Ceramic coating
Discussion in 'Detailing' started by Stripedbass, Feb 6, 2018.
  1. Feb 6, 2018 at 12:43 PM
    Stripedbass
    Stripedbass [OP] Well-Known Member
    2015 double cab
    Do all ceramic coating have to cure for at least 24 hours . Because I don't have a garage to put my truck in ?
  2. Feb 6, 2018 at 3:10 PM
    ShineTech
    ShineTech Active Member
    2017 Tacoma TRD Off-road
    Preferably yes but as long as you don't have rain or heavy fog/mist you should be good. If you can apply the coating as early in the day as possible that would be good so it can have time to cure a bit more. Many coatings will completely cure within 7 days or so unless you are using UV heat lamps.
  3. Feb 6, 2018 at 3:41 PM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    ....adding that to the shopping list.
  4. Feb 7, 2018 at 6:50 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Optimum Glosscoat is what I use. No garage. Optimum say cures in 1 hour time as far able to drive in the rain.
  5. Feb 7, 2018 at 11:44 AM
    killerken
    killerken Well-Known Member
    Philadelphia
    09 toyota tacoma dbl cab trd
    Access LE Cover Toyota Factory Nerf Bars Dynolock Tail Gate Lock
    Use AMMO Reflex and skip the ceramic coatings, Easy to apply, layer-able, cured in 2 hours then you can either apply more AMMO Reflex or you can apply AMMO Skin. The best part is you don't need to polish your paint to remove AMMO Reflex.
  6. Feb 7, 2018 at 12:08 PM
    ace96
    Western KY
    Why would you remove a coating anyways? That is the whole point of a coating. Don’t get me wrong Ammo makes some good stuff but failing to see the logic. Glosscoat is ridiculously easy to apply. I find it easier to apply than an easy on/ easy off wax.
    ShineTech likes this.
  7. Feb 7, 2018 at 12:41 PM
    ShineTech
    Gloss Coat is not bad at all. I've seen it last close to 1.5-2 years before the water stopped beading on the horizontal areas and as mentioned super easy to apply. You can maintain Gloss coat with opti-seal to prolong it's life.
    ace96 likes this.
  8. Feb 7, 2018 at 3:47 PM
    killerken
    Philadelphia
    1) Coatings don’t last forever. At some point you will need reapply a coating. In order to do this you will need to polish off any risidual coating on the car as most Coatings on the market are only layerable when the coating is initially applied
    2) Coatings do scratch, they are not built proof. If you do get a scratch then you will need to polish off the coating and reapply.
  9. Feb 7, 2018 at 4:55 PM
    ace96
    Western KY
    Coatings can be layered. Glosscoat is marketed as layerable. I have used wax, Adams Guard and Gloss, Optimum-seal layered over Glosscoat months after application.
    Any product can get a scratch. What do you do to fix them? Coatings are just a better layer of protection. No product lasts forever. Besides when it comes time to remove the coating or reapply it is time for a polish anyways.
    WebberLander likes this.
  10. Feb 7, 2018 at 7:38 PM
    killerken
    Philadelphia
    Ace96,
    I think you are missing what I am saying.
    Yes you can put a wax or sealant ontop of Glasscoat but can you put more Glass coat ontop of Glasscoat 6 months later?
    With Ammo Reflex I apply two coats initially as my base then I use AMMO Skin as my wear layer 6 months later I can go back and apply another layer of AMMO Reflex.
    The only limitation I have is I cannot apply AMMO Skin one week and the try to apply AMMO Reflex the following week without first going a doing a alchol wipe first.
    Regarding no coating last for ever, I agree 100 percent as I stated this in my earlier post. But why use a coating that I need to polish off.
    With AMMO Reflex I can just use a heavy Alchol wipe to remove the coating if I need to fix a scratch, but the idea is to not to have to polish again just maintain the Reflex by adding another layer ever 6 months and keep it topped with skin.
    Please understand I am not bashing Coatings but to many people think that coating are the one stop protection that will last for years and that is not true.
    And for me if I don’t have to polish a car ever year or two the more original paint I can keep on the car.
  11. Feb 7, 2018 at 8:28 PM
    ace96
    Western KY
    I think we both are misinterpreting. Fact is coating > sealant > wax.
    Yes, I have applied another layer of Gloss Coat after a couple of weeks. Did this on the wife’s 4Runner. Not an issue as long as the paint has been cared for properly.
    Try leaving bird shit on paint protected by sealant...it will etch. Have not had that issue with Glosscoat.
    Yes, you can get years out of a coating With proper care. I am only polishing every 2 years now. Car is easier to maintain than with a sealant and I have tried several...Adams paint sealant, Megs NXT, Collinite, Klasse to name a few.
