Champion CC1998 4 Runner radiator in 2001-2004 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rldanie, Jul 27, 2019.
  1. Jul 27, 2019 at 9:37 PM
    Rldanie
    Rldanie [OP] Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    Anyone running a champion cc 1998 4 runner radiator in there 2001-2004 Tacoma?
    I heard that because the hood is shaped different on the 2001-2004 vs. the 1995.5-2000 it we’ll work.
    Anyone using this radiator?
    I understand how things work with the CC1778
    Heard there where 2-3 people that used the CC1998
  2. Jul 27, 2019 at 11:27 PM
    robblacktpre03
    robblacktpre03 03 Tacoma Restore time
    Rob
    San Francisco, CA
    03 black pre runner
    k&n air filter, throttle body spacer, all pro UCA, 07 gun metal TRD FJ rims, blacked out interior trim
    Following, might need a new radiator soon
  3. Jul 28, 2019 at 1:35 AM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    Rldanie[OP] likes this.
  4. Jul 28, 2019 at 1:40 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    All I can add is I installed a Radiator made for the mid eighties 3.0 in my 2000 Tacoma it was just a matter of welding the brackets from the Tacoma to the radiator
  5. Jul 28, 2019 at 7:00 AM
    Rldanie
    Colorado
    Says it will clear,,
    https://www.tacomaworld.com/threads...3-4-supercharger.543859/page-17#post-19884462
    Just for reference for others with the 2001-2004 hoods to be able to use the 4 runner radiator.
    What shroud did you use, 2001 Tacoma 5 speed, Tacoma auto, 4 runner auto? You have a 5 speed?
    What lower radiator hose did you use? 2001 Tacoma 5 speed, Tacoma auto, 4 runner auto hose?
    @1997tacomav6 i used a 96-02 4runner/95-04 auto Tacoma shroud. 3.4 Tacoma’s with an automatic use thesame radiator as 96-02 4Runner. As for the lower radiator hose I used the stock hose in my 2000 v6 5 speed. it puts tension on it, but it reaches. My 2004 Tacoma is an automatic so I used the stock hose with no issues. So the end result is if you get a shroud and lower radiator hose for a 3.4 4Runner,regardless of if it’s a 5 speed or automatic 4Runner, or 3.4 automatic Tacoma, and you’ll be set. I initially had this setup in my 2000 v6 supercharged 5 speed and it worked great. The only modification you need to make to the shroud is shave the lip at the top and bottom edges down so it sits flush against the tank. As for 95-00 Tacoma’s you need to clearance one of the hood crossmembers for the radiator cap so the hood will actually shut. As for skid plate I was running a budbuilt on my 2000 and it cleared. I’m running the stock on my 2004 with no issues
  6. Jul 28, 2019 at 7:02 AM
    Rldanie
    Colorado
    Thanks!
    This was helpful
    Timmy the toolman is awesome
    Used he video to install my S/C...no problems
    Thanks again!
  7. Jul 28, 2019 at 7:04 AM
    1997tacomav6
    Denver
    Yea personally if you go with the champion radiator you should get the 4runner radiator.
    He says you need a 4 runner shroud, not sure why tho
  8. Jul 28, 2019 at 7:05 AM
    Rldanie
    Colorado
    Confirm it works!
    However, Champion and all suppliers are out of stock at the moment
    I will Call Monday to see if they will continue making it
  9. Jul 28, 2019 at 7:40 AM
    1997tacomav6
    Denver
    @00_5VZ did this swap, he can chime in
  10. Jul 28, 2019 at 10:25 AM
    00_5VZ
    00_5VZ Dumbest smart guy you’ll ever meet
    Rob
    Thornton, CO
    2004 DC TRD, S/C, Impulse Red Pearl
    TRD S/C, URD 7th injector, Deck plate mod, gray wire mod, 2 low mod, magnaflow cat back exhaust
    I’ve done the 4Runner champion radiator, it’s been in 2 different trucks. The first one was my 2000 v6 5 speed. I had to get a fan shroud from a 4Runner cause a 5 speed Tacoma shroud doesn’t cover the entire radiator. I put that same radiator in my 2004 Double cab Tacoma, and the fan shroud works fine. All 4Runner’s and automatic Tacoma’s use the same fan shroud. 5 speed Tacoma’s fan shrouds are shorter. If you do this swap in a 5 speed Tacoma, I’d recommend the longer shroud and lower radiator hose
  11. Jul 28, 2019 at 11:44 AM
    Rldanie
    Colorado
    Awesome!
    Now all I need to do is find one in stock..lol
    1997tacomav6 likes this.
  12. Jul 28, 2019 at 2:14 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Just for the info I have never run a fan shroud most times they are gone to I get the vehicle
    I guess if I lived in Death Valley it might make a difference .
  13. Jul 28, 2019 at 2:58 PM
    robblacktpre03
    Rob
    San Francisco, CA
    03 black pre runner
    More than likely going to need this, fittings are all corroded
  14. Jul 28, 2019 at 3:32 PM
    Rldanie
    Colorado
    You can still find them on Jegs
    $283
  15. Jul 28, 2019 at 4:02 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    I'm interested in a Champion radiator but the failure rate has me concerned
  16. Jul 28, 2019 at 5:20 PM
    1997tacomav6
    Denver
    The Champion has NO rubber bushings designed into its radiator.
    So I’m thinking if you put a rubber bushing in between the radiator and the front cowling, radiator support it might be the trick and there would be some play or flex available.
    You might have to drill out the radiator nut hole so the bushing tail section can
    Fit in the radiator support
    The bushings are made by Hillman at Lowe’s
  17. Jul 28, 2019 at 5:38 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Hopefully somebody with a champion rad will use bushings and keep us all posted
    1997tacomav6[QUOTED] likes this.
  18. Jul 28, 2019 at 8:09 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
  19. Jul 30, 2019 at 8:43 AM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    Would this also cool your tranny better ? Does it have a trans cooler built in ? Does anyone running the champion radiator notice a difference in temperature for both engine and tranny?
    I also agree with adding the bushings if it does not come with em. The OEM has them and it allows flex. I would assume longer bolts could be needed though.
