Changed spark plugs while engine was warm?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GAtrd, Aug 13, 2012.
  1. Aug 13, 2012 at 5:59 PM
    GAtrd
    GAtrd [OP] Member
    Georgia
    11 TRD OR
    Hey, All
    My truck hit 30,000 miles and was ready for the spark plugs to be changed. Since it was my first time I had a mechanic friend help. He changed them while the engine was still warm. What are the odds that damage was done? :confused: I've been worried about my engine ever since. I hoping someone has some good news to help ease my mind. How can I tell if any damage was done? Thanks everyone!
  2. Aug 13, 2012 at 6:01 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    dosent matter, maybe torque specs could be off.. I wouldn't worry about it. I prefer to do my plugs with a cold engine, just so I don't burn the shit out of myself
  3. Aug 13, 2012 at 6:02 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I think you're paranoid. It's Georgia in the summer even when it's 90* out the engine will be warmer than ambient temp.
  4. Aug 13, 2012 at 6:05 PM
    GAtrd
    GAtrd [OP] Member
    Georgia
    11 TRD OR
    Okay Thanks
  5. Aug 13, 2012 at 9:33 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    If the plugs came out and went back in, your golden. I do it cold cuz I hate pain.
  6. Aug 13, 2012 at 9:42 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Always do it hot on customer vehicles. Prevents risk of seized spark plugs pulling the threads from the head. Yes, it is hot to the touch, but I am used to it, and have special tools to prevent burning myself. I can do a set on a V6 Tacoma in under 10 minutes.
  7. Aug 14, 2012 at 4:50 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Special tools like a socket set... :rolleyes:
  8. Aug 14, 2012 at 5:26 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    It's too bad this is the shit dealer technicians have to do to make a decent living. Is it possible to swap plugs in 10min? Sure. Can you check and adjust 6 plug gaps, get the right amount of anti-seize evenly on the threads, blow out the holes after removing the coil packs but before taking out the old plugs, and take enough time to be careful with a customer's vehicle in 10 min?
  9. Aug 14, 2012 at 5:33 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I thought anti-seize was a no-no?
  10. Aug 14, 2012 at 5:34 AM
    Pugga
    Massachusetts
    This is why I do the work myself. The other part of that is, you pay a technician to do a particular task, like change the oil or plugs, etc. They do just that and may not take the time to notice something else wrong with the vehicle like maybe a differential seal starting to develop a slow leak.
  11. Aug 14, 2012 at 5:41 AM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    ^^^exactly. Most of these people are good techs, but to feed the family they have to ram 'em in and ram 'em out.
    It's shitty.
  12. Aug 14, 2012 at 5:45 AM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
  13. Aug 14, 2012 at 6:32 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Amen to that!!
  14. Aug 14, 2012 at 6:36 AM
    mrw3685
    mrw3685 Well-Known Member
    TX by way of KS
    08 Prerunner TRD
    Maxtrac Spindles, Bilstein 5100s all around, set at .85, Allpro Expedition Leaf Pack, Procomp 7036 17x9, w/Nitto Trail Grappler 285/70/17, Extended Steel Braided Brake Lines, Red-Line Hood lift, Relocated Trailer Connection, Trimmed Front Fender.
    I actually prefer second and third degree burns from engine work, that's while you'll often find me running my truck for 30-45 minutes, then changing the oil...making a point to purposefully dip hands in the scalding hot oil. It's really just a technique I've adopted over the years, that, and enhanced pain compliance.
  15. Aug 14, 2012 at 6:38 AM
    Pugga
    Massachusetts
    Really?? :facepalm: You change oil when the engine is still hot because that's when all the contaminants are suspended in the oil. Otherwise they can settle and won't flush out with the oil.
    Also, if you're a competent mechanic, you shouldn't have your hands in the scalding hot oil anyways...
  16. Aug 14, 2012 at 6:50 AM
    fsbrain03
    fsbrain03 Well-Known Member
    And hands!
  17. Aug 14, 2012 at 6:53 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  18. Aug 14, 2012 at 7:03 AM
    mrw3685
    TX by way of KS
    08 Prerunner TRD
    It was sarcasm. It was either lost with you or I did a poor job conveying it, either way my bad.
  19. Aug 14, 2012 at 7:12 AM
    Pugga
    Massachusetts
    Oh... my bad :eek:
  20. Aug 14, 2012 at 7:25 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    I have read that many times over as I am due for a change. However, I have seen other threads where people say to stay away from the anti-seize. Some said none at all and someone said dielectric grease.
    Not really that mechanically educated to have an opinion as this would be my first plug change.
