CB Radio / 2 way radio question for hunting / backroad exploring.
Discussion in 'Audio & Video' started by neverstuck, Jul 25, 2015.
  1. Jul 25, 2015 at 10:41 PM
    neverstuck
    neverstuck [OP] Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    I have never used radios outside of work and those are preset channels so I know little to nothing about CB's etc.
    I want to pick up a couple 2-way radios for an upcoming hunting trip. This hunting trip will take place where there is zero cell coverage or residences within 75 kms. I also travel a lot of remote areas and FSR's. For these 2 main reasons, I was thinking instead of the uniden/motorolla/midway 2-way radios, I would spring for a couple handheld CB's that could be used to call for help or monitor local traffic as well. I know the range on them sucks and would likely have to be paired with a larger vehicle mounted antenna for good range, but could also be used while away from the truck, on foot, to stay in touch.
    Do these portable CB's work pretty well for 2 way comms in the woods or are they just for industrial settings where people loading trucks can direct traffic and communicate with drivers and that kind of stuff?
    Help me pick an option
    1) buy a couple motorola 2 way radios because they work better for 2 way comms in the bush and portable CB's are not as good for that, and also suck for CB comms in remote areas, then in the future buy a hard mount CB unit if I decide I want one,
    2) pick up a couple CB portable units and a magnetic antenna for the truck when I want to use it in the truck for a better signal
    Safety isn't a huge issue with the CB's calling for help, because I have a Delorme Inreach SE that I will use in an emergency.
    Hopefully some radio guys see this thread.
    Thanks.
  2. Jul 25, 2015 at 10:55 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Subbed. I'm interested too
  3. Jul 26, 2015 at 12:03 PM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    Any radio guys out there today?
  4. Jul 26, 2015 at 6:14 PM
    Fahrenheit
    Fahrenheit Well-Hung Member
    Garth
    NS
    I myself would not only like to see CBs, but how they're mounted
  5. Jul 26, 2015 at 6:21 PM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Been wondering about this same thing. Sub'd.
  6. Jul 26, 2015 at 6:31 PM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    I to would like some info on this. Been thinking of 2 way radios for awhile now. Anyone???
  7. Jul 26, 2015 at 8:05 PM
    Fahrenheit
    Garth
    NS
  8. Jul 26, 2015 at 9:31 PM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    Have you searched yet? There's loads of CB install threads
    https://www.tacomaworld.com/search/406245/?q=CB+install&t=post&o=date&c[title_only]=1
    I'm looking for recommendations about using the portable handheld units for 2 way comms instead of the GMRS radios.
  9. Jul 30, 2015 at 8:35 AM
    uno676
    uno676 Well-Known Member
    Lonnie
    Colorado
    2009 DCB Long Box 4x4
    Your better off with gmrs for handheld communications cbs are good for mobile situations. The antenna requirements really hinder cb handheld applications. They have to be fairly long to work effectively. Sorry misread your original post I would go
    With a mobile unit with a vehicle antenna. Just make sure your swrs are low on your antenna. Cobra 25 is a good little radio with a Wilson antenna. Lil wil is a good little mag mount antenna.
    neverstuck[OP] likes this.
  10. Aug 1, 2015 at 9:50 AM
    wobble
    wobble Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    When I used to hunt, we used GMRS (Motorola Talkabout) radios while on foot for communication. We got more range than handheld CBs and they were much smaller and lighter to carry. We used CBs to communicate while in our trucks (Wilson roof mount antennas).
    neverstuck[OP] and Biscuits like this.
  11. Aug 1, 2015 at 4:34 PM
    Pappa Weasel
    Pappa Weasel Well-Known Member
    Stu
    Arvada CO.
    09 MGM 4x4 2.7L
    Bilstein 5100,Toytec AAL, AFE Drop in, All-Pro Slider general Ham radio license with radio setup in truck. Differental Air Breather Mod 2lo Mod ATO Dual batteries setup Optima red and yellow top batteries Rigid industries dually spots on window posts Fog lights,OTRATTW switches with Iggy's panel. Rear floods on Thule heavy duty truck ladder rack with half basket. 4.56 gears. Level 8 wheels.
    Get your ham radio tech license. Pretty easy to do if your a quick study. Way more reliable in an emergency and not much more expensive. Yeasu FT-60R around $150 for a handheld. Woxum HT's around $100. Then use Motorola Talkabouts with your buddies in the field and the Ham in your vehicle for longer distants and emergencies. With repeaters and such you will hardly ever be out of touch. Ham Radio test is about $15.
    Yes you can spend way more like any hobby (MODS!:)) with the new Digital rabios and GPS setups but for saftey Ham is the choice.
    Cb's in the mountains your lucky to get 3-5 miles.
    Call Sign KE0EXT
    llibrm and Biscuits like this.
  12. Aug 1, 2015 at 4:37 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    Hell you can even get a boufang for around $40 which still provides more power and clarity than a cb
  13. Aug 1, 2015 at 4:51 PM
    Pappa Weasel
    Stu
    Arvada CO.
    09 MGM 4x4 2.7L
    Here's my setup!
  14. Aug 9, 2015 at 12:47 PM
    taco_mike
    taco_mike Active Member
    CB radio's are better for when you are on the road
    FRS/GMRS is generally better for on foot
    That being said don't expect more than a mile range from the talkabouts in heavily forested areas or hilly terrain and thats really pushing it. Expect realistically 1/4 mile to 1/2 mile range. The nice thing about cb's is that you can change the antenna to get better performance compared to FRS/GMRS. I personally run both. I have a Motorola talkabout and I have a midland portable CB radio with a magnetic mount antenna.
  15. Aug 9, 2015 at 1:10 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    I want to take a moment and clear something up for those not in the radio know. OP is from Vancouver Island, GMRS does not require a license in Canada. However, GMRS is the US does require a license. So the OP and other Canadians can run them legal, but for anyone in the US, there is a fee to get a license (no test). In the US you can use FRS without a license and thats what is in every WallyWorld, Bass Pro, Cabelas, Target, etc.
    FRS < GMRS < CB (also know as 11 meter) < Amateur Radio (ham radio).
    Handhelds (HTs) are crap, it doesn't matter the application, they are built as under powered options. You can beef them up with mobile configurations (Antennas, amplifiers, power sources) but they will always be very limited in what they can do. Be careful, in the US it is illegal to amplify a CB (yes people do it all the time, but still) I don't know about Canada.
    Distance is very subjective. In the flatter parts of the world you can get miles out of FRS/GMRS/CB radios without issue, put a few mountains or hills (even trees) in the way and you will cut that down to Line of Sight (LOS) of a few hundred feet. If you are just talking to guys on a run, than HTs for any of the options will work fine. If you are wanting more. Talking to a base camp, another group running a different trail or even back to the city (this can give you the ability to make calls to phones) then you need a Ham license and a mobile unit.
    The downside to ham is that your buddies have to be willing to put in the time and money to get a license and equipment. A couple of CB or GMRS HTs are cheap and can be operated by anyone.
  16. Aug 9, 2015 at 1:21 PM
    taco_mike
    Could not have said it better!
