Charging Goal Zero Yeti from outlet in truck bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by staygoldconeyboi, Apr 25, 2023.
  1. Apr 25, 2023 at 9:40 PM
    staygoldconeyboi
    staygoldconeyboi [OP] Member
    Robby
    2021 Tacoma TRD Off-Road
    None so far :(
    I'm looking to grab a Goal Zero Yeti 1500x for camping/overlanding with my truck. I was curious if anyone else charged their's while on the road via the AC outlet toward the tailgate in the newer Tacomas. I have one in my 2021 TRD Off Road and was curious if that would be the preferred method over 12v inside the vehicle. Are there any risks of one over the other?
  2. Apr 26, 2023 at 6:32 AM
    OldMattB
    OldMattB Active Member
    I use a Bluetti EB3A. On my FJ Cruiser, I ran a heavy wire set from the battery, through a fuse, and to a 12-volt outlet I installed in the back. While driving, the Bluetti charges, and also powers my Iceco VL45 refrigerator. When I set up camp, I plug the refrigerator directly into the outlet, and the Bluetti is free and fully-charged for use - charging phones, lights, my CPAP while I sleep. Typically, the car battery shows about 12.5 volts in the morning at the back from the outlet, and the Bluetti is at about 45 percent charge.
    I am really happy with the setup - simple and effective.
    I would GUESS that the power loss from converting 12 volts to 110 and (typically) back to 12 volt for the fridge is not huge. I do see some risk from having 120-volt power if things get wet. I tried the Iceco in my Tacoma when the truck was running, and had to do the high-wattage conversion to get the fridge to run.
    suckingdarts likes this.
  3. Apr 26, 2023 at 6:48 AM
    jayandersen5
    jayandersen5 Well-Known Member
    Jay
    South Carolina
    2017 TRD Pro
    OTT Tuned Yukon 5.29s 35x12.50r17 Yokohama MTs RRW RR7-H Wheels Dobinsons MRRs RRW hybrid front bumper ATH rear swing out high clearance bumper Alucab Explorer Canopy iKamper skycamp 2.0 Diode Dynamics SS3 (x4) and SSC2 SOS Sliders RCI trans and t-case skids Smittybilt X20 Gen3 10k winch Prinsu Cabrack Expedition Essentials 3TPAM Caliraised 40" light bar Total Chaos spindle/cam tab gussets and bed stiffeners Switch Pro SP9100 Power Tray
    You'll need to install a 12v outlet in the bed in order to charge your goal zero while you're driving. My factory AC bed outlet wouldn't charge my ecoflow river pro while driving due to it dropping down to 100w.
  4. Apr 26, 2023 at 6:57 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    I found that my EcoFlow Delta 2 wants pure sine A/C to charge with or it won't even start charging. The Toyota inverter is not pure sinewave like say a RedArc is.
    I also modded my truck with the 400W anytime setup, so I know it isn't because of the 100W issue.
    My Jackassery 1000 didn't care what you fed it, but it would top out at 168W input.
    I have a dedicated fused 10awg 12VDC line ran to the back seat in my double cab where my EcoFlow and ARB fridge reside. The EcoFlow charges off this line, and the fridge runs off the EcoFlow.
    If parked for days, the EcoFlow gets switched over to solar charge.
  5. Apr 26, 2023 at 7:11 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    You could go with the the dedicated 'Yeti Link' system and charge directly from the vehicle battery. I've installed dozens and they work great!
