CB recieving great, transmitting bad
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Skyent, Jun 1, 2019.
  1. Jun 1, 2019 at 2:47 PM
    Skyent
    Skyent [OP] Member
    Jeff
    2019 Tacoma TRD 4x4 offroad
    Hi - anyone have an idea to the following. I tested my CB with my friends just 20' away. I have a compact uniden. I received him perfectly on channel 4. He said he could not understand me at all when I would transmit. I checked the SWR and channel 1 is about 1.5, 19 is about 1 and 40 is about the same. Mount is grounded. I can't find anyone in Simi Valley or in the area that can help me service CB's. Help please.
  2. Jun 1, 2019 at 2:52 PM
    Kheiron
    Kheiron @Koditten Pirate Radio member #003
    Kevin
    Powell, WY
    2017 OR DCSB QS
    Kenwood d710g, high speed pheasant mod
    The ham thread might give you better answers. Even though CB and the amateur bands operate on different frequencies the antenna tuning operates on the same principles.
    That being said we will need a little more info on your setup.
    The graveyard shift thread also has some ham guys. I am a ham operator, but my antenna knowledge needs some work. I am sorry I can’t be of more help.
    @medic2230 @m603holden @gixxerphil @koditten
  3. Jun 1, 2019 at 2:55 PM
    Skyent
    Skyent [OP] Member
    Jeff
  4. Jun 1, 2019 at 3:16 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Did you buy the unit new or used? Could be a bad Mic.
  5. Jun 1, 2019 at 3:20 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Try it a 50 yards. If you get too close reception can stink.
    Early Man and vicali like this.
  6. Jun 1, 2019 at 4:21 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Do you have aftermarket lights, fog lights, or led products?
    Kheiron likes this.
  7. Jun 1, 2019 at 4:26 PM
    Skyent
    Skyent [OP] Member
    Jeff
    New on Amazon.
  8. Jun 1, 2019 at 4:28 PM
    Skyent
    Skyent [OP] Member
    Jeff
    No, not yet. But I have bought the hidden bumper LED 32" and (2) Ditch lights and will get the 50" light bar. Does LED lights interfere with transmitting? I wish I knew of a CB store in my area...a thing of the far past.
  9. Jun 1, 2019 at 4:29 PM
    Skyent
    Skyent [OP] Member
    Jeff
    Hmm, never really thought of that. Okay I can try that. Thanks
  10. Jun 1, 2019 at 4:30 PM
    daddy_o
    Bossier City, La
    Did you read the reviews on Amazon? I just looked and right off the bat I saw about 4 or 5 with transmitting issues.:eek:
  11. Jun 1, 2019 at 4:38 PM
    m603holden
    Marteeen
    New England
    It can. No real way of knowing until it's installed. I wouldn't worry about it. But if you get it working a d it randomly stops working, check the led.
    As far as your current issue I'd try a farther distance. And then if that doesnt work there are guys on here who can trouble shoot it for you.
  12. Jun 1, 2019 at 4:47 PM
    Skyent
    Skyent [OP] Member
    Jeff
    I usually do, I must have just figured it should be good. I should return it and buy a different one. Any suggestions? It has to be the same type of compact though.
  13. Jun 1, 2019 at 4:54 PM
    Skyent
    Skyent [OP] Member
    Jeff
    I just ordered a replacement and to return the one I have. If the same problem occurs again, it may be something else. If it doesn't it will work. Its just for trails when off-roading with others and we want to communicate. But I am glad you noted that, lesson learned. Thanks daddy-o - helpful.
    daddy_o and Kheiron like this.
  14. Jun 1, 2019 at 5:13 PM
    daddy_o
    Bossier City, La
    Good luck with a replacement. At least it's an easy deal with Amazon. I have had to send two items back with Amazon in the past, and it was a very simple process.
    You are welcome, I was concerned when I saw more than 2 reviews with the same problems. Hope you get a good one next.
  15. Jun 1, 2019 at 5:21 PM
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    Where's your antenna mounted? I seriously doubt you're getting about 1 for SWR on ch 1. That's the theoretical best SWR possible, ridiculously good for a truck - most people aim to be below 1.5 for their SWR. I'm content with 1.5 - 1.8 across the board for SWR on my Taco, since my antennas are on a roof rack.
    If you can receive but can't transmit, you may have a short. Are you sure you connected the mount right? I had a buddy that hooked up his CB to a mirror mount but accidentally shorted the antenna RX/TX (center prong) to ground by not including the washers that came with the mount antenna. He could receive fine short-range, but couldn't transmit at all.
  16. Jun 1, 2019 at 5:44 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    This is an antenna problem.
    Make SURE the connections are good. Crap from China is not tested and uses poor materials and craftsmanship. Check the connectors and the connections. Look for malformed parts and kinks etc.
    Check for ground faults.
    If the antenna is a no ground plane type and you bonded it to the frame you may be shorting out on transmission but the frame picks up on receive.
    If the antenna expects a bonded frame make sure it is.
    In either case match the antenna frame ground to the instructions.
    Try to tune the antenna to a different SWR, and more importantly to see if the SWR moves in the direction you expect as you tune it. This can indicate line loss or impedance issues stemming from a short within the cable. Test the cable for shorts with an ohm meter.
    I assume everything is dry, as wet connectors or cables that have gotten wet internally at now junk.
    Try a different antenna and or cable, especially if the cable is kinked or bent at too narrow a radius.
    Try your antenna with a different unit.
    If you have thus ruled out the antenna and connectors, then the unit is the suspect. Again check the power connectors, as it may be chinacrap giving low voltage enough to power on but having trouble keeping up transmitting at 2-4 watts. Make sure the PTT feels smooth and clean. Again if either of these ever got wet you may want to start over.
    west4x4 and max_o like this.
  17. Jun 1, 2019 at 6:58 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I'm having the same issue with mine..still haven't gotten around to checking some things other members suggested to me. But, mine works fine until I add my bed rack and roof top tent. Can receive great but when I transmit other cannot understand me as well. If you do figure it out, post back here so I know what I should try first when I get around to troubleshooting mine :thumbsup:
  18. Jun 2, 2019 at 12:03 PM
    Skyent
    Skyent [OP] Member
    Jeff
    Thanks
  19. Jun 2, 2019 at 12:05 PM
    Skyent
    Skyent [OP] Member
    Jeff
    Will do. A bit confusing, the SWR is good, mount is correctly grounded. Should work with no issues. But, once I get it all figured out, I will share.
  20. Jun 2, 2019 at 12:11 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Calling all HAM nerds!!
    @max_o what are your thoughts?
    max_o likes this.
