CB Mods
Discussion in 'Technology' started by Namyo, Jun 22, 2011.
  1. Jun 22, 2011 at 6:15 AM
    Namyo
    Namyo [OP] -
    What mods have you done to your CB?
  2. Jun 22, 2011 at 6:23 AM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    I not have one yet but some folks adding amplifiers for further range.
  3. Jun 22, 2011 at 6:28 AM
    Namyo
    Namyo [OP] -
    Pretty sure what I'm learning is that you have to be able to adjust your dead key down to use a amp....which rules out the compact cb's Tacomas like. Maybe some one will chime in with a power adjust mod for a Cobra 19? :)
  4. Jun 22, 2011 at 6:34 AM
    Namyo
    Namyo [OP] -
  5. Jun 22, 2011 at 6:40 AM
    Namyo
    Namyo [OP] -
    Did you get it on a watt meter? Dead key and swing?
    I seen that mod for the compact cb's....should be able to swing 25-30 watts:notsure:
  6. Jun 22, 2011 at 6:51 AM
    Namyo
    Namyo [OP] -
    Kinda why I started this thread...had a cb since high school and just learning these things too :anonymous: didn't see any threads talking about this in here.
    Dead Key is the watt put out when cuing the talk button....should be around 3-4 watts on most cb's.
    Swing is the watt level when talking....6-8 watts on most cb's.
    Yelling or a amped mic will swing more watts.
    Kinda hoping someone that really knows what the hell their talking about jumps in.:eek:
  7. Jun 22, 2011 at 7:08 AM
    Namyo
    Namyo [OP] -
  8. Jun 22, 2011 at 7:18 AM
    Namyo
    Namyo [OP] -
    The bigger CB's will double that with the simple turn of a pot from what im reading....but their BIG :cool:
  9. Jun 22, 2011 at 9:43 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Modding your CB is illegal. ANyways... remember if you do mod it and manage to get 30-40 watts out of it you will need to make sure your power connections can handle the extra power. out of the box they only make 4 watts and use much less power. More power wont expand your range significantly. The short range of CBs is primarily due to the band they operate and the way radio waves in this band propagate.
  10. Jun 22, 2011 at 10:36 AM
    Namyo
    Namyo [OP] -
    Not sure about that law....I would guess it's not illegal to mod it, just to use it :p Only cause it doesn't seem to be illegal to buy a modded CB :confused:
    I just find this subject interesting....looks pretty easy to jump out there with 100watts or more :eek:.
  11. Jun 22, 2011 at 11:22 AM
    PreRunnerSeth
    Apex, NC
    Transmitting anything over 4w on CB is illegal, but the enforcement of CB laws is very lax. Modifying any device that requires FCC certification is illegal.
  12. Jun 22, 2011 at 11:26 AM
    Namyo
    Namyo [OP] -
    oh..I was reading that cb's from the factory dead key @ 4 watts and swing to 10 watts.
    Then modded cb's still dead key @ 4 and swing to 30-50 :confused:
    Of course I did see some rigs that had a DK of 40 watts swinging to 500 :eek:
  13. Jun 22, 2011 at 11:27 AM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    CD radios are very limited in talk distance due to the band that they use. It is illegal to "mod" a CB. The radios that you can buy that have been "modded" are either an Export radio (not ment to be sold in the USA) or have simpily be aligned properly.
    Use of an amp for CB is also illegal but legal for Ameteur Radio (HAM). Using an amp or linear... Most inear's need an input wattage (wattage of output from the radio) of 35-50 watts to make them work.
  14. Jun 22, 2011 at 11:30 AM
    Namyo
    Namyo [OP] -
    hmmm....what does aligned properly mean?
    and what is the difference between linear and a amp?
  15. Jun 22, 2011 at 11:35 AM
    Namyo
    Namyo [OP] -
    aligned properly means just 100% modulation? and a amp would not need watts from the cb...just boost the peak? :eek:
  16. Jun 22, 2011 at 11:47 AM
    kd8awe
    Rocky
    Ohio
    4x4 TRD Off Road
    They are the same thing. If you REALLY want a radio that will be able to talk a long distance... Take the test to become a HAM and get your license. A CB putting out 5 watts can (maybe) cover a distance of 20-30 miles... A ham radio putting out 5 watts can cover a distance of 100 miles depending on weather conditions. Ham radio operators have been able to talk 1000's of miles. Ham radio operator can bounce their signal off of satiellites or even the moon (google Earth-moon-Earth bounce)
    http://en.wikipedia.org/wiki/EME_(communications)
    http://www.squidoo.com/CB-Radio-DX
    http://www.squidoo.com/CB-Radio-and-Ham-Radio
  17. Jun 22, 2011 at 11:51 AM
    Namyo
    Namyo [OP] -
    nah don't really want...or need to talk long distance. Just curious...I have a amp for a cb that I used to use (pretty sure I didn't use it right)
    now I need a new cb as mine is crapping out and started to research....very deep subject to me.
  18. Jun 22, 2011 at 12:10 PM
    kd8awe
    Rocky
    Ohio
    4x4 TRD Off Road
    Aligment is to keep the radio on chanel. Have you ever hear someone on a CB talking and if you switch chanels (Up or down) you still hear them clearly. That is bleed over (devation). His radio it tranmitting off freq (chanel).
    Think of your truck as a carrier and your butt and modulation. When you key the mike there is a signal being put out by the radio (transmit wattage + modulation). Your butt (modulation) rides on that carrier (truck).
    Low modulation + low wattage = weak audio and short distance.
    Strong modulation + low wattage = poor distance good audio.
    What you want is a good balance of modulation and output wattage (remamber CB's can by law only have 5-12 watts)
  19. Jun 22, 2011 at 12:17 PM
    kd8awe
    Rocky
    Ohio
    4x4 TRD Off Road
    Sorry I forgot ...The amp (linear)
    Your radio must have a good amount of wattage output (through the antenna) to drive the amp. The amp will only respond (boost output) if it has enough in put wattage. Most amp's (linears) are for Ham radio and have been re-worked to function on the radio band that CB uses.
  20. Jun 22, 2011 at 12:38 PM
    Namyo
    Namyo [OP] -
    I have heard that...and watched a guy tune a radio with checking the frequency after turning the modulation up to 100%. He also showed the AM wave and it started to spike just past 100%. (instead of smooth waves)
    the 5-12 law makes more sense to me after learning swing. Thanks
    I was getting the incling that you needed a lower dead key to run an amp...just from cb reviews...like a power knob u see on some models to turn down. Almost like 4w DK was too much for an amp....
