Change headlight bulb
Discussion in 'Lighting' started by SupremeDeluxe, Mar 28, 2012.
  1. Mar 28, 2012 at 7:11 AM
    SupremeDeluxe
    SupremeDeluxe [OP] Member
    Virginia
    Coma
    How do you change the low beam headlight bulb? The one on my driver's side is out, is there a sticky or write up on all this? I hope this is a quick fix. Thanks.
  2. Mar 28, 2012 at 7:20 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You need a new headlight bulb, you can't change just the low beam. go to a local auto parts store, get a pair of H4 bulbs and replace the bulb. DO NOT TOUCH THE GLASS! You should probably replace both bulbs, if one blew, the other probably isn't too far behind.
    To change the bulb, unplug the plug at the back of the headlight (the one going to the headlight bulb), remove the rubber boot, release the retainer clip holding the bulb in place (note the bulb orientation so you install the new bulb the same way) and do the reverse with the new bulb. I've found it helpful to remove the battery and unbolt the windshield washer fluid reservior to give more room behind the headlight. Otherwise, you need tiny hands for the install.
    JayRolla likes this.
  3. Mar 28, 2012 at 12:29 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    to help not touch the bulb, wouldn't be a bad idea to use a disposable glove, GL
  4. Mar 28, 2012 at 9:26 PM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    I have an 11 the lights are the same on the 05 no? All I did was unplug the bulbs then twisted counter clockwise(I'm pretty sure counter clockwise) and they slide right out. Reverse steps for installing.
  5. Mar 28, 2012 at 9:53 PM
    nammer
    Nam
    Bradenton, Florida
    hmm i guess they designed them differently, never knew that, cause mine has the rubber boot and the retainer clip as well, no turning for me
  6. Mar 28, 2012 at 9:55 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    05'-11' s should be the same but I dont think you need to turn them.
    Same here, I just had the metal wire retainer clip that snaps into place and holds the bulb, no turning for me neither.
  7. Mar 28, 2012 at 9:57 PM
    nammer
    Nam
    Bradenton, Florida
    maybe NIGHT is talking bout fog light?
  8. Mar 28, 2012 at 9:59 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    If thats the case then yes, with the fog lights you do need to twist to get those off.
  9. Mar 29, 2012 at 5:34 AM
    Pugga
    Massachusetts
    All of the other bulbs just twist and pop out (fogs, marker lights and I believe the turn signals), the headlights are the only ones that use a retainer clip and a rubber boot. I wish they just twisted in, they'd be a lot easier to install!
    sfcacique likes this.
  10. Mar 29, 2012 at 6:24 AM
    Night
    Canada
    Must be, changed them out a while ago. Sorry about that.
  11. Mar 29, 2012 at 6:33 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    As Pugga said, change them both. Nothing is worse than changing one and losing the other a week later. If you touch the glass with your bare hands clean the bulb really good with an alcohol wipe or similar but the best method is to wear some gloves.
  12. Mar 29, 2012 at 3:01 PM
    nammer
    Nam
    Bradenton, Florida
    this might be just me, but I wouldn't change both, i know the rational is that they have both been on the same amount of time, and life should be similar, but our headlight bulbs can last for a lot of years, and the process is really simple, i think it would just be a waste, it could be another 5 years or so til that other bulb blows :notsure:
    JJ Diablo and everymanalion like this.
  13. Mar 29, 2012 at 3:03 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Nothing is worse than that? :laugh:
    It takes under a minute to change a bulb. I'd just change one. I had one go out and the other one lasted another year.
  14. Mar 29, 2012 at 3:06 PM
    dexterdog
    Oly WA
    2012 F150
    It is more for piece of mind than anything. If both bulbs have been through the same lifespan and one fails chances are great that unless the failure is due to something other than normal usage the other will fail soon. It is not about if it's about when and where.
  15. Mar 29, 2012 at 5:25 PM
    Night
    Canada
    I'm with ya! You're there anyway changing one might as well as change both. Halogen bulbs don't have that long of lifespan anyway. And its just annoying to have one go out while you're out and about. I hate when people only have 1 head light or tail/brake light :goingcrazy:
  16. Mar 29, 2012 at 6:24 PM
    Pugga
    Massachusetts
    If it's been a few years and one just blows (no water in the housing and not caused by an impact) then I'll replace both. If the dipstick Toyota engineer didn't put the battery right behind one headlight and the windshield washer reserior behind the other one, then I'd wait til the other one blew because I'd be able to change it on the road. With the crappy way our engine bays are set up, I can't change the headlight bulbs in the dark on the road. I see your point though. I usually swap the both and keep the one that was working in my glove box as a spare if I ever really needed it.
  17. May 26, 2014 at 2:47 PM
    Seid
    Seid New Member
    When changing a headlight on my 2005 Tacoma the retaining clip fell off, and I can't figure how to put it back on. There is a video online showing a Toyota headlight change that shows the clip being captured by a screw head. In that video the hinge portion of the clip is narrow, and mine is wide. There appears to be a boss with an undercut that should retain the clip, but I cannot get the clip to stay on when I try to lock the clip on the other end.
    Any advice? Pictures of the installation would be really helpful.
  18. Mar 8, 2024 at 4:36 PM
    MikeDeason
    MikeDeason Well-Known Member
    Forget the retaining clip. kept popping off every time I tried to push the boot back on. You don't need it. The bulb is secure without. Battery side it went smoothly with the clip but wwf side the clip kept popping off. On principle, I refuse to remove a battery or fluid reservoir to change a freaking bulb
  19. Mar 8, 2024 at 4:52 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Zombie thread resurrection man.
    That being said, the clip *is* actually needed. Very likely the reason jt kept popping off is that you have the bulb oriented incorrectly in the socket, which means you will end up with an incorrect beam pattern and/or a "left/right" beam instead of high/low.
    H4/9003 type bulbs have three prongs, with one being purposefully larger than the other two so the bulb can't be installed (easily) in an incorrect orientation. The retainer keeps it locked in place and doesn't allow it to bounce.
    Yes, it's annoying to finangle the bulb down around the battery and washer fluid reservoir, but you should always make sure its oriented correctly and secured properly.
    Too Stroked likes this.
  20. Mar 9, 2024 at 8:30 AM
    CaseyJones
    CaseyJones Active Member
    Toronto
    09 4x4 Dbl Cab TRD Sport
    I had no luck with the clip either. I think it bent because no way I can latch it. Bulb seems secure in the boot.
    Bulb configuration looks like the design of a grade 9 engineering project.
