CB Radio (Cobra 29) Mod & Mount in Center Console
Discussion in 'Audio & Video' started by DDD, Aug 25, 2009.
  1. Aug 25, 2009 at 4:28 AM
    DDD
    DDD [OP] Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I recently was given a Cobra 29 LTD Classic CB radio from a driver at work. Most of the veteran truck drivers at work have used the Cobra 29 Classic for over 20 years.
    Here is my problem:
    This radio is giant.
    There really isn't anywhere to mount it where it can be hidden but still be accessible and functional when I need it. I have seen other people's solutions to mounting this radio, such as LonghornTaco mounting it behind the console and MonkeyProof mounting it inside the cup holders. Those are both great ideas, but I did not want my radio to take up any room in the cab (leg room) and I wanted my radio hidden from passengers. I don't want to cut up the cup holders and loose the use of them. And, most importantly, I need the radio in a spot where I can access it easily while driving. I really like Ccoorreeyy's idea of using the glove box, but the Cobra 29 is too large to fit.
    Here is the solution I came up with:
    I decided relocate the face of the radio in the center console and secure the body (main circuit board, housing and speaker) under the passenger seat.
    This is accomplished by cutting the wires that connect the circuit board to the face plate and splicing in longer wires to bridge the gap between the passenger seat and the center console.
    Here is how I did it:
    Extending the faceplate wires
    I took apart the radio and found over 40 wires connecting the faceplate to the body.:( This includes wires for the switches, dials, display and SWR meter gauge. I decided to use CAT5 ethernet cable because I had an old 500 ft spool setting around for a few years and each strand has 8 wires in it. In all it took me about 6 strands of the CAT5 cable.
    So, I plugged in the soldering iron, turned on the Fox Saturday baseball (Dodgers vs. Cubs) and got to work. By the time the Dodgers had shut out the sorry Cubs I was almost finished.
    So, over 80 solder connections later, I was finished with the toughest part. I immediately tested all functions of the radio to make sure everything worked. To my amazement everything worked.:bananadance: I must be lucky or good at soldering.
    Mounting the Radio Housing
    I removed the center console and passenger seat. I ran a power cable to the fuse block and ran my antenna cable.
    I was able to fish the power cable under the carpet to where the shifter is and from there to the fuse block.
    I was able to strap the radio down to the floor using zip ties connecting with some metal support braces under the carpet. Not very pretty, but no one will see it.
    I mounted it with the speaker facing up. I will see if it is loud enough, if not I will get an external speaker at a later time.
    Mounting the Faceplate
    I cut a hole in the bottom of the center console to feed the wires through. Then I cut a new base plate for the console out of some plywood.
    I covered it with some felt (to look pretty) and installed the faceplate in wood base plate. I added some wood blocks under the deck to provide the spacing I needed and while I was there I decided to add a 12v power source.
    Here is the finished product
    Below are 2 pictures with the seat slid all the way back.
  2. Aug 25, 2009 at 4:50 AM
    98tacoma27
    Ben
    Not Beech Creek
    Niiiiicccceee!!
  3. Aug 25, 2009 at 4:52 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    :eek: amazing~!!
  4. Aug 25, 2009 at 6:03 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    As an electronics junkie who has modded or repaired almost every type of small electronic device I've ever owned, I'm embarrassed that you beat me to this!
    It looks Great! And you can bet that when I install my CB I'll be doing the same thing. I just might choose a different place for mounting the controls.
    nova423 likes this.
  5. Aug 25, 2009 at 6:14 AM
    kasey200
    kasey200 Well-Known Member
    south dakota
    07 TRD Dboubl Cab Longbed
    3" toytec, 285 BFG AT's
    come do mine!! i have the same radio out of my last truck that sits in my garage because it doesn't fit anywhere in the Taco.
  6. Aug 25, 2009 at 6:49 AM
    MT_mudflaps
    MT_mudflaps Just playin' on the runways
    Clint
    Bellflower, CA
    Indigo SR5 PreRunner with TRD off road
    Likewise, I have the exact same radio -- been wondering what to do with it! That's awesome!
  7. Aug 25, 2009 at 11:00 AM
    Fuzzyman81
    Fuzzyman81 The New Guy
    Jax, FL
    04 PreRunner TRD
    You wanna solder another for some cash! :) LMAO.
  8. Aug 25, 2009 at 11:10 AM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    Holy Shiny, that's a bright face plate!
    Nice work. When I saw you taking it apart, I was like... "Oh crap, here's a mod going south fast...", but you pulled it through. Looks tight.
  9. Aug 25, 2009 at 11:28 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    How much to just get a plug and play of that made? But wow, too much sodering for me, I would have just put the entire thing in the center console if it fit and if you weren't planning on using the space just my 2 pennies. You could relocate it to the dash somewhere and that would look SWEET!
  10. Aug 25, 2009 at 6:43 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    nice job.:thumbsup:
  11. Aug 25, 2009 at 6:53 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Excellent work!!!!!
  12. Aug 25, 2009 at 7:08 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    looks awsome
  13. Aug 25, 2009 at 7:11 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    That is damn genius! Awesome job!
    You want to do another for cash also?
  14. Aug 30, 2009 at 9:28 AM
    DDD
    Derek
    Santa Clarita, CA
    Forgot to add:
    Here is how I ran the Coax antenna cable to the antenna.
    Here is the grommet that I am going to use.
    I pulled out the grommet and used a sharp tool to poke a hole into it.
    I shoved my needle nose pliers through the hole.
    And grabbed a hold of the wire.
    Slide the grommet over the wire.
    Finally put the grommet back into the hole.
    Its water tight and you don't have to drill any holes in your truck. Now I ran the cable under the right rear door floor panel to the passenger seat. There is already a channel with wires under that floor panel with room for 1 more wire...
    Spencer97TJ likes this.
  15. Aug 30, 2009 at 9:34 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    damn good job you did with this mod man!!! very nice!
  16. Aug 30, 2009 at 11:40 AM
    MT_mudflaps
    Clint
    Bellflower, CA
    Good to go!
  17. Sep 28, 2009 at 6:01 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Wow, that is a nice install!
    And thanks for the nod in the original post. I really don't like where mine is mounted, but I never even considered anything like this!
  18. Oct 5, 2009 at 1:26 AM
    07prerunner91
    07prerunner91 Member
    Pleasanton, CA
    07 Prerunner 3in lift 285/75/r16 sim beadlock
    3in spacer, 2in add a leaf, 285/75/r16 toyo open country m/t's, ultra black rims with simulated bead lock, bhlm, recessed billet grill, touch screen in dash, amp, sub
    Oh my god! that is some impressive work! you definitely have my respect!!!
  19. Oct 5, 2009 at 2:11 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Nice work!
    If I could do this install I would put a CB in my Tacoma.
    AustinPizzini likes this.
  20. Oct 5, 2009 at 9:08 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Wow, Props. That's a lot of work. Almost all the modern amateur radios have remote mount faces its very convenient.
    nova423 likes this.
