chains on front of taco/4runner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Steve-VO, Jan 6, 2010.
  1. Jan 6, 2010 at 5:08 PM
    Steve-VO
    Steve-VO [OP] Member
    WV
    09 TAcoma
    Hi all. I have 06 4runner awd and 09 taco 4wd and live on a very steep unpaved road in WV that can ice up even after plowing from the melt freeze cycle. This winter so far has been an adventure. All the tricks on the trucks available (4lo in 1st gear, ABS, DAC, etc) will not at times prevent loss of traction and control if it's really bad conditions and i must get out. Chaining rear only can lead to loss of control as front wheels slide while back keeps pushing (just had that). Chain the front only and the vehicle can swing around into 360 spin (neighbor's experience). Chaining all 4 is a great solution, it really works. V-bar chains on back and SCC Z6 cables on front. Front chain problem is that even with the super thin SCC Z6 (only 1/4" clearance required) I can hear the tick tick of the connector on the back wire of the chain. Nothing else rubs. It may be contacting the upper control arm. Checking the cables after use shows no noticable wear, steering is fine, cables stay tight. Running stock size tires and wheels (17" on both trucks). Elevation drop is about 500' over 3/4 with very steep spots. I park at bottom and take unchained 4runner or taco (varies) to get to civilization.
    Any thoughts or concerns about the contact with uca given use i described? Anyone have a similar experience and solved it? Might this occasional use on front cause a problem one day with uca? Or not to worry? How tough is the uca? I'd think rocks hit it occasionally.
    Thanks for any input.
  2. Jan 6, 2010 at 8:21 PM
    S-M-R-T
    S-M-R-T Well-Known Member
    Unless the rubbing is so bad that you are scoring the UCA I don't see any problems. Keep the chains as tight as possible and monitor closely for any wear.
  3. Jan 7, 2010 at 5:56 AM
    Steve-VO
    WV
    09 TAcoma
    Thanks for your relpies. Studded is a thought. Not sure about WV law on studded tires. Not sure I want to make one truck to be a only a shuttle vehicle all winter. I'm going to play with where I move and tighten down the cables to get the connector higher up on tire. The SCC rubber tightener degrades and loses some tension strength so maybe a metal spring tensioner will help. Looked at moving the wheels off with insert but seems expensive and heavy-handed for my needs. Any other ideas much appreciated.
  4. Jan 7, 2010 at 6:24 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  5. Jan 7, 2010 at 10:03 AM
    Steve-VO
    WV
    09 TAcoma
    Thanks for the tip on snow straps. Might be enough in a pinch.
  6. Jan 7, 2010 at 10:28 AM
    SportyTuRD
    SportyTuRD Well-Known Member
    i feel like you would want like 5 straps on each tire...one little contact patch while the other 98% of the tires slips?
  7. Jan 7, 2010 at 10:59 AM
    VTDave
    VTDave Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    I run low profile v-bar chains on front and rear with no issues. I think the key is to keep them tight and properly centered in order to stop rub. I run some fasteners across the face of the wheel to keep the chains tight.
    But I agree with others: the tap-tap sound shouldn't be a problem unless you see scoring. Just remember that you shouldn't drive fast or far with chains/cables on.
  8. Jan 7, 2010 at 11:01 AM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    You'd definitely need to shut off VSC and traction control to run like that, otherwise the computer would freak out on you.
    Is it even possible to shut off all that stuff on the tacos? On my mazda I have to hold the stability control button down for a few seconds and everything shuts off (only way to succesfully perform either a burnout or a CA smog inspection) 'till the engine is turned off. Haven't tried that yet in the truck, though.
  9. Jan 7, 2010 at 11:19 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    i dont think you wouold just use one...maybe 4 at a minumun. but after looking at them a little closer they are only "velcro" straps... Im thinking that they would fly off the tire very easy
  10. Jan 7, 2010 at 11:40 AM
    lightfire
    lightfire Well-Known Member
  11. Jan 7, 2010 at 11:44 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
  12. Jan 7, 2010 at 12:58 PM
    S-M-R-T
    I would definitely start with winter tires. I was assuming that you were already running some and just looking for extra traction. Chains have their uses but are only a band aid fix for occasional use. If you are driving this road and others regularly then I think spending the money on tires is a wiser choice.
