Cheap mod: Double cab under-seat long gun storage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stretch85, Nov 13, 2011.
  1. Nov 13, 2011 at 3:24 PM
    stretch85
    stretch85 [OP] Active Member
    Raleigh-Durham, NC
    2011 V6 4x4 TRD Sport
    A few months ago I decided to get a truck shotgun. I figured the under-seat storage in the back of my 2011 double cab would be a great place to keep one. The storage compartment is obviously limited, but I found that the stockless Mossberg 500 Cruiser fits nicely. (I doubt you'd be able to get anything with a stock in there comfortably.)
    Of course, just letting the gun lay lopsided in the container wasn't very aesthetically appealing, and over time it sliding back and forth would wear both the gun and the storage compartment. So, I devised a simple, cheap mod to safely secure the gun inside the compartment using duct tape's friendly cousin, Velcro.
    Mod supplies:
    * 2x #10 1/2" machine screws
    * 2x #10 steel washers
    * 2x #10 nut
    * 2x #10 black plastic screw covers
    * 2+ feet double-sided Velcro
    Tools needed:
    * Drill w/ 5/32" bit
    * 2x flat head screwdriver
    * Adjustable wrench (a 10mm socket should suffice for our purposes)
    * Scissors
    * Marker pen/chalk (preferably a light color)
    Step 1: Remove the under-seat storage compartment
    This is accomplished by prying up the nine black fasteners along the front and rear edges of the compartment using two flat head screwdrivers. They may seem stubborn at first but with a bit of effort they will eventually pop straight up. (There's probably a tool designed specifically for this, but damned if I know what it is. A very small claw hammer might work as well.) I suggest sealing the fasteners in a plastic immediately to so that they don't disappear.
    With all nine fasteners removed, the plastic compartment lifts right out.
    Step 2: Cut two strips of Velcro to length
    Wrap Velcro around the two points at which you want to secure your gun leaving plenty of extra slack and cut two strips of sufficient length. You can always trip them down later if necessary.
    Step 3: Drill two holes along the front of the compartment
    Now, the ideal placement of these holes will depend on what gun you have. For the 500 Crusier, I drilled two holes about 3/8" below the lip of the container: one about half an inch from the left inside edge and the other almost directly underneath the third fastener hole from the left. You'll probably need to experiment with the Velcro and positioning of the gun to come up with the best spots.
    A word of caution here: Make sure the placement of the holes doesn't interfere with the two slots for the locking mechanisms of the compartment lids. Also avoid drilling the holes close to the vertical support on the outside of the container as they will prevent the washers from laying flat.
    Step 4: Putting it together
    Fold each Velcro strip at the point you want to attach it to the compartment and cut a very short slit vertically across the fold. This slit should be just long enough to force the screw the Velcro and no longer. Keep in mind that you want the overlapping portion of the Velcro loop to be above the gun, which should be the gun's right side.
    Put a screw through one of the screw covers and then force it through the Velcro strip with the loop (soft) side facing the screw head. Drive the screw into the wall of the storage compartment (head facing inside) and secure a washer and nut on the end of the screw. Repeat for the second screw.
    Again, the order of the component from inside to outside the compartment is: screw head, screw cover, Velcro, compartment wall, washer, nut.
    Once the nuts have been tightened sufficiently, place the storage compartment back in the truck and replace the fasteners. Now you should be set to mount your gun.
    I've found that if I keep the right-side loop just loose enough, I can very easily undo the left-side loop and slide the gun out without lifting the right side of the compartment (under the larger half of the back seat).
  2. Nov 13, 2011 at 3:32 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Not a bad idea. But to be honest though cool I don't see it as functional. Still good idea for transporting though.
    cosmic stardust likes this.
  3. Nov 13, 2011 at 4:03 PM
    stretch85
    Raleigh-Durham, NC
    What do you mean by functional? Granted, the gun isn't as accessible as if it were mounted on a gun rack, but I'm not comfortable advertising that there's a firearm in my vehicle.
    MadDaddy likes this.
  4. Nov 13, 2011 at 4:35 PM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    how hard is it to get the gun out quickly? thats the only reason i'd have shotgun in my truck that i specifically bought to carry in there is so i can grab it real quick in case of an emergency. seems like a lot of sugar for a dime, solid mounting method though
  5. Nov 13, 2011 at 4:42 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    What I meant by functional is that is a self defense gun and you can't really use it for its intended purpose mounted there. You actually have to get out of the truck and open the rear door, fold the seats, unlatch the tray unvelcro the gun.
    Still a good way to transport the gun, no doubt.
