Catback Exhaust without a muffler
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jonah Lyman, Nov 15, 2023.
  1. Nov 15, 2023 at 8:25 PM
    Jonah Lyman
    Jonah Lyman [OP] Jonah Lyman
    Jonah
    Washington
    95 Xtra Cab 3.4 4WD
    Im wanting to add an aftermarket exhaust on my 95 Tacoma 4wd 5vz and am wondering if anyone know where I can find just the catback tubing without the muffler. I dont want to have to custom fabricate an exhaust if I dont have to. I want to put a Black Widow race venom muffler on which is significantly shorter than the factory muffler. Would be fine with welding a little extra tubing to the pipes. Would also like to see exhausts that they have done themselves so if I had to make my own I could kinda see what others have done.
  2. Nov 16, 2023 at 7:16 AM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    Please don't be "that guy". Get your Black Widow, dump the exhaust before the axle and have it pointing towards that ground. It'll be plenty loud and less annoying.
    Glueman likes this.
  3. Nov 16, 2023 at 8:10 AM
    GoJo
    GoJo Well-Known Member
    Utah
    Jonah Lyman[OP] likes this.
  4. Nov 16, 2023 at 10:18 PM
    tacoseveryday4567
    tacoseveryday4567 Member
    Jacob
    Marina
    2000 Tacoma
    I run the Black Widow Race Venom on my truck, I like it for the most part. If I ever remember ill try and post videos sometime tomorrow if youd like.
  5. Nov 16, 2023 at 10:35 PM
    Jonah Lyman
    Jonah
    Washington
    95 Xtra Cab 3.4 4WD
    That would be cool, if you dont mind me asking what did you do for the rest of the exhaust? Thought about stepping up to a 2 1/2" exhaust size but ive read that people lose low end at that size and if you go above that it is really sluggish on acceleration. It would be great to see a video of it, thanks.
  6. Nov 16, 2023 at 10:39 PM
    tacoseveryday4567
    Jacob
    Marina
    2000 Tacoma
    Im not sure if its the same for a 95, but for my 00 my exhaust is 2.25 and it steps up to 2.5 for the end of the tailpipe above the axle. I just had an exhaust shop weld it on and use adapters for the diameter difference.
  7. Nov 16, 2023 at 11:11 PM
    Jonah Lyman
    Jonah
    Washington
    95 Xtra Cab 3.4 4WD
    Didnt think about that, would be easy for the Race Venom because the smallest out size is 2.5.
  8. Nov 17, 2023 at 1:20 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Whatever you do make sure the exhaust gas isn't going places that will heat up stuff. All that old plastic, wiring etc. Pointing it to the ground will be fine. In my opinion without a muffler it will sound like total shit but you do you. The drone on it will kind of get annoying inside the cab.
  9. Nov 17, 2023 at 2:00 PM
    Jonah Lyman
    Jonah
    Washington
    95 Xtra Cab 3.4 4WD
    When I said no muffler, I meant I wanted a exhaust kit just without the muffler because I want to put my own muffler on. Definitely agree with you on the plastics, changed the valve covers on my pickup and the plastic cover with all the wiring under the bottom intake plenum just shattered when I tried to move it. Now pieced back together and held by high temp electrical tape.
    Xbeaus[QUOTED] likes this.
  10. Nov 17, 2023 at 3:11 PM
    tacoseveryday4567
    Jacob
    Marina
    2000 Tacoma
  11. Nov 17, 2023 at 5:57 PM
    Jonah Lyman
    Jonah
    Washington
    95 Xtra Cab 3.4 4WD
    Sweet man, sounds good. If possible could you upload a picture or video of your exhaust setup? Wanting to order the muffler either tonight or tomorrow. Not sure if I should get the one with the center in center out pipe, or the offset one. Just whenever you get the chance dont wanna rush ya.
  12. Nov 18, 2023 at 8:12 AM
    Xbeaus
    Beau
    mine broke apart as well. Shattered as soon as I touched it. Found some heat rated silicon stretchy wrap. Shits the bomb. Holding out quite well. Got it at o’reilleys.
    I put a flowmaster 40 on my 3.4. Sounds pretty good! Ran it for a second without it to go get the muffler welded on so just cat and pipe and man - it was a terrible sounding smelly ride! Haha
