Changed spark plugs, now runs rough - thoughts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CoZ, Sep 6, 2020.
  1. Sep 6, 2020 at 11:34 AM
    CoZ
    CoZ [OP] Member
    British Columbia
    2012 TRD sport DCLB
    OME front shocks and coils, billies & dakar rear, plasti dipped badges, custom dclb sliders, 285/75/16 duratracs on ion 16s
    Hey guys,
    Yesterday I changed the spark plugs out on my 2012 V6, fairly simple job. I have changed many spark plugs in the past on other vehicles and never had any issues. For some reason, now my truck has a slight shutter while driving, almost like a short miss-fire but no lights come on. Almost feels like its about to stall out for a split second, its sporadic and I only really notice it under load.
    Before I go taking everything apart again, does anyone here have any suggestions to what it might be? I have tried searching through the forums but its too specific of an issue to find for my self. I did change them to iridium spark plugs, but should that really cause this? I also changed the battery at the same time, but again, that shouldn't cause any issues...
    Thanks in advance for any help you might have!
  2. Sep 6, 2020 at 11:36 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Did you gap the plugs? Or were they pre-gapped?
    Alexely999 likes this.
  3. Sep 6, 2020 at 11:36 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Happened to me as well on my 2012, one of the plugs had a hairline crack. I waited until it threw a code to figure out which one -- it takes a bit longer than you might think, but it caught the right one.
    wilcam47 likes this.
  4. Sep 6, 2020 at 11:36 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Bad gap one or more plugs? Plug not fully torqued? Coil pack not fully seated? Contacts dirty?
    RedWings44 likes this.
  5. Sep 6, 2020 at 11:37 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Bad plug....isolate then replace with new plug.
  6. Sep 6, 2020 at 11:41 AM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    I went to buy Iridium plugs at the Toyota dealer.The parts guy,a tech and the service advisor all told not to use them.The truck won't run right.
  7. Sep 6, 2020 at 11:42 AM
    CoZ
    CoZ [OP] Member
    British Columbia
    2012 TRD sport DCLB
    They were supposed to be pre-gapped which is why I got them. Could not find a gapping tool anywhere except an old crappy wire one I already had, which I'm not sure I should trust. I think I might drive it a few more times, see if I can get it to throw a code before taking it all apart.
    Thanks for the suggestions, did not expect such quick input!
  8. Sep 6, 2020 at 11:42 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    If you are within the emissions warranty period, you have to change every 30K miles with standard copper plugs. Others will work, they will just void your warranty. It should run fine, but fresh copper plugs every 30k is cheap and easy.
  9. Sep 6, 2020 at 11:52 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    on my 3.4l v6 it was copper core plugs DENSO dual electrode every 30k miles but usually the plugs were in such good shape except the gap, id just regap and use them till 45k or more miles
  10. Sep 6, 2020 at 11:54 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Both of these were my first thoughts.
  11. Sep 6, 2020 at 12:07 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  12. Sep 6, 2020 at 12:23 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    First thing I would do is double check that no vacuum hoses were left or knocked loose. Second dbl check all coil pack connections.
    CaptainBart45 likes this.
  13. Sep 6, 2020 at 1:08 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    My bet is cracked porcelain on a plug
  14. Sep 6, 2020 at 1:16 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Wait till there’s a code and go after that plug.
  15. Sep 6, 2020 at 1:24 PM
    BillsSR5
    bill
    2014 SR5
    hopefully DENSO or NGK Plugs were used
  16. Sep 6, 2020 at 1:29 PM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Easy enough to pull, check gap, check plug, and reinstall. That way you can check if you put everything back right.
  17. Sep 6, 2020 at 2:18 PM
    JDubs83
    JDubs83 Member
    2012 Dbl cab SR5
    Pre-gapped plugs are easier to install and you can get them in other options than iridium. Most pre-gapped plugs are set at .042 and have to be adjusted for some make and models. Reset the gap or change to stock plugs and problem will be fixed.
  18. Sep 6, 2020 at 2:26 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No, this is wrong. It will not void the warranty.
    Iridium Plugs always come pre-gapped and they should not be adjusted as the iridium is very hard and very brittle. Check the gap and if it is wrong you take it back for a replacement.
    But I would go back to stock recommended Copper Plugs.
  19. Sep 6, 2020 at 6:52 PM
    Jarod888
    Jarod888 Well-Known Member
    Colorado
    2024 GMC 2500 AT4 Duramax Longbed
    For gapping them, just use a set of feeler gauges. I think I got mine from napa for 10$ or so. Gap to .040 to .041.
  20. Sep 6, 2020 at 8:13 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    com’on man.... Seriously? Stop posting incorrect fear mongering statements that are false. Sheesh.