    If only part of your driving is on winter roads then you could always go no-studded. The best studless tires are as good these days. I would look at the Michelin X-ice Latitude or Bridgestone Winter Dueler first.
    Also don't forget to call your road maintenace office and complain until they the road sanded better.
  13. Jan 8, 2010 at 4:48 AM
    Steve-VO
    WV
    09 TAcoma
    Thanks again all. I am the road crew most of the time, ha ha. Steepness of road can require a small 'dozer or backhoe (with chains!) to plow in really big snows. Pulling the plasticoated wire ring on the Z6 cables as tight as poss. against back of tire and using an extra rubber tensioner reduced the tapping sound quite a lot. The contact point is now on the flat part of the uca above the rubber bushing. No wear on the back ring of cables really noticeable, uca feels smooth. I would not use this to drive any distance on a road, just to brief need to descend and climb this hill so not to lose steering direction control. Probably get wheel spacers if I had to regularly drive a distance in awful ice. I have to say the Toyota design up front with no clearance for chains is puzzling because the late model Taco and 4runner really are great machines for driving on this mountain in bad conditions.
  14. Jan 8, 2010 at 7:50 AM
    HankB
    HankB Well-Known Member
    Hank
    near Chicago
    06 Preruner TRD Off Road
    bone stock
    My thought as well. The difference in traction between all year rubber and what they use on winter only tires is pretty amazing. I usually leave the snows off until the first snow just to remind me how much difference they make. (No, not lazy or anything like that. ;) )
    Unlike aggressive tires that get traction in deep snow via tread pattern, these get traction on ice due to the rubber compound and that seems like what you need for an iced over road. Nokian Hakkapeliittas are supposed to be among the best, but you pay for that too. I have Hankook Icebear W300s which sacrifice a bit of ice traction for better manners on dry pavement. Another good brand to look at is the Bridgestone Blizzaks.
  15. Jan 8, 2010 at 1:42 PM
    Steve-VO
    WV
    09 TAcoma
    Update: Got the SCC Z6 cables to clear on the taco, will always rub a touch on the 4runner (fatter uca than taco). So the taco is elected the hill truck. Have v-bar or diamond chains to use for the back if I know ice/deep snow is coming. Have the SCC cables for front and back in the truck in case caught short - like returning from the big city post-storm (it happens enough). I found SCCs easy and quick to put on and take off. 4 wheels of SCC cables works quite well but real chains on rear make a big diff. with ice underneath. Thanks to all again. Winter tire idea sure is worth investigating too.
  16. Jan 8, 2010 at 1:49 PM
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    Pictures?
    :worthless:
    you guys probably know exactly what this looks like, but to a Houston.. I haven't got a clue. :D
  17. Jan 8, 2010 at 1:58 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    What did you do to get them to clear?
    I don't understand these newer vehicles... On my Dad's new 2010 Subaru Forester if he were to put on chains (front or back) it would void his warranty.
  18. Jan 9, 2010 at 6:15 AM
    Steve-VO
    WV
    09 TAcoma
    Sam in TX here's a pic of 4runner a few weeks ago before we got 20" snowfall. Put chains on night before. Back are v-bar ice biters, front SCC Z6 for limited clearance vehicles. Toyota manual says chains on back only but not why. Why is the uca clearance in front. Got cable clearance on Taco front by pulling the cables tight against back and using an additional runner tensioner (tirechain.com) to add tension on the cables. No big deal and works fine. Toyota manual does not threaten to void warranty. I found there are very expensive chains from Thule that do not go around the back of the tire so clearance is not an issue.
  19. Jan 10, 2010 at 5:40 AM
    SamSter0077
    Katy, TX
    Thanks for the Pics, That's a lot of snow!:eek:
