CB radio configuration help needed on Taco - Uniden Bearcat 880
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vijay, Nov 2, 2015.
  1. Nov 2, 2015 at 2:39 PM
    vijay
    vijay [OP] Well-Known Member
    ****not specific to Tacoma*****
    I installed a Uniden Bearcat 880 CB radio few months back. Since then I have not heard a single truck to truck CB ramble on radio. I hit the "Weather" button and the local weather lady goes on rambling for hours. So the Antenna etc is set up correctly. There is a construction site near by my office and the semi trucks neatly line up at designated spots(they are far between). I assume they are using CB radio to talk. However, I do not hear or have not heard any chatter since I installed it...kinda silly but what channel(I'm using 19 now) can I switch to make sure my CB is in working order?
  2. Nov 2, 2015 at 2:44 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    You might want to stop and ask just what channel they use
    Take it to a CB radio shop to get checked.
    you don`t have your squelch turned all the way up.
    With cell phones more and more drivers and not using the radios.
    I have not put one in a truck for quite a while.
  3. Nov 2, 2015 at 3:08 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    The CB channels (1-40) all must be below 27MHz. The NOAA weather transmission is at 162MHz. It doesn't even use the same antenna(s) and instead uses an internal narrow-band FM antenna. So just because you can hear the weather lady is no indication at all that your CB is operational. It's like a separate radio inside the CB package.
    I use my CB all the time and along the Interstates hear plenty of chatter. Also it is required for an off-road permit in my state and also required by the 4WD club I wheel with.
    I agree with Wyoming09 though that you need to probably get it tuned. You could buy "Firestick" brand antennas that are tunable and you could tune them yourself. But since tuning is pretty much only required once might as well go into a shop and have it done, cost is usually $40 - $100 depending on the complexity of your setup. You may need a new antenna(s)?
    Elevated likes this.
  4. Nov 2, 2015 at 4:42 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Did you tune your radio? You cannot just install it and have it work. You need to tune it with an SWR meter and ensure a proper ground. I like doing it myself rather than paying someone, SWR meters are not expensive. Plus if you change antennas (they do break on the trail, even the flexible ones eventually) you will need to re-tune. Also, do any of your friends have CBs you can test it against?
    Info if you are not familiar with CB tuning:
    http://www.wearecb.com/how-to-tune-cb-antenna.html
  5. Nov 3, 2015 at 12:53 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Funny the OP does not say anything about installing a antenna !!!
    Or the adventure of running the coax cable with those huge ends into the cab.
    I wonder !! That would explain why the weather channel works and not the CB.
  6. Nov 3, 2015 at 8:50 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It is way better IMO to run the cable into the cab without the connector attached and then solder the connector on in the cab.
  7. Nov 3, 2015 at 1:52 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Some people can`t solder !!
  8. Nov 3, 2015 at 4:12 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Hopefully an antenna was installed. Running the CB without the antenna is No Bueno.
    Op IF you have a CB antenna installed, turn the radio on to channel 19, the squelch all the way down, hit the trigger on the mic, and say "breaker, can I get a radio check". Repeat a few times if no one answers. If you can't get someone telling you "it's on", then it's time for a trip to the radio store.
    Whatever you do, don't say "good buddy"
