Charging Ecoflow River 2 pro from 110v socket
Discussion in '4th Gen. Tacomas (2024+)' started by Wahhabm, Sep 14, 2024.
  1. Sep 14, 2024 at 6:22 PM
    Wahhabm
    Wahhabm [OP] Well-Known Member
    Monther
    Hi I bought an Ecoflow River 2 Pro generator to power the Iceco refrigerator in the bed of the truck and I thought I would power the generator from the 110v instead of the cigarette lighter plug. Well, I quickly found out that the 110v will not run to charge up the generator and only the cigarette lighter plug will work. The cigarette lighter only pushes about 95 watts and the refrigerator consumes roughly 60watts. So this formula will not be enough to keep the generator charged and working to support the refrigerator all the time as my driving is very limited. When I searched on the internet someone posted something that the 110v plug in our truck is a modified sine wave and the ecoflow requires a pure sine wave. This is too technical for me. All I want to know is there a type of generator that will work from our 110v and can charge at a high rate?
  2. Sep 15, 2024 at 5:26 AM
    Ryguy3684
    Ryguy3684 Well-Known Member
    Virginia
    2024 Tacoma TRD off road
    That's odd. I have the larger, eco flow delta pro and it charges just fine. You'll have to use the 400w setting while the engine is running. Does the River have the option for a "fast charge". If so, turn that off and adjust the charge level for below 400 watts.
  3. Sep 15, 2024 at 5:53 AM
    Wahhabm
    Monther
    It didn't work yesterday. But I will try again today and play with the settings since you say your ecoflow delta pro works. Can you share the exact model in case I wind up changing mine.
    Ryguy3684 likes this.
  4. Sep 17, 2024 at 12:18 PM
    Wahhabm
    Monther
    I retested and the river 2 pro worked, but I winded up getting a delta 2 which also works
    el_turks and Ryguy3684 like this.
  5. Sep 17, 2024 at 12:19 PM
    Ryguy3684
    Virginia
    Cool. Glad it worked for you.
    Wahhabm[QUOTED][OP] likes this.
  6. Sep 19, 2024 at 6:09 AM
    el_turks
    el_turks Well-Known Member
    Southern California
    2024 OR, 2009 PreRunner
    What settings are you all using for your eco flows? I have mine at charging on 200 watts but it is not working. I also tried 300 and 400.
  7. Sep 19, 2024 at 6:29 AM
    Ryguy3684
    Virginia
    I set mine to 300 watts. Is yours not charging at all?
  8. Sep 19, 2024 at 6:50 AM
    Wahhabm
    Monther
    The 1st time I tried, I messed around with settings to bring below 400 watts and I didn't succeed. After I bought the delta, I just plugged it because it didn't have an app to mess with settings and it worked right away and it was chaging at almost 800 watts. I wasn't happy that the delta that I got from Costco because it didn't have an app so I returned it to Costco and I bought a delta 2 which wirks with Bluetooth app. I noticed, the delta 2 varies, it charges as high as 1100 watts and drops gradually to 300 watts. I then decided to try the river 2 pro by just plugging in and not messing with watts and I noticed it was charging around 780 watts. I hope this helps
  9. Sep 19, 2024 at 1:16 PM
    el_turks
    Southern California
    Mine does not charge at the moment. I plug it into the outlet in the cabin and turn the AC button on. I can hear the charger click on but the charge section of the screen does not show it charging but instead you can hear a second click and the charge stays at 000. not charging. Can you hear the click when you plug yours in? Do you hear a second click? I have a Tacoma Off Road, not hybrid, are your trucks hybrid?
  10. Sep 19, 2024 at 3:30 PM
    Ryguy3684
    Virginia
    Mine is an off road, non hybrid, as well. Are you using the eco flow app to adjust the charging rate?
    el_turks[QUOTED] likes this.
  11. Sep 19, 2024 at 6:16 PM
    el_turks
    Southern California
    Yes, maybe I should just try changing the settings on the Delta 2 it self. Right now I have the app at 200w
    Ryguy3684[QUOTED] likes this.