    I was previously anti-coating till I tried one. After realizing how much easier it made my life, no way will I ever go back to a sealant.
    oscolivar1 likes this.
  12. Feb 8, 2018 at 3:05 AM
    killerken
    Philadelphia
    Ace96,
    Thanks for sharing the information on Gloss Coat, did not know you can layer it after the initial application. If this is the case then it works in this case just like AMMO Reflex which is a coating of some sort that can be layered both initially and later.
    Then you but a sacrafacial layer ontop of the coating which can be a sealant or a wax. For this I use AMMO skin and I put this on once ever two months. Take 30 min to apply and wipe off.
    So up to this point we are basically the same.
    Where Glass Coat and AMMO Reflex is different is Glass coat needs to be polished off where AMMO Reflex can be removed with a Really heavy IPA wipe down. Granted it could also be polished off but not needed.
    Another benefit of AMMO Reflex is that I can apply it to Paint, & Plastic as it remains flexible. I don’t know if you can do this with Glass Coat so please let me know.
    Regarding coatings, I have tried CQuartz UK, nice product but not as easy to apply like AMMO. I was getting ready to try Kamakzi next but maybe I will give Glass Coat a try.
    ace96 likes this.
  13. Feb 8, 2018 at 3:16 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    It’s almost time to do my 07. May look into this ammo line
  14. Feb 8, 2018 at 3:25 AM
    Matt3400
    Matt3400 Well-Known Member
    2007 Lexus GX470
    They want to make sure it isn't seeing moisture in that 24 hr period. I didn't have garage space for my truck after applying Cquartz UK so I put a layer of Reload over it a couple hours later.
  15. Feb 8, 2018 at 4:56 AM
    killerken
    Philadelphia
    Matt3400,
    Like you, I had to apply reload as I don’t have a garage and when I detail for clients I am mobile and some of my customers also don’t have a garage.
    I like the CQuartz UK + Reload, but what I don’t like is the flash rates and how temp and humidity have such a impact on this.
    I have been reading great reviews on Kamakazi system so I may check this out. But for my trucks and all my high end customers AMMO NYC products are my goto products
    Kolunatic likes this.
  16. Feb 8, 2018 at 5:01 AM
    killerken
    Philadelphia
    Kolunatic,
    Regarding AMMO product. You will not be disappointed at all. Let me know if you have any questions and I will be glad to help+ Larry the inventor of this product line has a ton of videos on You Tube plus he will answer phone calls and emails when you have questions. Which makes his customer service one of the best in the industry, along with a Meguiars.
    Larry is one of the elite detailers of the industry and has been trained by The Godfather’s of the industry like Kevin Brown aka Mr Buff Daddy, Jason Rose, MIke Stoops, etc.
    Kolunatic and Matt3400 like this.
  17. Feb 8, 2018 at 5:04 AM
    Matt3400
    2007 Lexus GX470
    Yeah, wasn't a fan of UK application. I'll be switching either to Opti gloss coat or Gyeon Mohs. Heard good things about the Kamakazi system and Ammo. I can justify the prices on that stuff for daily drivers.
    I follow both Larry and Esoteric car car on social media/YouTube.
  18. Feb 8, 2018 at 5:39 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Thanks
    I need to do a deep clean,polish etc.
    I did detailing a lifetime ago,all by hand.
  19. Feb 8, 2018 at 5:55 AM
    killerken
    Philadelphia
    Hey Matt,
    If you try Gyeon, let me know what you think about it.
    I haven't done to much research on this product.
    Opti Gloss Coat seems interesting to try, I will need to talk to Matt Moreman (Obsessed Garage - another great You Tube Channel) about this as I know he went trough Optimum Training and I know he currently uses Kamikaze Coatings.
    I have a company car that I use as my test vehicle for all new products,which is great as this car gets abused with both Highway and city mileage and doesn't get washed as often as my Truck.
    One other key thing if you ever try AMMO Reflex is you can continue to use the same applicator over and over again as long as it doesn't become dirty.
    I learned this from Larry when I was with him last spring and this helps save on product.
    When you are done applying AMMO Reflex for the first time take the applicator and store it in a zip lock bag, the next time you go to use the pad the pad is already primed and when you add more AMMO Reflex it reactivates the AMMO Reflex that is already in the foam pad. This is great and will extend the bottle of AMMO Reflex.
    Matt3400 likes this.
  20. Feb 8, 2018 at 5:58 AM
    killerken
    Philadelphia
    Detailing by hand, I don't miss this at all.
    Doing a deep cleaning, paint correction and polish is fun though as when you are completed the final product looks amazing and normally looks better then when the truck came off the factory line.
    Kolunatic[QUOTED] likes this.
