Changed the oil, but friend got oil on belt.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trunkmonkey, Dec 30, 2009.
  1. Dec 30, 2009 at 11:25 AM
    Trunkmonkey
    Trunkmonkey [OP] Well-Known Member
    Kennesaw GA
    2009 Tacoma
    Ok well I was changing the oil and a friend was helping. Unfortunately, before I could tell him that there is a tube to drain the exes oil from the filter he unscrewed it, spilling oil all over the belt. Now my Tacoma squeals like crazy. We did the soap trick and it only last for a hour or so. Also got some belt dressing and it didnt do a thing.
    So I guess what I have to do now is change the belt and clean the pulleys really good and that should stop the squeals right? Is there a better rout to go cause I really dont want to have to replace a belt that only has like 3k miles on it.
    Thanks guys!
  2. Dec 30, 2009 at 11:31 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Normally I wouldn't recommend putting any 'dressings or cleaners' on the belts.... but...
    Did you try any brakleen? (or similar)
    You gotta clean the belt off and clean ALL PULLEYS. It might squeel for a bit....just give it some time after you clean everything. The belt has to reseat itself (for lack of a better term) and perhaps letting it run can burn off the remaining residue.
    Good Luck
  3. Dec 30, 2009 at 11:41 AM
    Trunkmonkey
    Kennesaw GA
    2009 Tacoma
    So are you saying, take it off clean everything then put it back on?
    And brakleen as in brake cleaner right?
  4. Dec 30, 2009 at 11:59 AM
    Mr_Torque
    Mr_Torque Buy the Ticket take the Ride.....
    Perkasie,PA
    '07 Tacoma SR5 4WD V-6 6 Spd
    MBRP Exhaust, 17" FJ Steelies w/Firestone AT's, Truxedo Lopro ,Timbren SES, Pioneer FH-X720BT HU & TS-C720PRS Component Speakers, TRD Quickshifter, Bilstein 6112/5160, Light Racing UCA, and Icon Progressive add a leaf.
    I'm not sure if brake clean is OK with rubber or plastic. Read the ingredients...some nasty stuff. What about Dawn dish soap or a waterless hand cleaner like Goop?
  5. Dec 30, 2009 at 1:11 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Before starting the engine spray everything down with brake cleaner. Let it sit for about 30 secs or so before starting engine. Start the engine and spray some more brake cleaner on the belt/pulleys as they rotate but exercise common sense. Watch your fingers and wear safety glasses to prevent fling from getting in your eyes. Grab the garden hose and spray everything down with the engine still running. Do this when the engine is cold to avoid all that water getting on your hot engine. Be sure to get the cleaner and water spray on the inside running portion of the belt as this is where the majority of oil will collect and cause you grief.
    I know brake cleaners and rubber don't mix, but it shouldn't be there long enough to cause any damage. If you are anal about it though, get some Castrol Superclean or similar engine degreaser instead.
    This may or may not work but worth a try if you don't want to remove your belt. Finish up with a little belt dressing and you should be good to go.
    P.S> Smack your buddy in the chops and tell him to wrench his own ride!
  6. Dec 30, 2009 at 2:45 PM
    Trunkmonkey
    Kennesaw GA
    2009 Tacoma
    Yeah, I took it to the car wash and sprayed some of there 'engine cleaner' on it and that didnt do much at all.
    So I will try, what about normal DAWN dish soap? Thats supposed to clean oil off right? I figure I will try it then was it off good then try the brake cleaner.
    Does any one have a good guide to removing the belt?
  7. Dec 30, 2009 at 2:54 PM
    aaronatl
    aaronatl ©1975
    Aaron Nrsa
    In A Big Country
    it hauls tostitos
    use electrical contact cleaner & compressed air
    or Isopropyl alcohol
  8. Dec 30, 2009 at 4:49 PM
    Trunkmonkey
    Kennesaw GA
    2009 Tacoma
    Update:
    I have tried putting dish soap and turning the truck on then spraying it out with a hose, that gave about 30 secs of peace and quiet... then the squeal was back.
    Then I tried contact cleaner and it didn't do any thing. I am all out of ideas.
  9. Dec 30, 2009 at 4:57 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Engine degreaser. It is a foam that sticks to the engine then you just rinse it off. Give that a try.
  10. Dec 30, 2009 at 5:02 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    Engine degreaser, dawn dish soap, carwash and a lot of elbow grease... you are going to need to get a rough bristled brush and scrub the crap out of every part you can reach. it is going to take a few trips before you get every thing but i would steer clear of brake cleaner.
  11. Dec 30, 2009 at 8:12 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i would take the belt off,find your friend and whip him with it.
  12. Dec 30, 2009 at 8:17 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    haha.
    Umm..if its cheap enough, just replace the belt? Shouldnt be more then $20 or so, and keep your OEM one as a spare..By the time you should "need" it, the oil should be gone.
  13. Dec 30, 2009 at 8:53 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Uh, IPA would dry the belt out :/ Pretty sure electronics cleaner would too....
    If dawn doesn't work... I'd probably just replace it or live with it :/
  14. Dec 30, 2009 at 9:06 PM
    russell@stone-creek.com
    russell@stone-creek.com Member
    Something's wrong. I spill oil on my accessory belt every time. Hate that oil filter on top.
    Anyway, I just wipe what I can and never hear ANY squealing.
  15. Dec 30, 2009 at 9:14 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    You know there's an attachment line for any left over oil to go into the catch, down the tube to where you direct it (aka, oil pan). Also, I always pull the filter off last so any oil not trapped in the filter drains out from below, works like a charm for me every time. (v6)
  16. Dec 31, 2009 at 6:37 AM
    Janster
    Jandy
    Lancaster, PA
    Did you clean off ALL the pulleys?
    Grease on the belt will get onto ALL the pulleys it drives. Then, it'll transfer back onto the belt if you don't clean off all the pulleys.
  17. Dec 31, 2009 at 6:40 AM
    Janster
    Jandy
    Lancaster, PA
    Underneath the filter, there's a rubber thing sticking downward. You gotta pull off that rubber piece (I had to use pliers). Go to any hardware store and buy yourself a 20" long piece of rubber tube that'll fit onto this fitting. Snake the tube down to your oil pan. Easy and clean.
    When you're done - take the tube off and put the rubber plug back on.
    Save the hose for next time.
  18. Dec 31, 2009 at 6:48 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    x2
    I use an empty powerade bottle, but once a friend was helping me with my recycling, saw the bottle in the garage and dumped it all over my lawn thinking it was old leftover grape powerade :facepalm::argue::smack:
  19. Dec 31, 2009 at 6:58 AM
    Janster
    Jandy
    Lancaster, PA
    You should've asked him.... DUDE? When was the last time you saw Chocolate syrup Poweraide?
  20. Dec 31, 2009 at 7:26 AM
    Trunkmonkey
    Kennesaw GA
    2009 Tacoma
    Well today I am going to take the belt off and clean the pulleys. We will see how that goes.
