was on there for 4-5 yrs nevermind..
    Might have a broken wire somewhere along the line
  17. Sep 2, 2020 at 4:02 PM
    Hood24
    Hood24 Member
    Brandon
    Georgetown Ontario
    '15 TRD DC SB 6MT
    Update... I was getting fed up, tried replacing MAF sensor, nothing. Cleaned sensor, nothing. Cleaned connectors, visually inspected hoses, nothing.
    Finally fixed: I cleaned throttle body assembly, and re-cleaned the intake filter. I cleared the codes, and this has fixed the issue for 1000kms so far. No returning engine light. Hope this can help someone else
    Hood