    What is the purpose of this truck shotgun for you?
  6. Nov 13, 2011 at 4:50 PM
    stretch85
    Raleigh-Durham, NC
    Lift up the seat, lift up the compartment cover, unstrap the one Velcro strip, and pull the gun out. Probably ~8-10 seconds from the driver's seat assuming you remember to unlock the door on the way.
    The reality is that you're not going to grab a long gun from the driver's seat in a hurry unless you have one mounted vertically as in LEO vehicles. That's what a handgun is for.
    To have and not need, essentially.
  7. Nov 13, 2011 at 4:59 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Lets hope so because if you need it, you essentially don't have it.
    As in for self defense? Because that's what I mean by functional, you can't use this for personal self defense. If at a light and an attacker approaches. If leaving a store and walking to your vehicle? Even if opening your vehicle and being approached it still wouldn't be practical. In my opinion a long gun is for home protection and even then the length can still cause issues in clearing corners. Say you can get this gun out while being attacked you can still only defend the passengers side comfortably.
    Justinlhc likes this.
  8. Nov 13, 2011 at 5:03 PM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    I have almost the exact same setp up, except I have a full stock. I recommend keeping it well oiled as they tend to rust especially from heat differences. Also mine rattles quite a bit so I put an old T-shirt under it...
  9. Nov 13, 2011 at 5:10 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    a "truck gun" isn't intended for rapid deployment, a la anti-carjacking , ..etc, - that's what a handgun on your person (or w/in reach) is for.. a truck gun is for the chance you are stranded somewhere, and are approached w/ a threat/threats... long gun affords more firepower in the worst of situations..
    MadDaddy and Typhoonzz like this.
  10. Nov 13, 2011 at 5:20 PM
    stretch85
    Raleigh-Durham, NC
    Yeah, I keep it oiled and also put a 40g reusable desiccant pack in the compartment. We'll see how well it holds up.
  11. Nov 25, 2012 at 6:41 PM
    glandnut
    glandnut Reserve Squirrel Hair
    Florida
    16' 4Runner TEP, 01' Ext cab 4x4
    secret stuff.
    Cool idea, I just keep a spin cast 2 pc. fishing rig for those quick draw moments.
  12. Nov 25, 2012 at 6:46 PM
    OldFatGuy
    OldFatGuy Well-Known Member
    Robert
    Greenville, NC
    2012 4WD double cab with minor mods
    Flow Master 50 Series dual K&N Filter Cheap Toyota Skid Plate (better than Nothing) 2.5 Hell Bent leveling Kit 1.0 blocks on rear 285-75-16 BFG KO High Performance Bed Mat De-Badged Westin Light bar -W/ 3 KC 100watt slim lights
  13. Nov 30, 2012 at 4:38 AM
    hudsonstrong
    hudsonstrong Member
    Jonathan
    Columbus, GA
    2013 Tacoma Double Cab 4x4
  14. Nov 30, 2012 at 5:14 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Good idea, I'm thinking about rigging something up behind the rear seats. That would be more for transporting the firearm, not for protection. I'm thinking a gun rack mounted behind the rear seats to keep them out of sight. They'd be trigger locked in the rack anyways so they wouldn't for self defense. I might steal the velcro idea to help keep them tight, I was thinking quick fist holders but velcro is a lot cheaper.
  15. Nov 30, 2012 at 5:20 AM
    Thelt
    Thelt Well-Known Member
    Lenoir, NC
    '12 4x4 SR5
    It is for when you empty all 17 rounds from your Glock and still have more zombies to kill. I think it is cool.
    straightawaykid, TacomaTrav and Vance like this.
  16. Mar 26, 2015 at 4:26 AM
    TOLLAV
    TOLLAV Wait, I have to drive ON the road??????
    Louisiana
    14 TRD Sport
    ^+1 :fenforcer:
  17. Mar 26, 2015 at 10:53 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    A cool idea OP ! :oldglory:
  18. Mar 28, 2015 at 10:21 PM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    Well done.
  19. Mar 28, 2015 at 10:29 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Awesome, to bad my truck has the rear sub and center console.
    Do you have a way to carry your handgun? I'm considering buying a cheap Kydex holster and strapping it inside my center console with the provided hooks.
  20. Mar 29, 2015 at 4:49 AM
    BYBO
    BYBO Well-Known Member
    Byron
    Indiana
    I keep an underfolding AK47 behind my rear seat. Slow to deploy as stated, but still available. A hand gun is only designed to get you to your long gun, IMO.
    Vance likes this.
