Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Feb 8, 2023 at 10:18 AM
    #2741
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Not 100% sure with 3rd gen but 99.9999% sure you have electronically simulated lsd (using brake and engine control) and therefore do not need additive.
    If your lsd has clutch packs (unlikely) then you require additive.
  2. Feb 8, 2023 at 10:31 AM
    #2742
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    And torsen style LSD would as well (if anyone swapped to that?). Question, not a statement.
    TodayWasTHeDaY and VTi EG6 like this.
  3. Feb 8, 2023 at 10:31 AM
    #2743
    VTi EG6
    VTi EG6 Well-Known Member
    TX
    2017 Taco TRD Sport
    Gotcha, initial fluid change was done at the dealer due to some recall or some BS.
    About to hit 90k, so Amsoil/Mobile 1 should suffice. Looks like most of the gen pop didnt have any issues w these 2 brands.
  4. Feb 8, 2023 at 10:33 AM
    #2744
    TodayWasTHeDaY
    Russ
    Calgary
    Good question as I have a Truetrac. Friction additive is not recommended and in the past they recommended non synthetic diff oil over synthetic.
    daveeasa[QUOTED] likes this.
  5. Feb 8, 2023 at 10:34 AM
    #2745
    daveeasa
    David
    PNW
    Thanks. Guess I should change mine out.
    TodayWasTHeDaY likes this.
  6. Feb 8, 2023 at 10:38 AM
    #2746
    TodayWasTHeDaY
    Russ
    Calgary
    I believe no harm will come with running a torsen with synthetic but they recommend straight Dino oil for best performance.
  7. Feb 28, 2023 at 8:59 AM
    #2747
    WalterFeegis
    WalterFeegis Member
    2000 Pre Runner, 2WD, Auto, 2.7L, 3RZ-FE, 228,000 mi, No Mods
    None
    Of all the fluids I've changed so far, the stuff I drained out of the rear differential in my PreRunner was the nastiest. I took out 2 quarts and put in 3. I used a 15/16" socket and breaker bar to get both drain and fill bolts. Valvoline 75-90 synthetic. Took about 45 minutes mostly waiting for the goop to drain. Because it was so nasty and neglected, I may do it again in 5000 miles. I was able to get 3 full qts. in because I ran the truck up the ramps enough to allow a little forward slope.
    Black97v6MT likes this.
  8. Apr 13, 2023 at 9:45 AM
    #2748
    Trandoshan-Tickler
    Trandoshan-Tickler Well-Known Member
    Gene
    Fontana, CA
    2002 Toyota Tacoma Prerunner
    Glad I found this thread. Looks like I have a project to do for my 2002 Prerunner.
  9. May 3, 2023 at 8:16 AM
    #2749
    4trdsport4
    4trdsport4 Active Member
    2017 trd sport 4x4
    Pro comp wheels 7032 17x9 Falken wildpeak at3 265/65/17 RCI bed rack Trd pro style grill
    Just over $400 for all of this.
    Dealer quoted me 170 each ( front and rear diff and transfer case). Might just have them do it next time.
    What’s be best way to get fluid out of these cans and fill the diffs ?
  10. May 3, 2023 at 4:46 PM
    #2750
    montijo505
    montijo505 Moon soon?
    Rio Rancho, New Mexico
    08 4Runner SR5/ AKA The Great White Pig
    That stuff is stupid expensive
  11. May 20, 2023 at 9:00 AM
    #2751
    Jdilla83194
    Jdilla83194 Active Member
    Carlos
    Colorado
    2006 Radiant Red Tacoma TRD Sport, Access Cab
  12. Jul 6, 2023 at 12:50 PM
    #2752
    kbecerra
    kbecerra Well-Known Member
    2006 Red Tacoma Double Cab Long Bed PreRunner
    Eibach Pro-Truck Lift (Stage 1), Deaver AAL, JBA STD UCAs
    I recently did this in March 2023 and I do have a 2006 PreRunner with the LSD sticker. I used AMSOil Severe Gear 75w-90 with AMSOil's "Slip Lock" LSD Additive (just in case there was not enough LSD additive in the gear oil itself).
    First impressions: No noise and smooth just as before!
    **The previous owner did all his maintenance at the local Toyota Stealership so I called and they confirmed that Toyota's Genuine Gear Oil was used**
    UPDATE: As of July 2023, I've only driven my Taco for about 7k miles and there is still no noise and rides smoothly.
    FINAL THOUGHTS:
    I don't think spending the extra money for the AMSOil is worth it. I will be doing a Mobil 1 and LubeGuard LSD additive for the next 15k miles of maintenance. I will also update my results from Mobil 1 and LubeGuard LSD additive here on this post thread for anyone interested.
  13. Jul 6, 2023 at 12:59 PM
    #2753
    kbecerra
    @Jdilla83194
    To answer your question, "Which LSD additive you should use?"
    I would suggest either LubeGuard LSD additive or AMSOil Slip Lock.
    I'm going to lean more on the LubGuard LSD since you can purchase it at any "Advance Auto Parts" or "O'Reilly's Auto Parts"
    * Both LSD Additives are around $10 for 4oz which is the amount needed for our Tacos
  14. Sep 26, 2023 at 2:37 PM
    #2754
    3rdCoast4x4
    3rdCoast4x4 Active Member
    2015 Tacoma TRD Off Road
    OK, So '15 Tacoma TRD Off Road 4x4. Changed my front/rear diff and transfer case using Valvoline Synthetic SAE 75W-90 Gear Oil. Measured out all the oil per the volume spec. I went for a test drive and now my truck won't come out of 4H back into 2WD. Dash light flashes, and I can hear the servo behind the glove box clicking on and off, but it stays in 4H. I 100% used the right amount of fluid so now I am very worried I won't be able to get it back in 2WD. 4WD worked properly before the fluid change, Thoughts?
  15. Feb 17, 2024 at 11:32 AM
    #2755
    Audi403
    Audi403 Well-Known Member
    2015 Tacoma TRD Sport
    Did you get this sorted out?
  16. Jun 27, 2024 at 2:48 AM
    #2756
    bkrdave36
    bkrdave36 Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    I've read through about 20 pages of this thread and I am still confused.
    I've got a 2006 2wd Prerunner with the LSD. Last time it was serviced was exactly one Ice Age ago by the dealer as part of a full service (back when I went to the dealer for services).
    Its time I crawled under and made it fresh.
    Is there a general consensus on which LSD additive to use for the 2006 LSD rear ends?
    Thank you.
  17. Sep 19, 2024 at 12:59 PM
    #2757
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
  18. Oct 19, 2024 at 9:35 AM
    #2758
    SubZero_907
    SubZero_907 New Member
  19. Nov 19, 2024 at 7:35 AM
    #2759
    BrightonTaco
    BrightonTaco New Member
    As info, I changed rear diff fluid this past weekend and it was so much easier removing the spare tire. Also, I used a brass hammer to knock the fill plug a few times and that helped loosen it up to be removed.
  20. Nov 22, 2024 at 5:37 AM
    #2760
    Hillbilly Willy
    Hillbilly Willy Well-Known Member
    Central PA
    2005 blue Tacoma DCSB TRD Sport
    Definitely drop the spare tire down as it allows much more room to pour or squeeze the fresh oil into the fill hole.
    Also fwiw I have been using Amalie lsd additive that I get at local auto parts store in my 05 sport w lsd. It has not chattered since.
