Ceramic brake pads
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zerofear66, Apr 25, 2019.
  1. Apr 25, 2019 at 8:39 PM
    Zerofear66
    Zerofear66 [OP] Well-Known Member
    2022 TRD Off Road Lunar Rock, 2014 Tundra Crew Max TRD 5.7L
    What's the benefit of using them?
  2. Apr 26, 2019 at 9:00 AM
    Glamisman
    Glamisman Well-Known Member
    higher fade resisitance.
  3. Apr 26, 2019 at 9:13 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    They gooder
  4. Apr 26, 2019 at 10:40 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I didnt notice any big difference between my Akebono ceramics and oem pads. Maybe more dust coming off the ceramics. If there is a difference, its that they seem to bite better when I first start to depress the pedal, but that could be from new brake fluid or just my imagination.
  5. Apr 26, 2019 at 12:05 PM
    underaroof
    underaroof ember
    Eastern Sierra
    2004 Xtracab 4x4 V6 TRD
    They bite more when new, but they feel about normal after a hundred miles or so. What ever kind of pads were put on my truck are dusty as hell though.
  6. Apr 26, 2019 at 1:06 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    ceramic pads are mostly for performance applications, like a sport or street racing car. They can withstand high temperatures (very useful for intensive use and against heat-induced brake fading) and are quieter than metallic brake pads. Their only downside is in freezing cold sub-zero temperatures, they don't perform as well
    That does not mean you shouldn't put ceramic them on your daily driver, you will just not really see a difference
  7. Apr 26, 2019 at 1:15 PM
    OneWheelPeel
    Phoenix, AZ
    Its kinda like saying "Synthetic oil is only good for high performance cars". Thats the old motto.
  8. Apr 26, 2019 at 1:17 PM
    xxmagpulxx
    xxmagpulxx Well-Known Member
    Reno, NV
    TRD Off-Road DCSB Blazing Blue
    You get to change your rotors more often, but they do have a higher tolerance for heat.
  9. Apr 26, 2019 at 2:05 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Meh, it costs the same, if not more to turn rotors these days versus replacing them. :notsure: May aswell replace them at every brake job.
  10. Apr 26, 2019 at 2:32 PM
    OneWheelPeel
    Phoenix, AZ
    Dang what kind of rotors you buying???
  11. Apr 26, 2019 at 2:39 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Brembo blanks. But you can get the autozone brand for cheaper. I personally wouldnt turn a rotor even if it was the cheapest option out there. Not alot of places do it anymore, and those that do usually involve some highschool kid that doesnt give a rats ass about the quality of his work, then they overcharge for it. You only gotta do brakes once every few years, may aswell replace the rotor while youre in there.
    genghis71 and ToxicTwin like this.
  12. Apr 26, 2019 at 2:54 PM
    OneWheelPeel
    Phoenix, AZ
    That's simply not true. What brembo blanks are even close to the cost of turning rotors?
  13. Apr 26, 2019 at 2:56 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Brembo blanks are more expensive. But you can get cheapos at the parts stores that would be more in line with turning your old ones.
  14. Apr 26, 2019 at 3:07 PM
    OneWheelPeel
    Phoenix, AZ
    I've turned tons of rotors. I'd much rather turn rotors rather then using cheapos. Plenty of high end cars claim you cant turn rotors and have to replace. The tacoma is not one of these vehicles. As long as the rotor is in spec as far as depth, why would you toss perfectly good rotors? - And worse, replace them with cheapos.
  15. Apr 26, 2019 at 3:13 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Dunno where you live, but I live where rotors rust to your hub quick. Getting them off usually means destroying them with a bfh. And its nice to get some rust free ones on to replace them.
  16. Apr 26, 2019 at 3:19 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    OEM pads are ceramic. Akebono would be my 2nd if not equal choice. I recall reading somewhere that Akebono manufactures the OEM pad for Toyota but can’t verify that.
  17. Apr 26, 2019 at 3:19 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    LoL Akebono ceramics are one of Toyota's OEM options. You may have had them to begin with.
  18. Apr 26, 2019 at 4:09 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Doubt it. The oem pads required shims, the akebonos didnt. I wanna say sumitomo makes the oem 1st gen brakes from what Ive read. Akebono may be used on other models however.
  19. Apr 27, 2019 at 9:16 AM
    Zerofear66
    Thanks for all the replies! I went with drilled rotors with Raybestos ceramic pads. Parts geeks has some pretty smoking deals on rotor/pads packages. I paid 140 shipped.
  20. Apr 27, 2019 at 10:40 AM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    My Toyota parts guy has said Akebono is trd for years you can get them for less than half price online, at Carquest they are $59.00..
