Changing wheel studs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, May 13, 2020.
  1. May 13, 2020 at 9:17 AM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    In case anyone is unaware, a $20 ball joint separator is the perfect tool for removing/replacing wheel studs.
  2. May 13, 2020 at 9:27 AM
    JoosBox
    JoosBox Well-Known Member
    Pat
    Boise, ID
    2007 TRD OR
    Haha. What I did was had my mom spin it in with the breaker bar while I held onto it to stop it from turning with the tire iron and sorta stood/pushed on it with my foot
  3. May 13, 2020 at 10:58 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    An air hammer pushed them out like butter.
    Gunshot-6A likes this.
  4. May 13, 2020 at 11:12 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    We don't all have compressors. And honestly, I would have had these out long before I even uncoiled the air hose.
  5. May 13, 2020 at 11:13 AM
    TacoButcher
    TacoButcher Well-Known Member
    Angel
    Nor Cal
    2019 Quicksand Taco
    Stock but not for long
    Lug nut and hammer .. much faster
  6. May 13, 2020 at 11:14 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    To put them IN?
    PzTank likes this.
  7. May 13, 2020 at 11:14 AM
    JoosBox
    Pat
    Boise, ID
    2007 TRD OR
    Damn. I’ll be honest I thought they had to twist in for some reason. I guess just looking at it and understanding what I was doing would have proven otherwise. This would have taken a lot less effort. Oh well!
  8. May 13, 2020 at 12:03 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Just replace the wheel bearing. Seems much easier than trying to get the studs out
  9. May 13, 2020 at 12:08 PM
    TacoButcher
    Angel
    Nor Cal
    2019 Quicksand Taco
    Now you know if you need to do again
  10. May 13, 2020 at 12:15 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    Wtf? :confused:
    It took all of 20 minutes. Not to mention the cost difference.
    I think you're doing something wrong.
    Athlaos, Marc70 and Gunshot-6A like this.
  11. May 13, 2020 at 1:37 PM
    Chuy
    Lakeside, CA
    Silver Taco
    I didnt know that, till now. But no, i can easily beat you with my pancake compressor and air hammer - you may beat me to the first stud while it airs up :quickdraw:. For less than $200, you can get such a compressor, air hammer, and air hammer bits. It will come in useful for many other things.
    Wheel studs are not on the bearing assembly. They are on a hub that presses into the wheel bearing assembly. But if replacing the wheel bearing, it is easy to press out the studs all at once if you have a press.
  12. May 13, 2020 at 1:41 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    I'm good, thanks. Never needed an air compressor. And when I had one, I preferred not to use it. I'll save my money. And if you're smart, you buy the whole assembly, which has wheel studs. But I'm not spending $320 to replace wheel studs.
    Aside from that, I was primarily talking about install more than removal.
  13. May 13, 2020 at 1:54 PM
    Lgeekdws
    Lgeekdws Well-Known Member
    2015 Magnetic Grey V6 4x4 SR5
    I just did one on mine in 20 minutes (including jacking the truck up and pulling the wheel) with a hammer for removal of the broken stud, and an oversized nut for the lug nut to pull against and a breaker bar. Total cost was just shy of $7.
    Ugga dugga machines are for girly men! :transformer:
  14. May 13, 2020 at 1:54 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    You did just fine with what you have.
  15. May 13, 2020 at 1:57 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    I've actually used that method in the past, and there's a tool Lisle sells that's basically a spacer bearing. But the heat generated from pulling in with the threads, and the unnecessary stress in the threads never made me feel super confident. :cheers:
  16. May 13, 2020 at 2:00 PM
    Lgeekdws
    Trick is to not do it in one pull, tighten to "this is getting really difficult", back off and retighten and the stud will pull in a bit more, lather rinse repeat. No over torque or heat, and you don't kill yourself.
  17. May 13, 2020 at 2:27 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    Yea, I'm sure it's fine, I've been doing it that way for years. This $20 tool made it surprisingly easy, without even exerting much torque, so I thought I'd share. Hell, the torque was so little that my 12 year old daughter held the hub still with just her hands. :D:D
  18. May 13, 2020 at 7:45 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I liked it OP! :thumbsup:
  19. May 13, 2020 at 8:13 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    Pretty good idea.
    I used a c-frame press to replace mine.
    JeffBoyardee[OP] likes this.
  20. May 13, 2020 at 8:19 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Have you tried the Lisle tool on the Tacoma? My Lisle tool didn't fit, because the wheel stud is too close to the 108mm hub center register. Ended up pulling it in with an open-ended lugnut flipped around, so the flat face sits against the hub flange to keep the stud square. Just grease the threads to reduce friction, but be sure to degrease the threads after you're done.
