CEL came on oil control valve replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slazz29, Aug 20, 2019.
  1. Aug 20, 2019 at 1:55 PM
    Slazz29
    Slazz29 [OP] Well-Known Member
    Colten
    1995 Tacoma 2.7 3.5 inch offsets black
    Barnes 4wd diff cover bull bar kc lights toolbox smoked tail lights 3 inch leveling kit ion alloy 3.5 inch offsets 31x10.50r15 gt's
    So my 2007 yota 4.0 is at 220k miles and my check engine light just came on. Took it straight to auto zone and had it scanned. The code was for the oil control valves. Not sure if it was the left or right but I just bought both of them and what a swift kick in the ball bag that was...300$. Any advice or threads on replacing them? Any info would be greatly appreciated.
  2. Aug 20, 2019 at 2:28 PM
    Slazz29
    Colten
    Location pics of the passenger side and drivers side would be really appreciated
  3. Aug 20, 2019 at 4:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  4. Aug 20, 2019 at 4:07 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  5. Aug 20, 2019 at 4:35 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I don't see the reasoning of replacing both if you are unsure of the exact codes. The codes should display as bank 1(passenger side) or bank 2. From some of past threads, some had success cleaning the OCVs or OCV filters. Are you experiencing any idling or accelerating issues?
    b_r_o likes this.
  6. Aug 20, 2019 at 4:47 PM
    Slazz29
    Colten
    It just showed up on the scanner as both? I just assume change them both now. As all of us know at 220,500 miles if I fix one and it shuts the light off the other is going to be right behind it. The truck idles good every once in a while it gets a little vibration almost when it idles down. Accelerates pretty normal once in a while it has a little not hesitation but you feel a little something. Hard to explain but I got the truck at 185k so o dont know how it ran new. I think it runs very well.
  7. Aug 20, 2019 at 4:48 PM
    Slazz29
    Colten
    Where are the filters located? 2 or just one? I just need to pull off the intake to get to them right? And they just pull out?
    jojotoo likes this.
  8. Aug 20, 2019 at 4:49 PM
    Slazz29
    Colten
    But the scanner showed them both. There was 2 different part numbers the computer said needed replaced. Left and right
  9. Aug 20, 2019 at 4:59 PM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    I did this job on my 2005 at 500,000 km. Both valves were broken and came apart when I pulled them out. Bit of an oh shit moment but a pair of pliers pulled the rest of the valves out. Pretty much as was warned.
    I think there was a thread here that I followed. Should be able to find it using the search function.
  10. Aug 20, 2019 at 5:02 PM
    Slazz29
    Colten
    Ok that's what i was looking for but cant find any how to's or step by step. I might as well clean the oil control filters too right? Is there 2 filters also? If anyone has the step by step please let me know
  11. Aug 20, 2019 at 8:00 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Oil Control VVT Valve Locations:
    Oil Control VVT Filter Screens locations.
    The filter screen looks like a bolt head.
    Black97v6MT, Wattapunk and TnShooter like this.
  12. Aug 20, 2019 at 8:10 PM
    Bishop84
    Bishop84 Well-Known Member
    They seize in like a bastard, they can easily break on removal, so only remove if you have replacements.
  13. Aug 20, 2019 at 11:04 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    should of done a little investigation before buying 300$ worth of parts. What are the chances that both valves failed on opposite sides of the motor at the same time? Just because a component is listed in a code description doesn't mean that component has failed.
    Id start with fresh oil and a filter if it hasn't been changed in a while
    craigs1 likes this.
  14. Aug 21, 2019 at 4:58 AM
    craigs1
    craigs1 Well-Known Member
    2007 4Runner Limited, 4.0L
    Post the specific error codes reported by the scanner, e.g. P0018 or whatever.
    b_r_o likes this.
  15. Aug 21, 2019 at 6:05 AM
    Slazz29
    Colten
    I'll have to get the exact code today when I go pick the new valves up. I use pennzoil full synthetic high meager and a k&n filter. Have 2500 on that change now so I dont really think it needs changed yet?
    b_r_o likes this.
  16. Aug 21, 2019 at 6:06 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Definitely pull the screen filters and spray them out with cleaner after doing the valves.
  17. Aug 21, 2019 at 6:14 AM
    craigs1
    That's a fine oil and one of my favorites for DOHC engines given the high concentration of moly antiwear compound they include. If you've been using this or similar synthetics, and changing the oil at ~5K mile intervals, it's unlikely that you have OCV valve or filter problems. Get the error codes.
    edit: I can't speak for the K&N filter either good or bad. The big nut on the case is handy on some engines. I only use Toyota YZZD3 filters for the 4.0L engine.
  18. Aug 21, 2019 at 6:21 AM
    Slazz29
    Colten
    Now these filters there is 2 of them right? How do I clean them just with some air or water? Take the bolt out and they come out?
  19. Aug 21, 2019 at 6:24 AM
    Slazz29
    Colten
    Thanks for the help guys. I am going to do both valves today and take out the screens and clean them. I'll get the codes today and put them on here in case this doesn't take care of the issue
    Black97v6MT and b_r_o like this.
  20. Aug 21, 2019 at 6:32 AM
    craigs1
    They are a plastic and wire mesh basket design, one on the side of each head and difficult to see. Driver side requires removal of the alternator. If you remove them, get new crush washers from the dealer and torque them to spec or you'll have leakage. Attached is a pic of a new filter for reference.
    However...I'm skeptical that these or the OCVs are your problem. Need the codes. Throwing parts is a hard way to diagnose.
    Black97v6MT likes this.
