Check Brake System Warning Message
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2016tacoma, Aug 23, 2020.
  1. Aug 23, 2020 at 9:53 AM
    2016tacoma
    2016tacoma [OP] Active Member
    Paul
    2016 Barcelona Red SR5 V6 4x2 DCSB
    I have noticed that the "Check Brake System" warning light and message come on whenever I perform the following steps:
    1. Turn the ignition switch to ON ( do not start the engine)
    2. Depress the brake pedal 5 - 7 times
    Could one of you please confirm if this is not normal ?
    TIA
  2. Aug 23, 2020 at 10:10 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Normal, you're depleting reserves with the engine off. I assume the pedal gets firmer and firmer?
    2016tacoma[OP] likes this.
  3. Aug 23, 2020 at 10:10 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    When u first turn it on it will cycle threw everything . System check of some sorts . As long as the light does not stay on u should be good . As far as the second part with hitting the brake pedal . Never tried that . Not sure why u would be doing that .
  4. Aug 23, 2020 at 7:13 PM
    2016tacoma
    Paul
