Changing over oil filter paper element to spin-on?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MaxTorque, Dec 29, 2022.
  1. Dec 29, 2022 at 6:59 PM
    MaxTorque
    MaxTorque [OP] Hope is not a strategy...
    Maryland
    cup holders
    Is anyone out there aware of an adapter kit to change over the oil filter assembly that uses the replacement paper filter element ( Toyo p/n: 04152-31090) and housing with a standard spin on oil filter? I'd like to go back to a simple spin on oil filter. No special wrench, no O rings to replace, no canister housing to clean. Ugg.
    BMH and BlackTRD4Me like this.
  2. Dec 29, 2022 at 7:01 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    There is a baxter spin on thread around here somewhere, just search for "Baxter" and it will pop up.
    shakerhood and soundman98 like this.
  3. Dec 29, 2022 at 7:04 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Paper provides better ISO filtration than spin on filter.
    But you do you lol.
  4. Dec 29, 2022 at 8:01 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    ^^^^^ this but, understand... this is not cheap. get the correct tools, (all of them), learn how to do oil changes with the cartridge, and embrace the suck. it really isnt that bad.
    these REALLY HELP! Ski
    https://www.motivxtools.com/collect...wrench-mx2301-funnel-mx2341-drain-tool-bundle
    usmc2msu, Chew and Rock Lobster like this.
  5. Dec 29, 2022 at 8:07 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  6. Dec 29, 2022 at 8:22 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    He's right about everything. The spin on adapters are ridiculously expensive and you're not saving that much time or convenience.
    It took me one change to figure out the paper, I had it down when I did my second service. It really isn't that bad.
    Speedbird and Chew like this.
  7. Dec 29, 2022 at 8:22 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    yeah, my other car looks like this, so originally i was fully prepared to do the baxter conversion to get the truck to be just as easy:
    but in all reality, i've changed it once now while using that kit, and it's honestly not terrible at all. my old ford ranger had a side-mount spin-on filter that dumped everything while trying to take it off. with the taco, between the central filter drain, and the housing to catch the rest, i didn't spill any. which is quite the accomplishment for me.
    i picked up a spare housing, so i can prep the new filter and housing in one shot, and deal with the old filter/housing away from underneath the truck to make it slightly easier, but otherwise, i'm not as offended with the filter setup on this truck as i thought i was going to be.
    i'm actually more irritated by the skidplate setup blocking access than i am any of the oil change portion...
    Amorak, blu92in99 and BkerChuck like this.
  8. Dec 29, 2022 at 8:38 PM
    skidooboy
    central lower mich
    Update to the trd skid plate, it has an access hole, so you dont have to remove the plate for changes. yes, it is some coin but, it looks great functions well off road, and gives you better access for services. Ski
  9. Dec 29, 2022 at 8:40 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    There is a spin on adopter, but If I were you, I’d stay far away from anything other than the OEM setup, as these engines appear to be very sensitive in that area.
    But that’s just IMHO, It's your truck, your money.
  10. Dec 29, 2022 at 8:51 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
  11. Dec 29, 2022 at 9:01 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    This is the easiest oil change ive ever done on a vehicle, ive never understood why others struggle with it.
    desmodue, Gatafly, 09 Redneck and 7 others like this.
  12. Dec 29, 2022 at 9:09 PM
    Benny22
    Benny22 Well-Known Member
    20Tacoma
    Crazy talk! I was very please on my first 3rd gen oil change. I thought, this is great, I no longer need to cut open the filter can for inspection.
    This system saves me time and mess.
    Tac2021 likes this.
  13. Dec 29, 2022 at 9:16 PM
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    I went with the baxter, well built, fits great, good customer service too. I work with orings a lot for my job and did put some oring lube on it before torquing it down, rubbing some oil on them would probably serve the same purpose...never a good idea to tighten down dry orings ;)
    Mine doesn't have the access cover (trd offroad 4x4), aside from having the trd vin and stickers it also has the trans skid plate...so not sure why mine is different, I've seen many folks who do have that door on the skid plate but for some reason mine is one of the ones that doesn't
    not easier than a spin on filter *shrug, the cartridge is impossible to be easier than that if we're being honest. if you like it fine, some don't...it's not that it's a "struggle" it's that the spin on is just easier and honestly...in my experience, better built filter. BUT it also allows for a larger filter element to be used which is another plus in addition to being faster, easier, and cleaner than the cartridge.
  14. Dec 29, 2022 at 9:19 PM
    JoeCOVA
    Joe
    Colorado Springs
    :rofl: im beginning to think youve never changed your oil.
    mutely, Lt. Dangle and hiPSI like this.
  15. Dec 29, 2022 at 9:23 PM
    Benny22
    20Tacoma
    I cant agree with that. I'd say there's no difference.
    And it's no harder to do, just more steps. I can do the oil change in less than 15 minutes. 3 of that is the R&R of the SR skid plate. If I had a spin-on, I'd guess about 14 minutes.
    For me, thats a wash.
    soundman98 likes this.
  16. Dec 29, 2022 at 9:24 PM
    JoeCOVA
    Joe
    Colorado Springs
    Dont forget the the oil drool you have to clean up that spills down the side of the block...
  17. Dec 29, 2022 at 9:24 PM
    Bcjammerx
    North East Texas
    why is that? I change the filter every 5k and the oil every 25k because I use amsoil. Every oil change my truck has had I did and before I used amsoil it was 5k for filter and 10k for oil...and only this last oil change did I switch to the baxter adapter and it's amazing...the cartridge filter was always mobile one and more than once the plastic keeper was cracked meaning oil was bypassing the filter so I do not like them. not sure what you're getting at, nothing I said would imply such an asinine observation. I've probably done more oil changes in one year than most do in a lifetime (it was my job for 3 years)...and I always do my own fluid changes...not just motor oil ;)
    09 Redneck likes this.
  18. Dec 29, 2022 at 9:25 PM
    Bcjammerx
    North East Texas
    I bought mobile one only filters, more than once the plastic keeper at the top was cracked when I took the old one off which means the oil bypassed the filter...they're garbage imo. I never said they were hard...but they certainly aren't as simple and easy as a spin on filter...just simple physics. fewer steps does equal easier/simpler, there's no bragging rights for doing something that's more involved when you don't really need to...it's just...dumb XD I'm older (40) so simpler is superior...plus the failed filters I've previously seen, it was a no brainer to install the baxter *shrug Go you for still using the more steps process I guess, not something to brag about but go ahead, I won't stop you lol
  19. Dec 29, 2022 at 9:26 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
  20. Dec 29, 2022 at 9:28 PM
    Benny22
    20Tacoma
    Unless your using Amsoil special bypass filter system, your just pumping dirt thru your engine. I see stuck oil rings in your future.