  12. Oct 6, 2024 at 7:05 AM
    slyguy47
    slyguy47 Nerd
    Jacksonville, FL
    15 AC TRD OR V6 4WD 5AT
    I have a 2015 TRD off-road and a Delta 2. The eco flow app only allows me to go as low as 200 W charging. I would really like to be able to charge it while I'm driving which I think the Tacoma can only put out 100 watts when you're driving. My Delta 2 just keeps clicking and shows zero on the display like the other poster mentioned.
  13. Oct 6, 2024 at 7:43 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    do the 400W anytime mod
  14. Oct 6, 2024 at 8:13 AM
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    I suspect there's a reason for the switch to 100W while driving. Anyone have long-term experience with using the 400W anytime mod? Anyone know the official reason for the reduction in capacity while driving? I doubt that Toyota spent the extra money for a 2-level inverter just for fun.
  15. Oct 6, 2024 at 8:13 AM
    Ryguy3684
    Virginia
    There's a mod that allows you to run 400 watts while driving. They make a little kit, but I haven't seen one for the 4th gen yet. The wire mod is pretty simple.
  16. Oct 7, 2024 at 1:29 PM
    TurboDA6
    TurboDA6 Well-Known Member
    The inverter in the Tacoma is the same inverter in Nissan trucks. It's outsourced like everything else these days.
    I'm currently making an adapter harness to swap out the OEM inverter in my truck with a 400w REDARC pure sine inverter that'll always run 400w.
    Most of the issues people are having with these "solar generators" is that most reject modified sine 120v. They detect the dirty AC and refuse to charge. I don't see why they can't make them to tolerate modified sine, but that's the typical reason most vehicles with 400w OEM inverter won't charge these devices. My Anker Solix requires pure sine to charge.
  17. Oct 7, 2024 at 4:43 PM
    grizzlyoutlaw
    grizzlyoutlaw Well-Known Member
    @TurboDA6
    I am looking into this as well and will share the info/wiring diagrams @caribe makaira sent to me. I have not been able to fully dive into but hope it helps so we can all get this done.
    So, the fused 80Amp wire going to the OEM inverter is this:
    This is the connector to the A/C output.
    For the Redarc Inverter, you'd purchase a mating connector so there's no cutting the harness. One side would get a normal a/c plug to the Redarc output, the other would get the mating connector to Q4. The ground on the added A/C plug would share the same location (ring terminal) as the ground for the OEM inverter. It's a bolt just ahead of the OEM inverter connectors.
    5 = Hot
    11 = Neutral
    Green = Ground
    Terminal required for 90980-10802
    Male (x2)
    https://www.corsa-technic.com/item.php?item_id=1064
    for 14 awg wire
    TurboDA6 likes this.
  18. Oct 7, 2024 at 5:15 PM
    caribe makaira
    Caribbean, Puerto Rico
    "Anytime" 400 watts Inverter
  19. Oct 7, 2024 at 6:54 PM
    TurboDA6
    I have the 12 pos connectors and contacts.
    The issue I am having is finding the 2 pos high current connector mating end.
    Have you found that one?
    BTW, to be clear, I'm doing this on a Nissan Titan. I've been joining in on these discussions because Nissan uses the same inverter and connectors as Toyota does for the Gen 3 and Gen 4 Tacoma.
    If you go to eBay and look up used inverters for these trucks (mine is a 2021, same inverter from 20-24) you'll see they're the same. Apparently some Toyota enthusiasts are very good at making electrical adapters, so for now I'll just make them available to the Nissan guys.
    With the huge enthusiast base of Tacoma owners I can see that once everything is sorted, an inverter adapter kit can be mass produced in China far cheaper than I can do them myself. I make other Nissan adapters too, but generally only move 10-20 sets a year due to Nissan truck enthusiasts being a small fraction of Toyota.
  20. Oct 7, 2024 at 7:04 PM
    caribe makaira
    If the Nissan uses same connector and inverter, what are you searching a mating connector for?
    Toyota 90980-12299
    Yazaki 375 Male Terminal for 10-8AWG
    TurboDA6[QUOTED] likes this.
