Check charging system light
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RustyTrumbone, Aug 26, 2018.
  1. Aug 26, 2018 at 12:25 AM
    RustyTrumbone
    RustyTrumbone [OP] Well-Known Member
    Phil McCracken
    2018 Tacoma SR5 Short Bed
    I’ve had the truck maybe two months, it runs perfect. But I’ve noticed whenever I had the key turned to accessory with the engine not running I get this “check charging system” warning come up. Is this just to warn you that you’re using the battery’s power while the engine is off? Or does it mean the voltage on the battery is lower than it should be?
  2. Aug 26, 2018 at 12:37 AM
    KellyJoe
    KellyJoe Well-Known Member
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    Yes. It's normal.
    2016Tacoman likes this.
  3. Aug 26, 2018 at 2:52 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Normal. Think of it as a fancy "battery" idiot light.
  4. Aug 26, 2018 at 2:56 AM
    tcjacado
    tcjacado Well-Known Member
    It's just letting you know that you are using the battery.
  5. Aug 26, 2018 at 4:09 AM
    Gator352
    Gator352 I like Publix cake ...
    Leesburg, Florida
    2018 Super White Tacoma SR5 4x2
    I’m surprised there’s not an idiot light for an idiot light.
  6. Aug 26, 2018 at 4:18 AM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Just look into the rear view mirror for that.:D
  7. Aug 26, 2018 at 4:26 AM
    Gator352
    Leesburg, Florida
    Such a comodian! Flush another would ya? :headbang: Lol
  8. Aug 26, 2018 at 5:34 AM
    MOC221_
    Frank
    Gold.
  9. Aug 26, 2018 at 7:30 AM
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    2020 Tacoma: Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
    Perfectly normal. Engine is not running so the alternator isn't turning and therefore not charging the battery. Vehicles with just a little red battery light do the same, I just don't think people notice those as quick. If you see that with the engine running then you have a problem.
    shakerhood likes this.
  10. Jan 3, 2022 at 12:12 PM
    Wendymauilady
    Wendymauilady New Member
  11. Jan 3, 2022 at 12:14 PM
    Wendymauilady
    Our Tacoma has this warning light while running it. Had to replace the battery. Now it's doing it again. Took it to Toyota and they can't figure it out. Frustrated.
  12. Nov 2, 2023 at 6:56 PM
    DesertSandMica
    DesertSandMica Member
    Chico CA
    17 SR5 4x4 LB 3.5 05 SR5 Prerunner 4.0
    Century Hi-C Snugtop Cab Hi Total chaos bed stiffeners
    What did you end up doing?
