Changed AC components, light still blinks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trachito, Apr 13, 2022.
  1. Apr 13, 2022 at 6:06 PM
    Trachito
    Trachito [OP] Well-Known Member
    New Orleans
    2006 V6 Tacoma 6spMT
    My AC stopped working and the AC light blinked. Can't find the culprit. Here's my order of troubleshooting.
    - Checked the pressure and it was super low. Charged it with R134a with leak seal, still didn't work. Held pressure after that, though.
    - Swapped the relay with one of the surrounding relays, didn't work. Also ran power to the relay and it clicked, so assume it's working.
    - Bypassed the pressure sensor switch with a paperclip.
    - Changed the Compressor Pickup Sensor on the compressor. Light still blinks, compressor doesn't turn on.
    - Bypassed the relay and the compressor kicked on but after a while of driving, the compressor made a whirring sound.
    - Replaced the compressor, condenser, and expansion valve. Recharged the whole system with proper amount of PAG 46 oil and R134a and some dye.
    Light still blinks and the compressor won't come on unless I bypass the relay. I'm going to just order a damn relay, but man, I'm getting frustrated here. I have a 1600 mile road trip into the desert coming up in about 3 weeks.
    Anybody got any ideas???
  2. Apr 13, 2022 at 6:08 PM
    Bishop84
    Bishop84 Well-Known Member
    Just swap the relay with an identical one under the hood.
    How are you charging the system?
    Whenever I'm helping with 2nd gen tacoma a/c I always have a motto "It's the damn compressor" It's rarely the high/low switch, relay or controller. 99% of the time its the compressor. Just because its new doesn't mean its good.
    12TRDTacoma likes this.
  3. Apr 13, 2022 at 6:13 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What year and engine is your truck?
    Your gona have to check your wiring from the clutch relay and compressor to the A/C Amplifier, I can post the wiring diagram if I know your year and engine.
  4. Apr 13, 2022 at 7:13 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Unless he has changed trucks. It’s an 05’ w/ 4.0:thumbsup:
    https://www.tacomaworld.com/threads/wtb-05-6-speed-shifter.158465/
  5. Apr 14, 2022 at 6:15 AM
    Trachito
    New Orleans
    Yup, 2005 4.0 6spMT.
  6. Apr 14, 2022 at 6:17 AM
    Trachito
    New Orleans
    Swapped the relay this morning. Didn't work. There are only 2 more culprits that I can think of: The pressure sensor and the sensor at the evaporator. After that, I'm out of ideas.
    This is insanely frustrating. I'm thinking of taking it to a shop or dealer, but I don't really know if they'll be able to help, and I don't want to pay for nothing.
  7. Apr 14, 2022 at 6:33 AM
    Trachito
    New Orleans
    Just tried bypassing the pressure switch with a paperclip. Still nothing, so the switch is probably fine.
    So now I'm down the the sensor that's on the evaporator coil. Gonna have to figure out how to test that. I found this thread on how to change that without removing the entire inside of the truck, but I don't want to just keep changing parts:
    https://www.tacomaworld.com/threads/a-c-performance-during-highway-cruise.446835/page-3
    Can anyone think of what else it can be so I can add it to the list of things to test?
  8. Apr 14, 2022 at 6:39 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What kind of compressor did you replace with? Either Denso or factory?
    This issue is either at your climate control unit or it's the AC itself. As stupid as the AC setups are on these trucks I'll say it's the compressor first, even though you replaced it already.
  9. Apr 14, 2022 at 6:49 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The flashing A/C light is when the A/C amplifier does not detect a speed signal from the compressor lock sensor after commanding the MG CLT relay on.
    Possible causes are:
    Open or shorted wire(s) in the lock sensor circuit
    Bad lock sensor
    Internal problem in the compressor
    Open or shorted wire(s) to the MG CLT relay
    Failed A/C amplifier
    You will need to check your wiring
    The MG CLT relay should have power on pins 2 and 5 when the blower switch is on, the A/C amplifier grounds pin 1 to turn it on.
    Also check the wiring between the lock sensor and A/C amplifier.
  10. Apr 14, 2022 at 6:49 AM
    Trachito
    New Orleans
    I'm adding the AC amplifier to the list of things to check.
    It's a UAC brand. I got it from RockAuto and it's a popular brand for this truck.
  11. Apr 14, 2022 at 6:52 AM
    Trachito
    New Orleans
    By lock sensor, I'm assuming you mean the compressor pickup sensor. That's been replaced. Compressor is new. I'll check the AC Amplifier and and then check wire continuity. Thanks, man.
  12. Apr 14, 2022 at 6:54 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes the wiring diagram calls it the lock sensor but service info calls it a pickup sesnor, it's the same thing.
    Trachito[QUOTED][OP] likes this.
  13. Apr 14, 2022 at 6:59 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The A/C amplifier is behind the glove box on top of the HVAC housing.
  14. Apr 14, 2022 at 8:40 AM
    Trachito
    New Orleans
    Ok, found it. Ordered a used one for $75.
    Oddly, the bracket part of the amp's housing is cracked and it was just hanging there. Not sure what would have caused that.
    I'm also having issues with the blower fan speed, in particular speeds 1-3, but not max. I'm already familiar with this problem. The connector that controls the fan speed has a burned connection at one wire. I'm going to clean that up and hope removing the residue on that connection fixes that problem. I think it's just affecting the connection, not necessarily a broken part.
    I'm starting to consider taking apart entire sections of the truck and refurbishing the wiring and several parts. It'll be cheaper than buying a new one, plus I've had this one since I bought it used in 08 and have done quite a lot in this truck.
  15. Apr 14, 2022 at 8:45 AM
    TnShooter
    Deogee
    STOCK
    You might as well replace the resistor too. That’s the most common cause of what you are experiencing. Settings 1-3 do not work but High is fine. It’s because the resistor is bypassed on High.
    If the connection at the blower is burned. It wouldn’t hurt to check both the fan and resistor connections. I’d probably check the connector for the switch as well. It’s not hard to get to.
    Trachito[QUOTED][OP] and Dm93 like this.
  16. Apr 14, 2022 at 11:11 AM
    Trachito
    New Orleans
    well, I'll be damned. Only $23 for the resistor and connector. I think I'll do that.
    https://www.amazon.com/Dorman-973-5...t=&hvlocphy=9051904&hvtargid=pla-493007214156
  17. Apr 14, 2022 at 11:15 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    TnShooter likes this.
  18. Apr 14, 2022 at 12:52 PM
    TnShooter
    Deogee
    STOCK
    @Jimmyh knows the updated part numbers I think.
  19. Apr 14, 2022 at 1:56 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  20. Apr 14, 2022 at 2:03 PM
    TnShooter
    Deogee
    STOCK
    Thanks Jimmy.
    Jimmyh[QUOTED] likes this.
