CB Radios
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PaidtoPlay08, Mar 4, 2020.
  1. Mar 4, 2020 at 6:52 AM
    PaidtoPlay08
    PaidtoPlay08 [OP] Well-Known Member
    Oregon
    2008 Tacoma DCSB
    Fox 2.5 Coilovers Fox 2.0 Rear shocks SPC UCAs Dakar Medium Duty Leaf Pack 285/70/17 BFG KO2s Method 316 17x8.5
    Anyone know anything about CB radios or have an opinion on one over another. Looking for some offroad/emergency communication reviews or suggestions.
  2. Mar 4, 2020 at 7:14 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Unless you're using one with friends or a club that uses them they're all but worthless these days. If you still want one, look at one of the compact models with the handheld controller that can be stored out of the way. You want a tuned antenna up as high and unobstructed as you can get it, i.e. the center of your roof. Find your local ham club, they'll have an SWR meter, and get them to help you tune it.
    Better yet, just get your ham operator's license, technician is easy to get, and opens up a lot more options. Another option is a cell phone booster.
  3. Mar 4, 2020 at 7:23 AM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    RyanDCLB likes this.
  4. Mar 4, 2020 at 7:28 AM
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    I've got the Cobra 75WX ST, its compact. I've zip tied the little power "box" under my seat. For the antenna, I've got a generic 4' antenna with a tuneable tip. I used the Firestik fireeye CB Coax Cable so I could have the cable come off the whip at 90 degrees, and I sneaked it between the taillight and the body. The mout is a firestick universal door jam mount flipped upside down, and screwed in beside the tailgate.
    it all works well. on a good day I can ( barely ) reach my buddy a few miles away when we are both in our driveway's with the squelch turned off. On the trails it works quite well. He's been way out of sight, and I was still able to communicate.
    I will say this about CB's. He's had waaaay less problems with his "non ground plane" Firestick then I've had with my traditional setup. I find that the braided cable in my spring keeps breaking then my TX distance is terrible while the Non Ground Plane Aantenna always has good TX.
    as far as CB Being "dead" that's not the case in my area, lots of local truckers on it, I chat some times, but mostly listen for traffic advice.
    I am getting my HAM license this year, and plan to do the who ARPS thing with above mentioned buddy, but at the same time I'll probally keep a CB in the truck for when I run with others who don't have HAM.
    Clear as mud?
    Bastek likes this.
  5. Mar 4, 2020 at 7:46 AM
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    I have Uniden cmx760 (which is similar form factors as Cobra 75) mounted in my truck. It's a good radio for what it is. Kinda expensive for its performance, but I guess I'm paying for convenience factor here. Radio is connected to Browning BR-180B antenna, that is installed on trunk lip mount on my hood.
    All together this setup works out good on the trails but now I'm intrigued with that Non Ground Plane Antenna that @D2. mentioned in previous post
  6. Mar 4, 2020 at 9:59 AM
    TerraNerva
    TerraNerva Well-Known Member
    Chip
    Central Arkansas
    Ummm....Tundra
    I love how people are so quick to say CBs are worthless -- just go Ham. CBs are far from useless. They provide citizen coms on long trips, many have NOAA capabilities, and with the right antenna set up they are great for trail coms in a group, or monitoring other groups while in popular runs, passes, and off road areas. My unit doubles as a handheld so I can spot out of the vehicle if necessary. That being said, the range is very limited as compared to Ham. What do vehicles you run with use? How much will you actually use a Ham? For most offroaders and trail runners, CB is more than enough, no test to take or specialized equip to buy. You have to evaluate what works best for you.
    The Uniden Pro Series has several units, are super compact and affordable. I run a Midland 75-822 because I can easily move it from my Tacoma to my Land Cruiser.
    Bastek and ImMrCrash like this.
  7. Mar 4, 2020 at 10:51 AM
    D2.
    Dan
    Nova Scotia, Canada
    @Canoehead
    the NGP antenna is a "kit" the cable has to be a NGP cable, and you can't modify the length. once Canoehead ditched his faulty radio, he's never had an issue TX'ing decent distances.
    I now want to go this route for my CB, but Canoehead and I both want our HAM....
    https://www.rightchannelradios.com/...products/firestik-ngp-antenna-3-way-mount-kit
    Below is the mount I used.
    https://www.rightchannelradios.com/.../products/vertical-door-jamb-cb-antenna-mount
    Look at Post #42
    https://www.tacomaworld.com/threads...nd-quantity-advice.207219/page-3#post-4945570
    This is what I did, but I did not cut my mount, I simply slid it between the bed metal and the sheet metal. There was enough room. Then I took the tail light out and put the cable in that hole and bolted up the light again. its snug, but fits. Been that way for about 2 years.
  8. Mar 4, 2020 at 12:01 PM
    PaidtoPlay08
    Oregon
    2008 Tacoma DCSB
    Thanks for the info guys. I am looking for one pretty much just for off road use with buddies and weather. If I had a CB, Can i also communicate with people who have hand helds? Just not any licensed radios correct?
    Bastek likes this.
  9. Mar 4, 2020 at 12:11 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    No. Cb is a deficated 11 meter band, frs/gmrs/ham will not be able to communicate with you and vice versa unless they have a cb.
    Gunshot-6A likes this.
  10. Mar 4, 2020 at 12:40 PM
    TerraNerva
    Chip
    Central Arkansas
    Ummm....Tundra
    You can communicate with CB hand helds, but not other bands, or 2-ways. Both have to be to dedicated as will.i.was said.
    will.i.was and Gunshot-6A like this.
  11. Mar 4, 2020 at 2:26 PM
    gr8t_white_taco
    gr8t_white_taco Well-Known Member
    Ethan
    2015 Tacoma TRD Off Road
    Stage 9 Icon suspension, full CBI aluminum armor and skids, prinsu roof rack, vtx wheels, dorkel, etc...
    I have the president bill CB with a fire stick antenna. It's a tiny little setup and gets pretty decent range. I have a hill out on my property and if I park on the top I can talk to my buddies who live 10 miles away, (as the crow flies).
  12. Mar 4, 2020 at 2:37 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    I think the name of the game for “emergency” comms is to have a couple options with you. I personally wouldn’t rely on CB alone for an emergency. Out of cell phone range I’d probably want a HAM handheld or such also. You are allowed to use them without a license in a true emergency situation.
    TerraNerva and ryfox0276 like this.
  13. Mar 4, 2020 at 4:02 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    This. I wouldn't want to rely on my CB for emergencies. Best case you're looking at a 12 mile range. I'm often well out beyond 12 miles of anything or anybody. Look into a cell booster, emergency beacon, or gmrs/ham radio for this.
    That being said, a CB can be fun and useful if you're buddies also run them.
