Center diff lock disable
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ofrim, Jan 24, 2019.
  1. Jan 24, 2019 at 2:50 PM
    Ofrim
    Ofrim [OP] New Member
    Hi!
    I have a 3rd gen Tacoma 4x4 sport and as you know when going to4x4 (high or low) center diff locks .. I was wondering is it possible to subject this lock to switch ? I need this because sometimes i want to carry heavy stuff on a windy road going uphill so you want to be on 4x4 ( preferably low) but with open diffs to avoid redundant stress on the drivetrain.
    Cheers !
    Ofri
  2. Jan 24, 2019 at 2:51 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW!
  3. Jan 24, 2019 at 2:58 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    No. There is no center differential. Just a transfer case that connects the output to both drive shafts. It's all or nothing.
  4. Jan 24, 2019 at 5:46 PM
    Ofrim
    Thanks for your replay ...
    if you have any other idea’s you are welcome to share
    Ofri
  5. Jan 24, 2019 at 6:06 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Your diffs remain open regardless on drive mode for your sport. You want to swap to 4lo on the fly?
    There's a reason for needing to be in neutral before switching to low gearing.
  6. Jan 24, 2019 at 6:10 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Buy a 4runner that's full time 4wd.
    You have part time
    If you're just after lo range maybe consider the 2lo mod.
  7. Jan 25, 2019 at 9:41 AM
    Doggman
    Alabama
    2017 TRD OR MT
    As @Joe23 mentioned you could attempt the 2Lo mod. It's not easy as far as I know though. Could also remove the front driveshaft. Obviously that's inconvenient but maybe it's worth it for your use case.
