Chassis Saver or Paint in boxed frame? if installing frame reinforcement plates.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cadmus, Sep 17, 2016.
  1. Sep 17, 2016 at 1:09 PM
    Cadmus
    Cadmus [OP] Un-Known Member
    Fort Collins CO USA
    '04 4door 4x4 TDRoffroad
    I started Prepping and painting Chassis Saver on my frame. It is a pretty low rust 2004 4 door. If in the next year i plan to weld on frame reinforcement plates like this:
    http://www.cbioffroadfab.com/products/1st-gen-toyota-tacoma-products/1st-gen-tacoma-frame-plates/
    or another brand. In those parts of the C frame that will become "boxed" perhaps it is unwise to use chassis saver. I never used chassis saver before, i do not know how much maintenance it needs or how it stands up to heat from welding. But I already determined applying it inside a boxed frame is not great due to uneven or "too thick" coverage (happy to hear other opinions).
  2. Sep 17, 2016 at 1:12 PM
    Cadmus
    Fort Collins CO USA
    Back ground:
    Plan was to use wire brush then Chassis saver on all exterior of all frames (some parts can not be hit with wire brush). on the inside of boxed frames i planed a chemical rust remover then rustolium with a garden sprayer.
  3. Sep 17, 2016 at 1:20 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Those frame plates get welded on the outside of the frame. It won't box the c channel.
  4. Sep 17, 2016 at 1:24 PM
    Cadmus
    Fort Collins CO USA
    ok. my bad. But some of them do box it and strength to weight ratio of a boxed system is better so that is what i will use.
    EDIT: WTF, i swore some kits were but i can not find any right now. maybe they were all DIY with plates?
  5. Sep 17, 2016 at 1:30 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    In my experience in the harsh north east of Canada, your best bet is a liquid undercoating. Fluid film, rust check, Krown, all very good products. They stay liquid and creep into all the crevices of your frame welds, body panels etc. When a truck rusts it usually starts in tight nooks and crannies where you could never reach with paint, or that awful hardening style undercoating. Re apply fluid film etc yearly. I usually apply late fall.
    This nozzle is good for inside your frame. You can get it for a spray gun as well
    My $0.02
    Itchyfeet and Cadmus[OP] like this.
  6. Sep 17, 2016 at 1:35 PM
    Cadmus
    Fort Collins CO USA
    Yes. But painting over a truck that had fluid film is a bitch. Just got the truck this year. Plan to prep and paint OR prep and chassis saver the best I can before the first coat of fluid film. Then fluid film every fall and spring.
    Fluid film and others get into the body and the crevices. I sing it's virtues and balance need for paint vs fluid-film in this post.
    I need this truck to last forever. I really hate the direction new trucks and cars are going and i do not want to own anything newer. Investing in rust prevention the best i can.
  7. Sep 17, 2016 at 2:22 PM
    Northern Taco
    Fair enough. I thought you were only using paint
